AM radio reception in a steel building - Diesel Forum - TheDieselStop.com
Off-Topic Discussions This is the area for general banter/chat. There are rules for this section, please read the sticky post in the section before participating. Enter at your own risk as some posts in here may be NSFW
 1Likes
  • 1 Post By DonWarkentin
post #1 of 10 (permalink) Old 12-21-2018, 11:16 PM Thread Starter
Does anyone have any tips for getting better AM reception with a DeWalt radio in a steel building?
2000 F450, 16' flatbed dually, auto, AIS, Aeroturbine Resonated muffler.
Don't argue with idiots. They will only pull you down to their level and beat you with experience.
Crabo is offline
post #2 of 10 (permalink) Old 12-22-2018, 02:22 AM
ArcticDriver's Avatar
Longer antenna?
We run a wire up the interior of the shop wall and it has brought in good signal for about 50 years.
10’-15’ is plenty.
SOLD:
ArcticDriver is offline
post #3 of 10 (permalink) Old 12-22-2018, 12:05 PM
If necessary, run the antenna to the outside of the building.
ford_doctor likes this.
2001 F350 XLT 4X4 crew cab, dual rear wheels, long bed, black, 7.3l turbo diesel, automatic transmission, 4.10, shift on the fly, running boards, sliding rear window, 38 gal fuel tank, Odyssey extreme 65-PC1750T batteries, Michelin LTX-MS2 rear tires, Sumitomo Encounter front tires, Shell Rotella Ultra elc, 11,500 gvwr, 20,000 gcwr, 7500 gvw, completely stock, 114,000 miles when purchased, now has 240,000 miles, repairs so far: two starters, batteries, cps, brakes, tires, alternator, ball joints, locking hub, wheel hub, AC compressor, serpentine belt, power steering pump, driver's side window, ignition switch, o-ring, Spectra premium radiator, water pump, fan clutch, fan blades, thermostat, thermostat housing, tensioner. Stolen twice so far, but recovered both times with major damage.
DonWarkentin is offline
post #4 of 10 (permalink) Old 12-22-2018, 03:16 PM
RT
RT's Avatar
Hold the antenna in one hand and hold your other hand in the air. Might need to hold one leg up as well.
Seriously, though - try touching the antenna to various metal objects to see if the reception improves. Might get lucky and find the building itself is a decent antenna.
Sent from my iPad using Tapatalk
RT is online now
post #5 of 10 (permalink) Old 12-23-2018, 12:54 AM
Texkenusmc's Avatar
I had to put my antana on different metal objects in my 50x50 metal shop to get a good signal.
Texkenusmc is offline
post #6 of 10 (permalink) Old 12-23-2018, 08:40 AM
Listen to FM. LOL
Stroking it is offline
post #7 of 10 (permalink) Old 12-23-2018, 08:53 AM
ford_doctor's Avatar
Actually with the technology now streaming off the Internet can get you pretty much any source of audio through many different devices that are now all too common. With respect to the original post I have to agree that an external antenna would be ideal.
2016 Ford Fusion ENERGI Titanium Plug-in Hybrid
Diesel Technician Society
Diesel Mentor Directory
ford_doctor is online now
post #8 of 10 (permalink) Old 12-23-2018, 09:46 AM
Yeah the internet Option does work well...maybe too well for me. Finding an AM radio signal without a little static or having to finagle the antenna a bit feels empty to me.
SOLD:
post #9 of 10 (permalink) Old 12-23-2018, 11:56 PM Thread Starter
So far I have tried everything suggested except adding a piece of wire. There is no internet access available, and no place to hook up an external antenna. Would you just wrap the wire around the existing antenna. The radio is one of the DeWalt jobsite radios.
Crabo is offline
post #10 of 10 (permalink) Old 12-24-2018, 12:38 AM
Exactly. My current radio is a 10-year old Milwaukee Jobsite radio.
You can just run a length of wire across the shop wall or just clamp to the gaspipe to your heater and then wrap the near end around your radio antenna.
I think you can even just make a loop of wire with a 6”-8” diameter and flop it over the radio.
AM signal is pretty easy to grab in a crude fashion.
SOLD:
  Diesel Forum - TheDieselStop.com > Other Topics > Off-Topic Discussions
