Aftermarket Wheel Finishes - Diesel Forum - TheDieselStop.com
Forum sponsored by: Discount Tire
post #1 of 5 (permalink) Old 09-14-2015, 11:43 PM Thread Starter
My Photos: (9)
I'm looking for some aftermarket wheels for my 2013 F350, tuxedo black over pueblo gold.
I don't want all black wheels, but even black with milled accents have me worried about Midwest winters and salt destroying them. So, I've turned to PVD.
Does anyone make PVD wheels with black accents?
What do all of you do to keep your wheels from corroding in winter? I know that you should wax them, but really, will that protect them enough in winter? I can't figure waxing them once a month in winter when it's -20 outside.
Recommendations? Thoughts? Experiences? Thank you!
Smokewagun is offline
post #2 of 5 (permalink) Old 09-15-2015, 07:22 PM
Mongus's Avatar
POR 15 makes an awesome clear coat.
Mongus rigs;
1992 F-Superduty Dump truck 7.3 - Luk SMF 5spd 5:13 rears-Ricksons 19.5 wheels & tires-Banks get kits.
This is my work hoarse !
2000 F550 - Crew cab -Custom Hood
Harley Flamed Fenders & Doors.
4x4-7.3 - South Bend 6spd 4:88 rears. Loaded ! Volant intake
Hog Performance 4" SS exhaust
Banks wheel, turbine, exhaust brake-Ceramic coated
AFE Blade Runner Spyder
Strickley Diesel Return Fuel & Banjo Bolts
IH up pipes - ceramic coated
Powder coated everything.
Brake Performance-slotted & dimpled rotors with performance pads
DP Tuner 80 Tow
Coolant filter system
Evens Coolant
203 thermostat
Bullet Liner coated Dana 60 front end
2008 F-350 Harley Davidson Crew cab - long bed - 6.4 - Banks-Six gun-Air intake-IQ-Dual Exhaust
2004 Pace American 28' x 9' x 8' enclosed work trailer. 18k GVW. Tri axle - loaded
Custom Built Roll -Off dump trailer. 17yard box. Double dual axles. 20k GVW.
Fully decked 2003 Anni Fat Boy.
Rare "Reaper Tins"
Mongus is offline
post #3 of 5 (permalink) Old 09-15-2015, 11:27 PM Thread Starter
My Photos: (9)
So buy new wheels and then clear coat them? Sounds like an added expense better offset by a second set of wheels. For the cost to clear coat new wheels, a new set of rubber can be put on my factory wheels and drive them in the winter.
post #4 of 5 (permalink) Old 09-16-2015, 09:38 PM
Mongus's Avatar
You asked the question ,,,,,,,,,,,,,,,,,,,,
Mongus rigs;
DP Tuner 80 Tow
Evens Coolant
203 thermostat
Rare "Reaper Tins"
Mongus is offline
post #5 of 5 (permalink) Old 09-22-2015, 02:31 AM
klhansen's Avatar
My Photos: (180)
Yes they do. It's called Glisten PC. A lot harder than normal clearcoat.
I used it to restore the finish on some stock aluminum wheels that the factory coat had chipped on and had the typical white corrosion growing under the coating.
Nothing protects completely from chips. I suppose you could wash and wax them every day, but I for one don't have the inclination to do that. If you really want to keep your aftermarket wheels nice, hang them on the garage wall.
), AIS,
regulated return,
klhansen is offline
  Diesel Forum - TheDieselStop.com > Other Topics > Wheels, Tires, Brakes, and Suspension
