Airbags Installation VIDEO - Page 2 - Diesel Forum - TheDieselStop.com
Sponsored by Discount Tire
post #16 of 31 (permalink) Old 04-21-2011, 07:46 AM Thread Starter
Originally Posted by rocman View Post
My install was a lot easier. All I did was swipe a plastic card through 2 slots and it magically got done without any effort on my part.
lol - what was that old American Express commerical? The one with the guy swinging in a hammock in the back yard with a glass of lemonade and a satisfied look on his face as he surveys his beautifully landscaped back yard...
The announcer says, "There's only one thing more satisfying than enjoying the results of a long hard day of weed pulling and lawn trimming, and that's knowing that you paid Manuel to do it..." love that
CURRENT: 17 F350 Platinum Ultimate
FORMER: 11 SD 6.7L CC SWB White Platinum Lariat Ultimate
2" Auto Spring leveling kit (required caster correction)
315/60/20 Toyo MT's
Line-X Bedliner/Door Seal Mod
DDM Tuning HI/Low HID's (H13, 55W, Color 5,000K)
Titan 50 gallon tank
EpicCowlick is offline
post #17 of 31 (permalink) Old 10-08-2011, 05:54 PM
Well, I just ATTEMPTED to install the Airlift Loadlifter 5000 onto my 2011 F350 6.7. What a disaster. The kit (57396) is a POS in my opinion. The quality of the bags themselves are awesome, but the way they mount/install is ridiculous, and in my opinion, impossible.
  1. On the drivers side, the top bracket is darn near impossible to install due to the wiring harnesses, the mount for the DEF tank and some other lines.
  2. On the passenger side, there's no way to tighten one of the bolts that attaches the top of the airbag to the top side bracket.
  3. Per the instructions, you have to literally bang off a large piece of the bottom mounts with a hammer. The instructions say you may have to use a grinder to cut it off (which I had to do on both lower mounts).
  4. The instructions just plain suck, bigtime.
After I ran into issue #2 above, I said screw this and backed everything out and returned the truck to factory. I'll be returning this kit through amazon and ordering the Riderite kit.
I went with the Airlift kit because the bags look to be a lot better quality than the Riderite bags. And I figured since I was going to use the Airlift 72000 Wireless kit, I might as well keep it all in the family so to speak, one throat to choke, etc, etc. But man, extremely poor design of the mounting mechanisims with the Airlift bag kit.
So fair warning if anyone is considering going with an all Airlift system. I'd very strongly recommend going with the combo of Airlift Wireless 72000 and the Riderite bag kit, like Epic did.
Now patiently waiting on my Riderite bag kit....
ds53652 is offline
post #18 of 31 (permalink) Old 10-08-2011, 06:01 PM
Epic,
In your video, where you're installing the airbags themselves, you really only show the passenger side being installed. Question for you, how difficult was the drivers side with all the wiring harnesses, mount for the DEF tank and those other lines that run the inside of the frame?
Thanks, DS
ds53652 is offline
post #19 of 31 (permalink) Old 10-09-2011, 07:41 AM Thread Starter
Originally Posted by ds53652 View Post
Epic,
Thanks, DS
The only problem I had was due to the fact that I had the B&W hitch already installed. I had to loosen but not remove the driver's side plate to allow the airbag bracket bolt through the frame. There were no conflicts with hoses and other stuff on the truck. The most confusing part was in setting the Firestone bracket height. I had to set them on the highest hole which the instructions specifically said NOT to do. There was no other way to do it without cutting or burning off the bump stop tongue that is in the way. Bottom line is after a summer of pulling a very heavy fifth wheel, the brackets are pristine and working great.
315/60/20 Toyo MT's
post #20 of 31 (permalink) Old 10-10-2011, 09:39 AM
I'm on the second hole from the top on that bracket for my Firestone airbags and I have the same truck. No cutting or grinding here at all. The only irritant about the installation was that bolt by the def tank but my wifes small arms and hands solved that. The rest of the installation was a breeze.
kereams is offline
post #21 of 31 (permalink) Old 10-10-2011, 03:31 PM
FYI guys. I just spoke to Firestone. Even though their website says use kit 2071 for 2011 F250/350 for diesels without an in-bed hitch, they are now saying use kit 2535 instead (even though the site says 2535 is for same truck but with an in-bed hitch).
ds53652 is offline
post #22 of 31 (permalink) Old 10-10-2011, 04:26 PM
klhansen's Avatar
My Photos: (180)
Very nice video.
I think it deserves being stickied to the top of the forum.
), AIS,
regulated return,
klhansen is offline
post #23 of 31 (permalink) Old 10-10-2011, 06:14 PM
Great video.
skew12 is offline
post #24 of 31 (permalink) Old 10-11-2011, 12:15 AM
My kit was the 2535, guess that explains why I dis not see the issues you did.
kereams is offline
post #25 of 31 (permalink) Old 10-18-2011, 06:32 AM
+1 on the issues with the Airlift install. I ended up sending my Airlift bags back and installed the Ride-Rite. The install was very smooth. The 72000 wireless is awesome!
John
2011 Ford F-350 DRW Lariat Crew Cab 4x4 (8' Bed 3.73, Oxford White, Pale Adobe Accent, 6.7L, 10K GVWR, Lariat Ultimate Package, Tailgate Step, Universal Garage Door Opener, Upfitter switches, Navigation, Preferred Equipment Package)
Born: 6/15/2010 - Cost At Birth: $59,540 - Purchased: 7/17/2010
Mods: Added Engine Block Heater, LineX, Firestone Rear Airbags, Air Lift Wireless Compressor, LockPick, Added UpFitter Switches, Bed Lights, Torza Top Tri-Fold, Ultimate-EDP Alarm, Door Seal Mod., Rancho RS98510 Steering Stabilizer Kit, Bilstein 4600 HD Shocks.
John Hagen is offline
post #26 of 31 (permalink) Old 11-14-2011, 08:14 AM
After some extensive thought and research on my own, I called Brad at AirLift. We discussed my concerns and I was informed that there were some design changes in the 57396 kit as well as the 72000 wireless kit. After more discussion I was invited to stop by at my convenience. I did so the following week and was given a tour of the facilities. I learned that most, if not all of the components in all of their products are made in the USA, which is a plus as far as I'm concerned.
During my visit I spoke to their engineer on this system and learned what some of the improvements in the kits were. The brackets in the 57396 kit have been redesigned so it is not necessary to remove the welded on piece of the lower brackets, and I believe the left upper bracket has also undergone some modification.
The 72000 wireless kit has also undergone some design changes. There is no longer a need to join the controller, as it has been joined during production. Additionally, there is only one wire (14ga. I believe) that needs to be run to the front of the vehicle. This wire runs to a key on source in the power distribution box and is fused with a 15A spade type fuse. The wire that runs to the battery has been eliminated.
This information along with the $100 rebate and the fact that this is a Michigan company helped me greatly in my decision to purchase these kits. The best deal that I found was online at Advance Auto. They had pretty much the same prices as other online sellers with a 15% discount and a $50 rebate
More to follow on the installation.
Regards,
BH
Bounty_Hunter is offline
post #27 of 31 (permalink) Old 11-14-2011, 08:15 AM
After some thought I decided to have the install done. I did some searching for someone who had some experience installing the AirLift kits. I found someone who, although it was not their main focus, had more than the necessary experience, who agreed to do the install. I was allowed in the shop to monitor the install, which incidentally took about 3.5 hours including both kits (57396 and 72000).
One of the first things I noticed that may present problems, was the orientation of the bags on the lower brackets. There are various options, but on this application the bags mount toward the rear of the newly designed brackets. This kit is a relatively snug fit, and there is only enough room for them to fit this way. The upper brackets went in without a problem. Once the lower brackets and bags were properly oriented, they also fit as designed. There was no need to modify the brake lines. The left side slid between the lines and the axle and the right side slid over the lines. Care needs to be taken when tightening the long bolts to the lower axle housing bracket to avoid the brake and ABS line. One thing I noticed is that is imperative is to tighten the brackets in the order that is described in the instructions. There was no real problem getting to any of the bolts on this install. The whole install was done with common hand tools, with the exception of a cordless drill and a 3/8 impact (only used to run down the nylock nuts on the long carriage bolts). All of the fasteners were tightened by hand.
The wireless 72000 kit was mounted above the spare tire mount as others have described. This kit has also been updated. There is no longer any need to Join the controller with the manifold, as it has been done in production. The connection direct to the battery has been eliminated. There is only one wire (14ga.) that needs to be connected to a key on source. This was connected to the same point as others have pointed out in the power distribution box under the hood on the left side of the engine compartment. The intake for the compressor was routed along with the wire to a spot under the hood where it should remain dry.
The whole install went very smooth and took only about 3.5 hours from about 8:30 untill noon. So far all that I have done is play with some of the settings. I havent had an occasion yet to try it out under a load, but I willl keep everyone posted.
Regards,
BH
post #28 of 31 (permalink) Old 11-15-2011, 08:12 AM Thread Starter
Hey BH. Great write-up. That would have been neat to go to the factory and talk to those folks. It sounds like several of the issues with the bags have been resolved including elimination of the 1.5 amp barrel fuse. It's great that they have only a single line running to the fuse box instead of two (I wondered why they didn't do that in the first place)! I got a good look at my buddy's install and it looks like it's good quality and should last the life of the truck. He likes them but hated the installation. I told him he'd get over that soon.
So far my Firestone's are working great but I absolutely love the AirLift 72000 system.
315/60/20 Toyo MT's
post #29 of 31 (permalink) Old 03-21-2013, 10:11 PM
DKR
DKR's Avatar
I have a new 2012 F250 with about a 800lb box in the bed that can weigh up to 1500lbs. I had this in a 2009 F250 with Firestone RideRite air bags.
I went down the other day and bought the Airlift system for it (rebate) and I ended up taking it back this morning. The largest challenge was that at current ride height which was a little over an inch lower than stock the air bag was completely compressed. I actually had to raise the truck to just get the bag in. I returned them due to the fact that I would only have about an inch of down travel with the Airlift system installed.
I called and spoke to the folks at Airlift this morning and they said this was normal. I just did not feel comfortable with this.
DKR is offline
post #30 of 31 (permalink) Old 07-07-2013, 04:38 PM
So maybe I. Missed it some where but where did you get the power from exactly in the fuse box? Is there a owner connect acc power source under the hood?
2011- F350 6.7l Lariat, Tuxedo Black, factory tonneau cover, rear bumper step, Compustar pro remote start, window visors, duraflap mud flaps, spray in box liner, Fox 2.0 IFP shocks, tinted windows, sub relocated to center console, lock pick, RideRite Load Lifter ultimate air bags, RideRite wireless air compressor
In the works
Projector retrofit
FX-R projector
Morimoto 3Five ballast
Morimoto 3Five 5000K bulb
Gatling gun shroud
billet grill
Traded-2003 F350 6.0L Centennial Edition fully loaded except FX4 package.
cdooguy is offline
  Diesel Forum - TheDieselStop.com > Other Topics > Wheels, Tires, Brakes, and Suspension
