Best Tool - Diesel Forum - TheDieselStop.com
Off-Topic Discussions This is the area for general banter/chat. There are rules for this section, please read the sticky post in the section before participating. Enter at your own risk as some posts in here may be NSFW
 7Likes
post #1 of 22 (permalink) Old 12-15-2018, 09:47 AM Thread Starter
caseyj's Avatar
Best Tool
I have come to rely on my LED headlamp for all types of jobs. IMO one of the best investments I have ever made. They only cost around 25 or 30 dollars. Check em out if you haven't already.
Fix likes this.
1994 F250 HD, IDI Diesel, 3:55 gears, K&N filter, Hayden Tranny Cooler, Monroe HD SensaTrac shocks, dual pillar pod with temp & tranny guage, poly fuel tanks,aluminum racing radiator
caseyj is offline
post #2 of 22 (permalink) Old 12-15-2018, 10:35 AM
My Photos: (27)
I assume you mean the lamp you strap to your head? I got one a couple years ago and don't know what I ever did without it. Besides mechanical work I use it when cleaning out the pellet stove and anything else you can mention.
LMJD is offline
post #3 of 22 (permalink) Old 12-15-2018, 11:01 AM
I don't have one of those yet. You're making me think that I should get one.
DonWarkentin is online now
post #4 of 22 (permalink) Old 12-15-2018, 11:34 AM Thread Starter
caseyj's Avatar
Well, if you don't have one, now is the time to drop some hints.
Happy holidays to all and especially to those who have responded to my inquiries.
LMJD likes this.
caseyj is offline
post #5 of 22 (permalink) Old 12-15-2018, 11:46 AM
Thanks, Happy Holidays. I'm about to start dropping some hints.
post #6 of 22 (permalink) Old 12-15-2018, 02:27 PM
My Photos: (27)
Don, be sure to Google and read up on them, you want to get one with a really powerful light.
LMJD is offline
post #7 of 22 (permalink) Old 12-15-2018, 03:26 PM
I used one years ago, when I had to work on gas compressors out in the field after dark. That was before LED, and the thing was heavy, and hard on the 4 d-cell battries it used, but I never went without it. I now have two or three of the little LED ones. They really are the best thing sice sliced bread.
Merry Christmas to y'all
LMJD likes this.
1993 F-350 crew cab non-turbo 5 speed transmission
35 years a mechanic on large stationary engines natural gas and diesel fired, and other industrial equipment.
oldrebuiltdodge is offline
post #8 of 22 (permalink) Old 12-15-2018, 05:00 PM
bugman's Avatar
My Photos: (12)
The salesmen at the stores think that I am nuts when I ask them if I can put batteries in them and take them into a storeroom in the store and turn out all the lights so that I can tell how good they are.
Just the brightness doesn't work for me. I like a defused or a light that will spread out a little along with the brightness of it.
As for something to just throw into the truck I have a couple of cap lights that clip onto the brim of a hat. They are small and for their size they put out some good light.
LMJD likes this.
bugman is online now
post #9 of 22 (permalink) Old 12-16-2018, 09:50 AM
My Photos: (27)
Just looked and mine is a Black Diamond brand, appears to be 200 Lumens on bright beam and uses 4 AA batteries (rechargeable) in a pack on the back of the headband. Also has a red beam and a couple other features I don't use.
LMJD is offline
post #10 of 22 (permalink) Old 12-16-2018, 10:34 AM
Hat with lites in bill from lowes
early 99 f250 auto 190000 miles ts6 chip, riffraff frx, 6637 filter with riffraff cover edpv delete 4in exhaust tru- cool max,dedc tow mirrors with lights/heat,glow shift boost,egt,trans, fuel, gauges. hopkins agility brake control,pyle backup camera,firestone air bags,marinco plug, 265/75r 16 cooper discoverer a/t3 tires sinister diesel coolant filter,Bilstein 5100 stancor gpr.
stumpman is offline
post #11 of 22 (permalink) Old 12-16-2018, 11:24 AM
I found one that says that it has 45000 lumens. Would that be bright enough?
post #12 of 22 (permalink) Old 12-17-2018, 02:11 AM
klhansen's Avatar
My Photos: (180)
I have a Black Diamond headlamp that has 3 separate lenses and bulbs, The outside two work as a flood (wide) beam and the center one works as a spot beam. A second tap on the on button switches between flood and spot. Has a battery compartment that takes 3 AA batteries that are available virtually everywhere, as opposed to specialty type batteries.
), AIS,
regulated return,
klhansen is offline
post #13 of 22 (permalink) Old 12-17-2018, 08:10 AM
RT
RT's Avatar
Letís see. A 100 watt bulb is 1,600 lumens, so would 28 of those on your head be bright? Iíd be worried that whatever I looked at would catch on fire... Might be fun.
JJEdwards likes this.
RT is offline
post #14 of 22 (permalink) Old 12-17-2018, 05:18 PM
ArcticDriver's Avatar
Probably bright enough to permanently blind whoever comes up to talk to you and you forget to turn it off before looking their way!
Where I work the sun set back in November so we rely on headlamps daily. I can’t believe DonW has gotten this far in life without one...he must eat alot of carrots...Lol
SOLD:
ArcticDriver is offline
post #15 of 22 (permalink) Old 12-18-2018, 02:04 PM
Where I work the sun set back in November so we rely on headlamps daily. I canít believe DonW has gotten this far in life without one...he must eat alot of carrots...Lol
Forget the wimpy 45,000 lumens. I've been searching the internet, and I now have found one with 200,000 lumens with 11 LEDs.
  Diesel Forum - TheDieselStop.com > Other Topics > Off-Topic Discussions
