285's on a stock (and heavy) '2001 F350 - Diesel Forum - TheDieselStop.com
Sponsored by Discount Tire
post #1 of 2 (permalink) Old 08-19-2018, 11:16 AM Thread Starter
HI All - my '01 F350 is about 12,000-13,000 lbs, depending on the day. It is SRW 4x4 extended cab long bed. All stock. I am running 265/75r16 goodyear wrangler tires with Kevlar. They have been ok, but I need to inflate them to 80 psi in order for the truck to not swim around on the road due to all the weight I carry. I am thinking about going to 285/75r16s - perhaps BFG All terrain KO2s, but am reading that while there should not be any rubbing issues, the tire manufactures recommend a 7.5" wide wheel for that size tire, while the stock wheels at 7".
However, many people run 285s on the stock 2001 wheels and have no issue. My question is, will I have any issues fully inflating 285s on a 7" rim? I am drawn to the 285s because they have a greater load rating than the 265s...but I predict that I will need to inflate them to max.
Please share any thoughts you may have. It sucks that they went with 16" wheels back then....make upgrades very limited w/o a bunch of modifications....
Thanks!
2001 F-350 Super Duty XLT Extended Cab - 7.3L Power Stroke - 4x4 - Auto Trans - SRW - Tow Package - 67,000 miles
Mr Blotto is offline
post #2 of 2 (permalink) Old 10-26-2018, 04:28 AM
Your GVW is 10K, why do you exceed by 20-30%?
Get a 450 or 550 if your going to load it like that, or a trailer.
Sure there is margin in the rating but you are entirely too far off the reservation.
Your going to hurt someone.
2000 350SD, Crew, SRW, 6 speed, custom bumpers, 4" exhaust, Bullydog, Spar Guages.
In possession 2018 450 Lariat Cab-Chassiss, Blue Jean, future 11' Aluminum custom Flatbed, DBL super single 335-80-20 488's 2 1/2" lift all around, electric locker in the front, Airlift bags, on board compressors Sulastics on their way when revision done, bumper TBD
*******SEVERE DUTY********
mcintoshjr is offline
  Diesel Forum - TheDieselStop.com > Other Topics > Wheels, Tires, Brakes, and Suspension
