how 2 use search on this site - Diesel Forum - TheDieselStop.com
News, Comments, Site Help and Suggestions Discussion of TheDieselStop.Com itself. What do you like or don't like, kudos and complaints, comments and suggestions.
post #1 of 12 (permalink) Old 08-22-2006, 09:25 AM Thread Starter
Inc
Ok how do ya get the search function to work on this site?
Ive tried several ways, several times, on different things and can never get anything to come up.
Am looking for information on the trans diode in the 4r100
2000 7.3 auto F-350 CC,LB,DRW, 4x4, 4:10's
ISSPRO piller mount gauges, IAH delete, DIY Tymar, Boost fooler, 203 thermostat, HX crossover, Zoodad Mod, MBRP 4" exhaust, SP Diesel EBPV Brake & TCC controler, 6.0 trans cooler, CCV Mod, WW, BTS vb, PI convertor, 'pooned tank, tank and pre-pump mods, DP-Tuner no start, stock, 40t, 60t, 80e, and 120r, fumoto valve
Inc is offline
post #2 of 12 (permalink) Old 08-22-2006, 10:17 AM
haul_n_horses2's Avatar
My Photos: (17)
Re: how 2 use search on this site
Click on search. In the list of forums to the left select 7.3 engine and drivetrain and control click (right click??) on the forum 7.3 aftermarket and upgrades so both of these forums are selected (searched).
Fill in the box for the search terms with "mechanical diode" and click the radio button for the subject heading and body.
Very important. Go down to the date range and select years and put in 5 so you will find all posts in those two forums in the past 5 years that contain the term mechanical diode (I am assuming that is what you are searching for). Hit search and voila 331 posts with those terms.
2002 F350 Lariat CC 4x4 Auto 4.10 DRW, DP-Tuner F5 live tuned stock, quiet, 40dd, 40, 60, 80 tow, 80e and 120r, B&W GN, BrakeSmart, 'pooned tank, tank and pre-pump mods, 2 Dahl 100 filter, regulated return, BTS dual HPOP, AC singles with EDM 34 lpm nozzles, AIS, H2e, Spearco 6.0 IC, Hypermax 3.5" dp--> MBRP 4" 304SS exhaust, BTS tranny, 203 T-stat, Chevron ELC, Oilguard bypass with Schaeffer 9000, WranglerNW 200 amp alternator, Nippon-Denso starter, SPA gauges, SteveRacer mods, Hella 80/100W 9007s, Hella Micro DE foglights, 1000FF driving lights, 220W backup lights, Stancor contactor, X-Springs, Bilstein shox, custom bumpers but otherwise stock. Nov 30 '99 build engine with 16 K miles, Fluidampr, Comp Cam 910 springs, Melling LPOP and ARP headstuds but otherwise stock.
haul_n_horses2 is offline
post #3 of 12 (permalink) Old 08-22-2006, 11:28 AM
Maintain's Avatar
http://forums.thedieselstop.com/ubbthrea...;gonew=1#UNREAD
2001 F250 CC/SB Platinum
11.62 @ 115.79
SWAMPED
Maintain is offline
post #4 of 12 (permalink) Old 08-22-2006, 11:49 AM Thread Starter
Inc
thanks got it. is that the way to make it work? the 5 years part?
seems as though it has pulled EVERY post for the last 5 years not just the ones i'm looking for?
Inc is offline
post #5 of 12 (permalink) Old 08-22-2006, 12:11 PM
My Photos: (17)
did you put the keywords in quotes? If you do it looks for that exact phrase, otherwise it will look for all posts in those forums in the past 5 years with either the work mechanical or the word diode in them. If you want just posts with both words, you need to precede them with a + symbol. If you just want posts with the phrase mechanical diode, use quotes around the phrase.
post #6 of 12 (permalink) Old 08-22-2006, 12:18 PM
The way that I've found works best is just to go to google, plug in what you're looking for, maybe some info on your truck, and type "site:thedieselstop.com" at the end. You'll only get back results from this domain.
2002 F250 4x4
T-444E 6-speed
Alan_Hicks is offline
post #7 of 12 (permalink) Old 08-22-2006, 12:18 PM
My Photos: (24)
I've been using the search function for the past 5 years or so, and once you figure out the system, it really works great.
2001 F-250 (pcm PMT2) ISS Pro EV tranny, boost, pyro gauges. TS Performance flip chip. Banks MONSTER exhaust, Maghytec rear diff cover, ITP H/X kit, Whelan 52" Strobe Bar, Fisher 8.5' Snow Plow, 3 Weatherguard tool boxes. HUTCH fuel tank mods, REMANFACTURED Ford transmission.
CPSS is offline
post #8 of 12 (permalink) Old 08-22-2006, 12:42 PM
how many years did it take and what is the secret
99 f350 4x4 cc 145,000 miles fuel tank,lines ais
BTM
wilson61 is offline
post #9 of 12 (permalink) Old 08-22-2006, 01:27 PM
I agree, it really works well once you figure it out. [img]/ubbthreads/images/graemlins/grin.gif[/img] The fairly new feature of being able to pick and choose which forums to search from the list on the left helps (use control + click to select multiple ones).
Make sure you select the forums you want to search in. On the date range, I just delete the first box and go up to the blank selection, so in other words no date restriction, so it will return all results. I usually bump up the results per page to 200 so I don't have to click next so many times. Also, you can use the phrase in quotes like "mechanical diode" or do it this way: +mechanical +diode. The first should find the exact phrase, the second way will find posts with both words but not necessarily together or in that order.
Try searching and select the 7.3, 7.3U&A, general U&A, and gen. questions forums. No date restriction, and search on +2001 +mechanical +diode. Brings up some good results.
edit - this thread should probably be in the site questions forum... that way folks doing searches in the future can find it more easily. [img]/ubbthreads/images/graemlins/grin.gif[/img]
ryaneverk2 is offline
post #10 of 12 (permalink) Old 08-22-2006, 01:35 PM Thread Starter
Inc
(")seems to work just fine. like the delete range too.
all i have to do now is get under my tuck and get the build date.
thanks
INC
Inc is offline
post #11 of 12 (permalink) Old 08-22-2006, 01:49 PM
My Photos: (38)
Why do you have to get under the truck? The build date should be on the door or B pillar door post sticker.
gregrob is offline
post #12 of 12 (permalink) Old 08-23-2006, 02:15 AM
jgarden's Avatar
use + sign in front of each word you want to find.
TDS member #49 - 1999.5 (Built 4/26/99) White F350, CC, SRW, LWB, Lariat, AIC, 4R100 (4th transmission before 85k - gotta love this tranny), 6.0 trans cooler, manual shift 4wd, 3 inch leveling kit, KING reservoir shocks, 285-75-16 Bridgestone REVOs, Performance Friction Pads all around, Powerslot Cryo'd rotors in front, CD player, Infinity REF 6800CS speakers (front and rear), Garmin 2610 GPS (hardwired), 40/20/40 leather seats, heated turn signal- TT mirrors, Titan V hitch, weatherguard box, DP Tuner 4 Position chip (love it), AIS intake, Diesel Site CAC Boots, 4" Magnaflow exhaust, Diesel Innovations Up Pipe, gutted EBPV, Non EBPV Turbo Pedestal, X-Monitor. NO STEERING WHEN BRAKES ARE APPLIED!
Jack
jgarden is offline
  Diesel Forum - TheDieselStop.com > General Discussion > News, Comments, Site Help and Suggestions
