Airbags Installation VIDEO - Diesel Forum - TheDieselStop.com
Sponsored by Discount Tire
post #1 of 31 (permalink) Old 01-23-2011, 08:00 PM Thread Starter
Here's a video of my experience installing Firestone Ride Rites and an Air Lift wireless on-board compressor.
CURRENT: 17 F350 Platinum Ultimate
FORMER: 11 SD 6.7L CC SWB White Platinum Lariat Ultimate
2" Auto Spring leveling kit (required caster correction)
315/60/20 Toyo MT's
Line-X Bedliner/Door Seal Mod
DDM Tuning HI/Low HID's (H13, 55W, Color 5,000K)
Titan 50 gallon tank
EpicCowlick is offline
post #2 of 31 (permalink) Old 01-23-2011, 10:36 PM
Nthorseman's Avatar
Excellent video...where you at? I'm bringing my truck to you for this under 10 minute install...
Nthorseman is offline
post #3 of 31 (permalink) Old 01-24-2011, 07:21 AM Thread Starter
lol - maybe you could do it in 10 minutes if you had a 20 guy pit crew.
Salt Lake City, come on up!
315/60/20 Toyo MT's
post #4 of 31 (permalink) Old 01-24-2011, 09:14 AM
Were you a little nervous about drilling the frame?
Green_Shield is offline
post #5 of 31 (permalink) Old 01-24-2011, 11:01 AM
AJones's Avatar
Fun install isn't it?
I also installed the Ride Rite Wireless Air Command 2489 dual system a few months ago.
I have included T-valve on both sides to allow for manual fill and checking with the manual valve stems at the rear bumper. I am finding that handheld air pressure gauges do not match the pressure readings from the remote control unit readout. Both sides seem to be off by roughly the same amount. I have tried several hand held gauges to be sure. When the wireless meter shows 10Lbs the actual pressure is slightly more than double at 25Lbs. Any troubleshooting suggestions would be appreciated! I have contacted Firestone a couple of times through their website tech support with no response...
2011
F350 CC DRW 4x4 Lariat
AJones is offline
post #6 of 31 (permalink) Old 01-24-2011, 11:30 AM
dsroka80504's Avatar
I don't have any experience with Airbags so really don't know much about it. I purchased a new toy hauler last week that will have wuite a bit more hitch weight than my last 5er. I am guessing hitch weight to be around 2500, up 1000 from my cougar. I get that they make the truck squat less, but what are the other benefits? My Road Warrior has the EZ suspension on it which is supposed to ride a lot better. Any advice would be great.
2011 F350, CC, SB, Lariat Ultimate, Chrome Package, 4x4, FX4, White Platinum, 6.7L (SOLD)
2001 F-250 CC Lariat, LB, 4x4. 205K and Traded in
1996 F-250 XLT Regular Cab, 4x4, 187K. Bartered for construction work.
2010 Cougar 32RLB 5th Wheel - Traded in 1/22/11
2011 Road Warrior 30C Titanium Edition (SOLD)
dsroka80504 is offline
post #7 of 31 (permalink) Old 01-24-2011, 02:31 PM
Nthorseman's Avatar
The air bags will eliminate the squat. They will also allow you to drive on oblivious to the fact that you have a blown rear spring shackle that is now trying to come up through the box...happened to me one day, kept hearing a thump, could'nt make out anything on inspection on the highway, drove fine, got home and there's a small hole in the bed that looks like it's trying to get bigger.
So it's worth the 10 minute install by EpicCowlick...I hear he uses a 20 man crew...
post #8 of 31 (permalink) Old 01-24-2011, 06:15 PM Thread Starter
No, drilling the frame may sound scary, but it's no big deal. Talk to an engineer about the ability to put holes in the center of the vertical portion of a horizontally loaded structural member. It would have to be about 2 inches in diameter before it mattered.
I didn't put the T in so I have no way to verify the actual pressure in the bags. But I don't think it matters anyway. At the end of the day, I really don't care what the pressure actually is, just that it levels the load and helps stabilize the ride. So any discrepancy in hand-checked vs. digital readings is a non-issue for me. I'm using the Air Lift compressor and not the Firestone so we can't compare that way.
I mentioned my thoughts on another forum so forgive me if I am duplicating. There were two things that I expected from the airbag system: level the load, and increase the load capacity of the rear end. I clearly accomplished both of those objectives. What I didn't expect was the added benefit of smoothing out the ride A LOT. My trailer was pushing (bucking/jerking) the truck quite a bit before the bags and that has all but disappeared with the air bags. I was actually looking at some type of shock absorbing system on the hitch but it's no longer necessary. The air bags have really smoothed out the bucking. My Next Level toy hauler has a similar advanced suspension on the three axles as well. It has four shock absorbers on two of the axles.
Be aware that I only have about 80 miles on the airbag setup so my opinion is only from a newbie's perspective. Take that for what it's worth.
315/60/20 Toyo MT's
post #9 of 31 (permalink) Old 01-25-2011, 04:25 PM
AJones's Avatar
I would agree that knowing the pressure isnít critical especially for raising or stabilizing the load. Itís when empty that Iíd like to be able to set it 5 Lbs. and forget it. Unfortunately when I set the remote to 5 (lowest remote will allow) the bags really have 15 on one side and slightly more on the other. Thus I have to manually air them down to the prescribed min so I donít get too much bouncy. Other than that minor inconvenience, I like them!
2011
AJones is offline
post #10 of 31 (permalink) Old 01-25-2011, 05:26 PM
doczenith1's Avatar
My Photos: (11)
I am a structural engineer and I approve of this message.
On a serious note, the vertical portion is what we call the web of the member. The web resist the shear forces in the member which are highest near the supports of the member.
Al Bedford, P.E.
2011 F350 Lariat, SC, SWB, 6.7L, 4x4, 3.55ELD, FX4, Lariat Int Pkg, 20's
SOLD
2003 Mustang SVT Cobra, black convertible. - 6/2007 - 9/2013
SOLD: 2002 F250 Lariat, V10, 4x4, auto, 3.73LS, SC/SB, camper & off-road pkg. 12/2001 - 12/2010
With spreadsheet open click File then Download if you would like a copy of the spreadsheet.
doczenith1 is offline
post #11 of 31 (permalink) Old 01-26-2011, 07:34 AM Thread Starter
Nice to hear from someone with actual credibility on the matter! lol
315/60/20 Toyo MT's
post #12 of 31 (permalink) Old 04-20-2011, 05:08 PM
EpicCowlick,
Just watched your video on installation of Firestone 2535 air bag kit. ( Great Job, Big Help)
Did you have an issue with the brake line on the passenger side? looked at my truck and it looks to me like the brake line would be in the way for the axle strap of the lower bracket.
Thank You Sir
2015 F-350 drw, diesel, 4X4, lariet
Cessna is offline
post #13 of 31 (permalink) Old 04-20-2011, 07:47 PM
rocman's Avatar
My install was a lot easier. All I did was swipe a plastic card through 2 slots and it magically got done without any effort on my part.
rocman is offline
post #14 of 31 (permalink) Old 04-20-2011, 10:37 PM
Adjust your low pressure switch. Should explain how to do that in the manual. I had to do this on my last truck with air bags. Then you never have to worry about it again and it will be at 5lbs.
kereams is offline
post #15 of 31 (permalink) Old 04-21-2011, 07:40 AM Thread Starter
Originally Posted by Cessna View Post
EpicCowlick,
Thank You Sir
Hey Cessna,
No, I didn't have any conflicts with the brake lines. You do have to work around them but everything fit in just fine. If there is a problem, I bet you could loosen the brake lines a bit and move them around as necessary.
Epic
315/60/20 Toyo MT's
  Diesel Forum - TheDieselStop.com > Other Topics > Wheels, Tires, Brakes, and Suspension
