Best Rotors for '2001 F250 - Diesel Forum - TheDieselStop.com
Sponsored by Discount Tire
 1Likes
post #1 of 21 (permalink) Old 07-14-2018, 04:37 PM Thread Starter
What rotors do ya'll recommend for an 01 F250 7.3? Getting some brake wobble so I think its about time to get things moving. Thanks!
2001 F-250 XLT 4x4 7.3; 146,000 miles; 4R100
optimusprime is offline
post #2 of 21 (permalink) Old 07-28-2018, 05:43 PM Thread Starter
Anyone?
post #3 of 21 (permalink) Old 07-28-2018, 06:59 PM
jleedog's Avatar
Cant you have the ones you have turned and use them instead of buying new?
2002 F250 Super Duty Crew Cab 7.3L Lariat 2WD 131,000mi; 4in turbo back custom exhaust, Garrett GTP38R turbo, Riffraff intercooler boots, Dorman Up-Pipes, Ford Severe Duty AIS, 31 row 6.0 transmission cooler, Scangauge II, ISSPRO EV2 Boost-EGT-Trans temp Gauges, DP T-5 Tuner (stock ,60HP tow, Decel, 60HP highway econo, 80HP city econo), Dieselsite coolant filtration, Max Air A/C mod, foglight mod, AIH delete, LED interior, back up camera, hid foglights.
I have AE if you are in San Diego area and need help. Send PM
jleedog is offline
post #4 of 21 (permalink) Old 07-28-2018, 08:47 PM
79jasper's Avatar
Yeah, but say for example oriellys, most done even know how to use the machine.
Hell, my local one cant even build a simple damn fuel line for me.
Sent from my SM-G892A using Tapatalk
79jasper is online now
post #5 of 21 (permalink) Old 08-06-2018, 12:18 PM
My brother swears by these cryogenically treated rotors and this will be the next set I use. I put a set of oem rotors and new bearings when I did my front brakes two years and 15,000 miles ago. Warped again. Next job I do, I will use these.
High Performance Brake Pads and Brake Rotors - Frozen Rotors
tretpflyr is offline
post #6 of 21 (permalink) Old 08-06-2018, 03:43 PM
79jasper's Avatar
What pads did you use?
Sent from my SAMSUNG-SM-G920A using Tapatalk
post #7 of 21 (permalink) Old 08-11-2018, 07:52 AM
I've had good luck with cryoed and slotted rotors.
2000 Excursion 7.3L Diesel 4x4, BTS Tranny, AFE intake,Stage1 Single Shot Injectors , GTP38R turbo, EBV delete, 6 position TS chip, Adrenaline HPOP
kcastle is offline
post #8 of 21 (permalink) Old 08-11-2018, 07:58 AM
ArcticDriver's Avatar
I recall a negative issue concerning the slotted rotors.
SOLD:
ArcticDriver is offline
post #9 of 21 (permalink) Old 08-11-2018, 09:53 AM
I've heard the same negative about drilled rotors, or drilled and slotted rotors. I have not experienced negatives with slotted rotors. I had about 100K on a set of Cryo'ed power slot rotors on all 4 corners. Powerslot Part Number: 126.65086CSL-CSR
The last set I got for my Excursion were possibly Power Stop brand, but looks identical.
kcastle is offline
post #10 of 21 (permalink) Old 08-11-2018, 01:32 PM
klhansen's Avatar
My Photos: (180)
Ford does not recommend turning rotors, and neither does Jack (FMTRVT), TDS's resident brake expert.
If you're getting brake pulsation, it means there's probably hard spots which can't be turned out. They come back soon after any attempt at turning.
When I redid my rear brakes, I went with Ford Rotors (which happened to say "Made in China" on the boxes) but they're doing well. On the rears, I went with Ford Loaded calipers. I recently replaced the front pads with Ford "SuperDuty". My front rotors were in good shape with minor scoring and I just reused them without turning.
On slotted and/or drilled rotors, you're losing contact area. It's equivalent to putting smaller pads on.
), AIS,
regulated return,
klhansen is offline
post #11 of 21 (permalink) Old 08-11-2018, 01:40 PM
79jasper's Avatar
It seems about 90% of the threads with drilled and slotted rotors, they all are cracked and warped.
post #12 of 21 (permalink) Old 08-11-2018, 08:33 PM
I had the slotted and cryro rotors on one of my trucks. They worked great!! and I never had a issue with them. For the price and hassle of trying to get them turned I usually buy NAPA best or Ford rotors.
DENNY
1999 F350 AUTO 4x4 CC LB DRW 4.10
DENNY is online now
post #13 of 21 (permalink) Old 12-30-2018, 01:21 PM Thread Starter
What pads do you all recommend? Are the ones from NAPA any good?
post #14 of 21 (permalink) Old 12-30-2018, 02:09 PM
I have had good luck with the NAPA premium ones or Ford OEM.
DENNY
DENNY is online now
post #15 of 21 (permalink) Old 12-30-2018, 02:12 PM
I never reuse the calipers. I used to back in the day but had an issue with the puck sticking after being pushed back in and burning up pads and calipers. I always replace the calipers with new or rebuilt, make the job simple and you get a good brake fluid flush at the same time.
DENNY
DENNY is online now
  Diesel Forum - TheDieselStop.com > Other Topics > Wheels, Tires, Brakes, and Suspension
