$200 cab air ride install - Diesel Forum - TheDieselStop.com
Ford 650/750 Medium Duties Technical discussion of the new Ford Super Duty 650 and 750 series trucks with Power Stroke, Cummins, or Caterpillar engines.
post #1 of 6 (permalink) Old 06-28-2014, 05:05 PM Thread Starter
Finished this up last year and had to take the bed off this year for some upgrades and I could finally get some good pictures of the setup.
It came off a '98 international 9300 sleeper. The dimensions were perfect for the F-750.
'03 F-750 Supercrewzer
Cummins with air brakes and 10 speed roadranger conversion
94cobra2615 is offline
post #2 of 6 (permalink) Old 06-30-2014, 11:21 AM
38Chevy454's Avatar
Nice adapting the International parts. Is the front mount just the rubber bushing and it has sufficient give for the movement?
I used to have a handle on life......but it broke!
2006 F-650: 5.9/Allison
1988 F-250 4x4: 7.3 IDI with ATS, ZF-5
2005 Kenworth Motorhome: Cummins ISX15, 10-speed Ultrashift
38Chevy454 is offline
post #3 of 6 (permalink) Old 07-01-2014, 12:09 AM Thread Starter
Yes, the front mounts are the thick round ones with the steel on the outside. I'm not sure what's on the regular f550 and smaller trucks. I'll get a pic of the front mounts when I get a chance.
There seems to be plenty of give for the movement......no problems with that.
I love messing with these 650/750 trucks. You can adapt all kinds of stuff from semi's and the stuff is usually cheap from the wrecking yards.
It cost $200 for the air ride setup, bolts, and new monroe shocks for it.
post #4 of 6 (permalink) Old 07-01-2014, 06:09 AM
Googs's Avatar
Neat work, bet it's great to ride in for a bigger truck,what the next project.
03 F250 4x4 CC 7.3ltr 4R100HD rebuilt, 160,000 Klms
GTP38R , Turbo-master , IH Bellowed up pipes, RiffRaff CAC boot kit, AIH delete, .
4" Turbo back exhaust ,Banks power elbow, LPG (Gas over diesel) DP F6 tuner, 40hp tow, 60hp tow, 80hp tow, 60hp, 80hp, 120hp race, Decel, 1200 RPM.
RiffRaff 6637 intake ,pre filter, Snorkle
Custom made trans cooler with twin thermo fans ,water to oil cooler
Scangauge 11,AutoMeter Trans temp, pyro ,Water/Oil temp, Fuel Pressure, Boost.
Longrange 120 ltr fuel tank and transfer pump, 15,000 lb winch, Warn winch bar, Lightforce HID spot lights, HID headlights, Black Widow Drawer System, Snugtop Canopy with gull windows, Fr & Rr ARB Diff locks, Hornblaster Train horns, Post fuel pump filter, RiffRaff FRx and HPx , Bilsteins x4, Onboard compressor , Air tank and water traps, Billet door handles, Alpine headset, Alpine overhead DVD player, Rockford Fosgate sub, Alpine amp and CD changer.
Googs is offline
post #5 of 6 (permalink) Old 12-29-2014, 09:11 PM
I'm also putting in air ride on my 06 f750 cat/Allison can't tell if yours is a crew cab.
Worried about too much cab flex by removing the middle mounts
Thx for any info
Jbhaen is offline
post #6 of 6 (permalink) Old 08-08-2019, 02:23 PM
Hey it’s Lee I saw your air ride cab conversion on a F-750 I have a crew cab 04 650 what all modifications did you have to make beside getting the used air ride cab assembly off the international 9300 ?
dsoxjr is offline
  Diesel Forum - TheDieselStop.com > Ford Diesels > Ford 650/750 Medium Duties
