Transmission trouble? - Diesel Forum - TheDieselStop.com
Off-Topic Discussions This is the area for general banter/chat. There are rules for this section, please read the sticky post in the section before participating. Enter at your own risk as some posts in here may be NSFW
post #1 of 2 (permalink) Old 11-16-2019, 04:56 PM Thread Starter
RT
RT's Avatar
Thought this was funny
Sent from my iPad using Tapatalk
RT is offline
post #2 of 2 (permalink) Old 11-17-2019, 12:06 AM
And we probably should replace the flux capacitor while we're in there.
DonWarkentin is offline
  Diesel Forum - TheDieselStop.com > Other Topics > Off-Topic Discussions
