What is the deal with stolen and abandoned property - when does it become mine? - Diesel Forum - TheDieselStop.com
Off-Topic Discussions This is the area for general banter/chat. There are rules for this section, please read the sticky post in the section before participating. Enter at your own risk as some posts in here may be NSFW
post #1 of 4 (permalink) Old 12-15-2013, 07:56 PM Thread Starter
My Photos: (5)
I have a friend who had a piece of equipment dropped off in his parking lot. The serial tag was removed, the license plate was removed from the equipment trailer, he called the police to file a report and he was considering just having it towed out of his way. After how long would this equipment become his? I believe it was stolen. It is in great shape and the serial tags were removed.
2002 F-250, PSD 6-speed, CC, short bed, 4X4, Toreador Red w/ Silver accent, A.R.E mx cap, Weld Super Single II and 33s in the summer, x-springs, F-350 blocks and badges, AIC, proflaps, ITP intank mod, AirDog with 3 micron filter, isspro guages and TTM, scangauge, husky liners, alarm, xm stereo,stull 5399-p grille, centramatics, ccv mod, AIS Air Filter, Southbend CON O, Detroit Truetrac LSD, coolant filter, 203 stat with billet housing, blackcloud intake heater plug/boost fitting, reese titan hitch, fabcraft PTO cover/temp sender port, prodigy brake controller, ITP Boost Annihalator, oilguard bypass filter, Mag-Hytec rear dif, bilsteins, hellwig rear stabilizer bar, ATS housing, non-ebpv pedistal and exhaust flange, magnaflow 3.5dp exhaust, ITP reg return, turbomaster wastegate controller, and ceramic coated bellowed up pipes, PHP 50t and 80p, currently 127,000 miles.
clydesdale is offline
post #2 of 4 (permalink) Old 12-15-2013, 07:59 PM
Seems like a local court would be the best source of that info based on your township/city. Where I work after a certain amount of time and abandoned vehicle in the lot can be taken over but will need to submit for a title. With no numbers on that unit, it may be problematic.
jamesrxx951 is offline
post #3 of 4 (permalink) Old 12-17-2013, 02:50 PM
My Photos: (27)
I'd be real hesitant to ask, let alone to take one bit of advice, from a bunch of complete strangers on the errornet regarding a question like this. At least you can get a visual if you ask a total stranger on the street.
Yep, or county DA, even local law enforcement could say who to consult.
LMJD is offline
post #4 of 4 (permalink) Old 12-17-2013, 11:21 PM
Bill1013's Avatar
Consult a trailer manufacture if there is one in your area. I think there is a place on trailers where the Mfg. name and serial is scribed. Register it as homemade and sell it.
99.5 F350 XLT Lariat 4X4 4R100 4.10 DW CC LB Centurion conversion, 183K miles Garret Turbo, Radio SD &Tape, SP Performance 40-60-80 chip, 100 Gal.Transfer Flow W/Trimax Control Aux. fuel tank. ScanGaugeII, Boost, EGT, Trans. Temp. Oil Temp. Build date 03/99
92 F350 2WD 7.3 IDIT E4OD CC LB dually Banks turbo US Gear O/U, 79K on the engine. 129K body.
Have AutoEnginuity W/Ford enhanced. Lima OH area.
My mind works lightening fast. One Flash and it's gone forever.
Bill1013 is offline
  Diesel Forum - TheDieselStop.com > Other Topics > Off-Topic Discussions
