Best Rotors for '2001 F250 - Page 2 - Diesel Forum - TheDieselStop.com
Sponsored by Discount Tire
 1Likes
post #16 of 21 (permalink) Old 12-30-2018, 02:46 PM
I went with raybestos rotors, pads, and calipers from rockauto.com the last time I did my brakes, and they are working great. No problems. The motorcraft, powerstop cryoed, drilled, and slotted, and a few others are there on the rock auto site also.
2001 F350 XLT 4X4 crew cab, dual rear wheels, long bed, black, 7.3l turbo diesel, automatic transmission, 4.10, shift on the fly, running boards, sliding rear window, 38 gal fuel tank, Odyssey extreme 65-PC1750T batteries, Michelin LTX-MS2 rear tires, Sumitomo Encounter front tires, Shell Rotella Ultra elc, 11,500 gvwr, 20,000 gcwr, 7500 gvw, completely stock, 114,000 miles when purchased, now has 240,000 miles, repairs so far: two starters, batteries, cps, brakes, tires, alternator, ball joints, locking hub, wheel hub, AC compressor, serpentine belt, power steering pump, driver's side window, ignition switch, o-ring, Spectra premium radiator, water pump, fan clutch, fan blades, thermostat, thermostat housing, tensioner. Stolen twice so far, but recovered both times with major damage.
DonWarkentin is offline
post #17 of 21 (permalink) Old 12-30-2018, 03:05 PM Thread Starter
Originally Posted by DENNY View Post
I never reuse the calipers. I used to back in the day but had an issue with the puck sticking after being pushed back in and burning up pads and calipers. I always replace the calipers with new or rebuilt, make the job simple and you get a good brake fluid flush at the same time.
DENNY
So do you change out the calipers each time you do pads? What calipers do you recommend?
2001 F-250 XLT 4x4 7.3; 146,000 miles; 4R100
optimusprime is offline
post #18 of 21 (permalink) Old 12-30-2018, 05:21 PM Thread Starter
Originally Posted by klhansen View Post
Ford does not recommend turning rotors, and neither does Jack (FMTRVT), TDS's resident brake expert.
If you're getting brake pulsation, it means there's probably hard spots which can't be turned out. They come back soon after any attempt at turning.
When I redid my rear brakes, I went with Ford Rotors (which happened to say "Made in China" on the boxes) but they're doing well. On the rears, I went with Ford Loaded calipers. I recently replaced the front pads with Ford "SuperDuty". My front rotors were in good shape with minor scoring and I just reused them without turning.
On slotted and/or drilled rotors, you're losing contact area. It's equivalent to putting smaller pads on.
Do you happen to know a part number for the Loaded calipers? When I google Motorcraft loaded caliper, the results come back rather ambiguous. Also, pardon my ignorance, but what is the difference between a loaded and unloaded or semi loaded caliper?
post #19 of 21 (permalink) Old 12-30-2018, 05:37 PM
ArcticDriver's Avatar
Optimus.
I would contact a Fords Parts Counter directly for the details and P/N for your specific truck.
optimusprime likes this.
SOLD:
ArcticDriver is online now
post #20 of 21 (permalink) Old 12-30-2018, 09:11 PM
klhansen's Avatar
My Photos: (180)
I found them on Fordparts.com when I did my rear brakes. But that site is not so good anymore. I would suggest contacting the guys at Autonation Ford White Bear Lake (https://parts.autonationfordwhitebearlake.com/), and give them your VIN. There are different setups. Mine took the same rear caliper on both sides, but later trucks used different calipers (location of the bleeder is important - needs to be on top.)
As far as I know, there only loaded calipers (complete with pads, ready to bolt on) and unloaded calipers (without pads). No ideal what semi-loaded would be (maybe with one pad ? )
), AIS,
regulated return,
klhansen is offline
post #21 of 21 (permalink) Old 12-30-2018, 09:15 PM
Yes, I usually go with NAPA. If I remember right I have gotten some from Ford also.
DENNY
1999 F350 AUTO 4x4 CC LB DRW 4.10
DENNY is offline
  Diesel Forum - TheDieselStop.com > Other Topics > Wheels, Tires, Brakes, and Suspension
