Member Profile - Diesel Forum - TheDieselStop.com
News, Comments, Site Help and Suggestions Discussion of TheDieselStop.Com itself. What do you like or don't like, kudos and complaints, comments and suggestions.
post #1 of 3 (permalink) Old 01-06-2019, 10:02 PM Thread Starter
Big Horn's Avatar
Member Profile
I have went to my member profile several times but do not see an option for adding my State (Illinois) . Can someone point me to where I can edit this—. Thanks!
2002 F350 7.3L / 4R100 - 4WD CC DRW 8 Box, AIH Delete, Gauges- Pyro, Trans Temp, Boost, Fuel Pressure, TS-6 tuner, Zoodad Mod, Mishimoto 31 row Trans cooler, Mobil 1 ATF, Trans return line ATF filter, Hutch/Harpoon Mod, Air Lift Load Lifter 5000 rear air springs, Rancho 9000 shocks, Timbrens on the front.
Big Horn is online now
post #2 of 3 (permalink) Old 01-06-2019, 10:25 PM
Top right corner of screen-User CP.
Left panel-Your Profile-Edit Your Details.
Center-Additional Information-Where you live.
DonWarkentin is offline
post #3 of 3 (permalink) Old 01-07-2019, 01:18 PM Thread Starter
Big Horn's Avatar
Sent a PM
  Diesel Forum - TheDieselStop.com > General Discussion > News, Comments, Site Help and Suggestions
