Does new post show immediately? - Diesel Forum - TheDieselStop.com
News, Comments, Site Help and Suggestions Discussion of TheDieselStop.Com itself. What do you like or don't like, kudos and complaints, comments and suggestions.
 2Likes
  • 1 Post By klhansen
  • 1 Post By Administrator
post #1 of 5 (permalink) Old 03-20-2019, 11:49 AM Thread Starter
Was wondering if new posts show immediately- wrote up a lengthy post and submitted, but donít see it. Did I mess up somewhere and have to retype whole thing again? Thanks.
"Nothing solves a problem like an aluminum bat and a wood chipper."-Author Unk
2018 F350 SD KING RANCH
1990 RAM 12 VALVE CUMMINS
Wayovertorqued is offline
post #2 of 5 (permalink) Old 03-20-2019, 12:36 PM
I have no idea what happened to your lengthy post. It doesn't seem to be around anywhere. My suggestion is to retype the whole thing again, then copy and save it to a word document just in case it gets lost again somehow.
DonWarkentin is offline
post #3 of 5 (permalink) Old 03-20-2019, 01:28 PM Thread Starter
i had a feeling thats what happened. i will def do that this time. Thanks so much.
post #4 of 5 (permalink) Old 03-20-2019, 02:00 PM
klhansen's Avatar
My Photos: (180)
Your post was tagged as moderated. The system seems to do that with long posts or stuff with lots of numbers, etc. in them.
I've released it, so no need to repost.
I've also commented to Administrator about that. Seems like more and more posts need to be approved by a moderator.
Welcome to TheDieselStop. And thanks for the informative post.
AG Jeff likes this.
), AIS,
regulated return,
klhansen is offline
post #5 of 5 (permalink) Old 03-21-2019, 09:30 AM
Administrator's Avatar
klhasen got you sorted. We'll look into the report they sent up as well.
- JB
AG Jeff likes this.
Administrator is offline
  Diesel Forum - TheDieselStop.com > General Discussion > News, Comments, Site Help and Suggestions
Similar Threads
"NEW" posts & Show me the first UNREAD post PSDfreak News, Comments, Site Help and Suggestions 7 01-31-2008 02:30 PM
Taking the Plunge, first performance modifications DarthSurplus '99 & up Upgrades and Aftermarket - 7.3L Engine 7 07-27-2005 11:05 AM
downtube ok for pyrometer ? RAMROD5000 '99 & up Upgrades and Aftermarket - 7.3L Engine 105 04-11-2005 06:06 PM
posts draasch News, Comments, Site Help and Suggestions 3 12-07-2004 09:46 PM
