Question on Level 8 Tracker - Diesel Forum - TheDieselStop.com
Discount Tire
post #1 of 4 (permalink) Old 07-13-2011, 06:02 AM Thread Starter
Hi, I think from your description on the web site that these wheels (Wheel Details - Discount Tire Direct) will fit on the stock tires LT275 70R18 on a 2011 F350. There isn't a description of the supported weight of the rim, can I assume its comparable with the stock rim? Thanks.
2008 F350
2011 F350
tjdonald is offline
post #2 of 4 (permalink) Old 07-14-2011, 11:00 AM
Discount Tire's Avatar
Thank you for the post tjdonald.
I do not have the weight on your OEM 18" wheels but the 18x9 ET0 Level 8 Tracker weighs 28lbs.
As far as the fitment goes, your factory 275/70-18 tires are not recommended for a wheel wider than 8.5" so we do not recommend running them on the Tracker.
Tire sizes 285/70-18 and 285/65-18 would be good options to consider for this wheel.
Keep in mind that the 18x9 ET0 Tracker has 5" of Backspace so it will sit outside of the fender by about 1" and you may need to make some light fender modifications to avoid tire rub.
Low Prices! More Choices! Trusted Experts!
At The Store:
To Your Door:
Useful Links:
  • To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
Discount Tire is offline
post #3 of 4 (permalink) Old 07-15-2011, 08:58 PM Thread Starter
ok thanks ... and I really appreciate your help in this forum.
2008 F350
2011 F350
tjdonald is offline
post #4 of 4 (permalink) Old 07-16-2011, 11:10 AM
Anytime and thank you for your continued support.
At The Store:
To Your Door:
Useful Links:
  Diesel Forum - TheDieselStop.com > Vendors > Discount Tire
