Ford follows VW down the drain? - Page 3 - Diesel Forum - TheDieselStop.com
Off-Topic Discussions This is the area for general banter/chat. There are rules for this section, please read the sticky post in the section before participating. Enter at your own risk as some posts in here may be NSFW
 15Likes
post #31 of 42 (permalink) Old 06-06-2018, 09:18 PM
ArcticDriver's Avatar
This article states VW is having trouble updating test equipment quickly enough to meet new EU Emissions Standards. More restrictions every year:
Volkswagen admits it can't cope with new emissions tests
http://www.bbc.co.uk/news/business-44383226
Europe is also seeing quite a bit of legislation against older diesels...sure hope nobody starts that over here.
SOLD:
ArcticDriver is offline
post #32 of 42 (permalink) Old 06-07-2018, 07:39 AM
Phil G.'s Avatar
Isn't that California?
2007 F350 SRW 6.0L Auto, 3.73LS, 172"WB 4x4. Viper Alarm/RS, WD pillar Guages,AutoEnginuity, 100gal polished alum fuel tank.
All Sold: 99.5, early03 , 2004 - all were 172" wb 4x4 lariat's.
My Worklog - *Updated 8/18 with Edge CTS2 install click here =>*:
Phil G. is offline
post #33 of 42 (permalink) Old 06-07-2018, 10:14 AM
79jasper's Avatar
Yeah, cali already did it.
Sent from my SM-G892A using Tapatalk
79jasper is offline
post #34 of 42 (permalink) Old 06-07-2018, 11:33 AM
Yes, we have to get smog checks in California, even though there were no smog requirements the year they were manufactured, and the vehicle has no smog control equipment on it. The smog check is to check to see if there are any modifications made to the vehicle. The vehicle must be completely stock with no modifications in order to pass smog.
2001 F350 XLT 4X4 crew cab, dual rear wheels, long bed, black, 7.3l turbo diesel, automatic transmission, 4.10, shift on the fly, running boards, sliding rear window, 38 gal fuel tank, Odyssey extreme 65-PC1750T batteries, Michelin LTX-MS2 rear tires, Sumitomo Encounter front tires, Shell Rotella Ultra elc, 11,500 gvwr, 20,000 gcwr, 7500 gvw, completely stock, 114,000 miles when purchased, now has 240,000 miles, repairs so far: two starters, batteries, cps, brakes, tires, alternator, ball joints, locking hub, wheel hub, AC compressor, serpentine belt, power steering pump, driver's side window, ignition switch, o-ring, Spectra premium radiator, water pump, fan clutch, fan blades, thermostat, thermostat housing, tensioner. Stolen twice so far, but recovered both times with major damage.
DonWarkentin is offline
post #35 of 42 (permalink) Old 06-07-2018, 02:53 PM
My Photos: (27)
Can't blame 'em for that. We got local idiots here old enough to get a license but childish enough to put stacks on a pickup so he can pretend he's in one of those big trucks that bend in the middle and go psss, psss when you brake. Their main event is puking out as much black smoke as possible----until the cops catch 'em.
ArcticDriver likes this.
LMJD is offline
post #36 of 42 (permalink) Old 06-07-2018, 04:08 PM Thread Starter
RT
RT's Avatar
Well, as much as I hate government intrusion, I'd be ok with a snap test in Texas. I swear I can't remember the last time I saw a Dodge that didn't fog the whole intersection every time they hit the accelerator...
LMJD and ArcticDriver like this.
RT is offline
post #37 of 42 (permalink) Old 06-08-2018, 07:41 AM
Phil G.'s Avatar
I just had mine tested yesterday so I could get my new tags for the year.
SNAP test results were 8.4 with a max limit to pass of 30. Man, I hate listening to that test... on the carpet at over 4000 RPM for several seconds 3 times in a row. It just doesn't sound right having a diesel revving that high. Now I wait to see if the valve train stays intact for the next few weeks. I seldom ever rev the truck much over 3K for very short periods of time usually when up shifting in tow haul with a load.
My reward for passing was a $114 bill for the test then $681 bill for tags for the truck and service plate. Expensive day....
Phil G. is offline
post #38 of 42 (permalink) Old 06-08-2018, 08:10 AM Thread Starter
RT
RT's Avatar
Our annual inspection on a diesel in Texas is $7.00 - yep, seven whole bucks... That gets you a quick look at your wiper blades, a glance at tire tread, making sure all your light bulbs work, and - most importantly - making sure the horn works since the last time is was probably used was the inspection the year before.
LMJD likes this.
RT is offline
post #39 of 42 (permalink) Old 06-08-2018, 11:09 AM
Phil G.'s Avatar
Oh, that is E-test.... just an e-test for the $114, then there's the annual safely inspection on top of that, it's using between $100-$200 if nothing in found wrong, it requires brakes to be disassembled and pads/rotors measured and recorded and of course full front end inspection, leaks, lights, windows up and down, seat belts working, etc etc the whole deal. Isn't that great??
Phil G. is offline
post #40 of 42 (permalink) Old 06-08-2018, 01:29 PM
My Photos: (27)
Phil, to put you in an even better mood, unless the law changed, I understood the yearly registration in Oregon was $32 or $34 even if it was a $200,000 Rolls Royce.
LMJD is offline
post #41 of 42 (permalink) Old 06-08-2018, 02:04 PM
badbart's Avatar
Makes me feel better. Florida has no emissions testing or annual safety inspections and my tags cost around $45 for my truck.
2011 F350 4x4 XL Crew Cab Dually
2010 Keystone Fuzion 405 Toyhauler
badbart is offline
post #42 of 42 (permalink) Old 06-09-2018, 08:22 AM
Phil G.'s Avatar
Yup, life is expensive around here. My truck is commercial and registered for just shy of 20K lbs plus the cost of the service plate for trailers, that drives the tags up considerably but the e-test is every two years and annual safety inspection cost, that applies even to Joe weekender with any pickup that has a door sticker showing over 10K, whether he registers it for that much weight or not.
At 10K registered, I think his tag cost would be about $200 so that's 200 tag+150 safety+ 50 e-test(1/2 the $110, it's two years) so that's $400 year before insurance to keep a newer 250/350 on the road unless it has the 9900 GVWR option.
LMJD likes this.
Phil G. is offline
  Diesel Forum - TheDieselStop.com > Other Topics > Off-Topic Discussions
