2000 F350 Pro Comp 6.5" or 8.5" - Diesel Forum - TheDieselStop.com
Forum sponsored by: Discount Tire
 2Likes
  • 1 Post By yan7gin
  • 1 Post By acade
post #1 of 11 (permalink) Old 02-28-2016, 05:35 PM Thread Starter
acade's Avatar
Alright fellas, I just picked up a 2000 F350 XLT 4x4 CCLB 7.3 ZF6 after being stationed overseas for 3 years and can't decide between the Pro Comp 6.5" and 8.5" lift kit. I had the 6.5" on my 99 and loved it. Had 16x10 wheels wrapped in 37x13.50 Interco tires. I am pondering going bigger so I can run 38x15.50 tires on some 18x10 wheels. Any suggestions or inputs welcome. From what I've been reading, it sounds like with the 8.5" I should be fine with the stock driveshafts. Maybe later I would think about getting custom driveshafts, but until that point, supposedly the stock shafts are ok. Any thoughts?
99 5.4L gasser with 6.5" Pro Comp
2000 F350 4X4 XLT CCLB SRW 7.3L ZF6
8.5" Pro Comp lift
16x12 M/T Classic IIIs with 38x15.50 Toyo Open Country M/T rubber
Riffraff Diesel 6637 intake, CCV mod, HPX, AIH delete, CAC boots/clamps/plenum inserts
Riffraff Diesel Coolant Filtration System, Billet Thermostat Housing
MBRP 4" SS straight exhaust
LuK clutch kit
Edge CS2 programmer
VIAIR on-board compressor w/Kleinn air horns
Amp Research Power Steps
2016 tailgate conversion
Iron Cross bumpers w/Rigid Dually LEDs
DeeZee tool box
Gooseneck hide-a-hitch
acade is offline
post #2 of 11 (permalink) Old 02-28-2016, 10:33 PM
yan7gin's Avatar
the other option if you don't what to go with the 8", you can take the 6" and add the bushwaker cut-out style fender flare. tha will give you plenty of space for 38.
I have only a 4" and i run the 37x13.5 with 2" spacer.
if you are going with the 8", i'm pretty sure procomp has a good kit and has everything you need to get everything lineup like it should. custom driveshaft will be a good idea later down the road
nice truck BTW
NOSPARKPLUGZ likes this.
F350 2002 7.3
auto, 37/13.5/20 open country, Bushwaker cut-out flare, Bilstein 5100, Maxtow gauges (EGT, Trans temp, Boost), 4 inch diamond eye turbo back axel drop with BTM muffler, S&B intake, RR AIH plug, billet FPR with gold spring, CNCfab Sgt 1 HPOP, CNCfab HPOP line with cross over, CNCfab 4 line fuel kit, ARP heads stud, RDP plenum reinforcing insert, complete CAC intercooler boot kit, full engine seal and gasket kit, 360* turbo rebuilt, WWII, EGPV delete, dark blue CPS, Hydra chip with SDK tunes, Polished compressor manifold, HD coolant, 203* thermostat, Transgo HD kit, Energy suspension bushing kit, front and rear diff fully rebuilt with 4:88 gear ratio, Z36 powerstop heavy hauling brake kit, headlight relay mod, Fumoto drain valve AND STICKER
F350 2008 6.4 (sold)
TT 26' Springdale 2014
7x17 enclose trailer (shop) 2012
yan7gin is offline
post #3 of 11 (permalink) Old 03-01-2016, 05:23 AM Thread Starter
acade's Avatar
I don't plan on using fender flares so I just want to make sure I can clear 38s. I don't think the height would be the problem, but the width is what I'm worried about. I would like to go with 15.50 tires on some 18x10 wheels with 5 inch backspace. I THIIINK that should push them out enough so they don't rub on the leafs. Also, my 99 gasser was ligther than the 7.3 so it actually sat a little bit higher. Although with the 8.5" on the 7.3 I think I should still be able to make the 38x15.50 tire work. Thoughts? Anybody running this lift/wheel/tire combo?
8.5" Pro Comp lift
LuK clutch kit
Edge CS2 programmer
DeeZee tool box
acade is offline
post #4 of 11 (permalink) Old 05-09-2016, 05:55 PM Thread Starter
acade's Avatar
finally got the lift installed; went with ProComp 8.5" lift; it came with everything except extended brake lines; the shop had to order a set of steel braided lines to finish the lift; all in all I love the look; I think for a CCLB you need the extra few inches for it to look proportional IMO; the front shaft ended up being too short so it's at the driveline shop now getting extended shafts
8.5" Pro Comp lift
LuK clutch kit
Edge CS2 programmer
DeeZee tool box
acade is offline
post #5 of 11 (permalink) Old 05-09-2016, 10:39 PM
yan7gin's Avatar
Look good!!! How you like it dlso far?
Sent from AutoGuide.com Free App
F350 2002 7.3
yan7gin is offline
post #6 of 11 (permalink) Old 05-10-2016, 11:53 AM
NOSPARKPLUGZ's Avatar
Jealous
2003 F550 LARIAT CCLB P/U 6.0 PSD - 4.88's, 22.5 AF Independence, 2" ReadyLift Level Kit, Goodyear 36" Tires, Dual Tanks, SCT TS, Projection Halo's, Looney Wild, 4" LOUZ Straight, Pypes 10" Tip, ARP's, Sinister Coolant Bypass, Sinister EGR Del., Pmax, S&B CAI, Rugged Cover Hard Tri-folding Cover, Chrome Angled Toolbox, Bed Lined, Dorman O.C, Kelderman 5K Rear Airbags, Casserly 155cc's, Sinister IC Blues, Sinister CAC BT's, Zoodad, Sinister RR, Aeromotive Regulator, K40, Cobra CB, Tekonsha P3, 40 LED's, Bull Bar, AM Grille, FB Delete, Ported Heads, VR HG's, AirLift 5K Front Air Bags, AirLift Tank, AirLift Double QuickShot Compressor, AirLift Dual Path Guage, Bilstein 5100's, Total 5" Lift And Some More Stuff.
2000 F350 LARIAT SCLB 4x4 7.3 PSD - 3.73's, Manual Locking Hubs, 14' Bed, 14' Tailgate, 14' Bumper, Spyder 8000k HID Smoked Halo Headlights, Dual Alternators, Dual Batteries, LED Smoked Clearance Lights, WW2, Looney Custom, SCT TS+, FASS Titanium Fuel System, FRx, 6.0 FPR Spring, Tuff Country 4" Suspension Lift, EZ Ride Leafs, Skyjacker 8000 Nitro Shocks & Struts w/Red Boots, BetterBuilt Nerf Bars, Fuel Krank 20x12 -44 Offset, 35" Mastercraft MXT, Extang Trifecta ToolBox Tonneau, Black Husky Topsider LowPro ToolBox, Black Mesh Grille, 5" Diamond Eye Straight Pipe, 4" Diamond Eye Downpipe, Aero-Turbine AT5050 Muff., OBS CPS, Genssi 8" Exhaust Tip. Skyjacker Nitro 9000 Dual SS, 4 AutoTek 6x8 Door Speakers, Rockford Fosgate Punch 10" Subwoofer, Rockford Fosgate Punch 600W Amp, SoundStorm DD662B H/U, K40/K30, LED Dome Lights, Grille Strobes, Smoked 3rd Brake, 08 LED Mirrors, Colorshift Interior LEDs,
2005 E450 6.0 PSD - 4.10's, 16ft Unicell Box, Built By Timken Aeronautic Transmissions, 280k Miles Strong!
2005 Cardinal Fiver - 36FT, 3 Slides, Mor/ryde, 13,500lbs.
NOSPARKPLUGZ is offline
post #7 of 11 (permalink) Old 08-10-2016, 09:21 PM Thread Starter
acade's Avatar
it surprisingly rides good going down the highway; real smooth and no steering wheel shake or wobble; I went with the BBs for balancing and I think that is way better than the weights, especially for tires soo big
8.5" Pro Comp lift
LuK clutch kit
Edge CS2 programmer
DeeZee tool box
acade is offline
post #8 of 11 (permalink) Old 08-18-2016, 07:27 AM Thread Starter
acade's Avatar
8.5" Pro Comp lift
LuK clutch kit
Edge CS2 programmer
DeeZee tool box
acade is offline
post #9 of 11 (permalink) Old 08-18-2016, 12:05 PM
Sharp. I like it.
8/28/04 --> '04 F350 CC PSD FX4 Lariat Shorty (truck born 06/09/04, engine build date 03/06/04) 149K miles, Torqshift 5 Spd Auto, 3.73 LS, FULLY loaded, Oxford white with medium flint leather.
7/7/15 - BPD EGR Cooler, new OEM oil cooler, ARP Head studs, SCTX4 with IDP Extreme X tune.
8/23/16 - 4" Pro Comp lift with Bilstein 5100s, Pro Comp dual steering stabilizer (with ProComp ProRunner shocks), 18x9 Fuel Coupler wheels, 35x12.50 Toyo Open Country RTs
Traded in 8/28/04 --> '01 F250 CC PSD 4x4 Shorty, SCMT 1705, AFE Magnum Force intake, Walker BTM, polished stainless steel nerf bars and Putco grille inserts, soon to be lifted? -> SHOULD'VE KEPT THIS TRUCK! :-(
NinjaRacer is offline
post #10 of 11 (permalink) Old 09-05-2016, 10:08 PM Thread Starter
acade's Avatar
I think the next thing I want to do is add some Amp Research steps; any recommendations yah or neh? $1300 for steps is expensive, but they definitely have the cool factor
I am also wanting to put a front bumper mount for the block heater plug and add an in-dash USB charging port; has anybody done either of these? I found a boat/marine male plug for the block heater and a dual USB charging port, both on eBay
8.5" Pro Comp lift
LuK clutch kit
Edge CS2 programmer
DeeZee tool box
acade is offline
post #11 of 11 (permalink) Old 05-13-2017, 10:35 AM Thread Starter
acade's Avatar
installed some LED front and rear turn signals; you can get a LED specific flasher relay at Auto Zone to stop the hyper flash; they look good IMO; still not sure what I want to do with the headlights
installed a block heater plug port in the bumper to help clean up the front end and make it easier access; it blends in and looks factory IMO
also have had my Amp Research Power steps installed for several months now, and that is probably the single best mod that I've done; at $1100 for a new set, it seems steep, but they are definitely worth it
8.5" Pro Comp lift
LuK clutch kit
Edge CS2 programmer
DeeZee tool box
acade is offline
  Diesel Forum - TheDieselStop.com > Other Topics > Wheels, Tires, Brakes, and Suspension
