Brake Problem - Vacuum pump - how to test? - Diesel Forum - TheDieselStop.com
Forum sponsored by: Discount Tire
post #1 of 15 (permalink) Old 05-21-2007, 11:23 AM Thread Starter
My brakes are not working @ low rpm's and I want to test the vacuum pump. Just want to know how, also it might be the power booster and I would like to know how to test if there is a vacuum leak in that.
'97 F350 Crew Cab, 4x4
bhansen is offline
post #2 of 15 (permalink) Old 05-21-2007, 12:57 PM
STurbo90's Avatar
My Photos: (9)
Re: Brake Problem - Vacuum pump - how to test?
Hook up a vacumn gauge on the manifold on the drivers fender, should be about 20 in.
Is your "Brake" light coming on? usually happens when a pump is weak.
PSD,CC,LB,E4OD,4WDw4:10LS
STurbo90 is offline
post #3 of 15 (permalink) Old 05-21-2007, 04:22 PM Thread Starter
Yes the light is going on, should I just replace the pump?
bhansen is offline
post #4 of 15 (permalink) Old 05-21-2007, 06:33 PM
realbadlarry's Avatar
No,do a search and do the hydroboost conversion..$264.00 from autozone for the hoses and booster. Better brakes for another $150.00
95 CCLB 4X4, DP, TYMAR, Adeneline HPOP, 5POS CHIP, 4",3 GUAGE POD, 129k, 265/75/16 bfg E, E4OD,4.10s,Putnams hitches front and rear,Air bags rear.Banks IC
realbadlarry is offline
post #5 of 15 (permalink) Old 05-21-2007, 06:54 PM
How are you guys swapping pullies from the old pumps to the new ones? Are you using a pulley puller then a hydraulic press to press the pulley on the new pump?
95MNPSD is offline
post #6 of 15 (permalink) Old 05-21-2007, 06:57 PM
It is easiest to get the puller set,,,maybe autozone?....
Rick.....
97 F 350 ...Lucky 13
"Most stuff's just stuck & needs hittin with a hammer .Supporter/End user of ShiftSolutions THE CURE E4/4R Trans Control. Helping Cancer patients and families
Special thanks to RacerX USA
action4478 is offline
post #7 of 15 (permalink) Old 05-21-2007, 09:47 PM
I used 2 pry bars in the bench vise. and a deadblow mallet. tried using a puller but none were small enough to grab the hub in the center and i didnt want to bend it from grabbing the outside edge.
97 F-350, 3" 2 piece downpipe, open air intake, 6 pos. chip from black cloud diesel.com, 4 in. straightpipe exhuast.
NOW WITH 2'nd rebuilt tranny in 3000 miles.
+new vac pump both at 245'000 new starter at 249'000
have since crossed the 250'000 mark , 253 and still gettin up.
Since killed by a red light running durango.
weponhead is offline
post #8 of 15 (permalink) Old 05-22-2007, 11:22 AM
Is this a three jaw puller set? How are you pressing the pulley onto the new pump? I don't want to ruin the pulley or my new pump. Thanks.
95MNPSD is offline
post #9 of 15 (permalink) Old 05-22-2007, 07:07 PM
It's a puller made especially for the pump, It also fits water pumps on cars, power steering pumps, ect...
It comes with the nessesary tool to press it back on...
Well worth having...
Rick.....
post #10 of 15 (permalink) Old 05-22-2007, 07:23 PM
The pump's shaft is tapped, 3/8-16unc. Using washers and a 3/8 bolt, press on the pulley. When the bolt bottoms out, stack up more washers or go to a shorter bolt. Dont forget to drop in that pump mounting bolt before you press on the pulley.
Randy
2005 F-250 King Ranch * 4X4 * 4" exhaust / 5" tip * Let the mods begin......
1994 F-250 Super Cab * 4x4 * ZF-5 * 3:55 * RDS Single Shot Stage I's* TDP 6pos chip * BDP electric fuel * BDP D-66 Turbo * IDM Mod * Hypermax 3x4" dp * Authentic Tymar intake* 7.3 Intercooler * gutted ebpv * 4" exhaust & 5" tip * LUK clutch * A-pillar pod w/ Auto Meter NV boost, pyro and water temp gauges * reverse dash lighting and hvac controls * Optima yellow top batts D75/25, both on the right side * HPO X-over mod * manually controlled gp's * cruise control mod * add-a-leaf (front) * AC mod
94strokerace is offline
post #11 of 15 (permalink) Old 05-22-2007, 07:45 PM
I used to use a longer bolt with a nut threaded on it, tighten the nut against the washers until the pulley is seated .... works great in a pinch...
Rick.....
post #12 of 15 (permalink) Old 05-23-2007, 12:03 AM
I have the same problem. Replaced the pump and it helped a little, but the brakes are still not great. I am now thinking the booster is bad or maybe a vacuum leak?
95 x-cab 4x4 AT LWB bone stock
robbiesdad is offline
post #13 of 15 (permalink) Old 05-23-2007, 12:06 AM
I got my hydroboost stuff today. I'll let you know how much better it works once I'm done.
post #14 of 15 (permalink) Old 05-23-2007, 01:31 PM
I haven't gotten around to researching further but when my last vacuum pump went out there were metal shavings all around the pump and on the hose. Since replacing I have an occassional hissing on first start up that goes away after hitting the brakes. My climate control also acts up when going from vent/heat/defrost/ac etc. Both problems began immediately after the failure. I'm wondering if I got metal shavings in the vacuum hoses somehow. Just a theory and maybe a very poor one but figured I'd toss it out.
'94 F350 4x4 PowerStroke, 5-speed, 4.10 gears, crew cab, XLT, Luk Clutch, ZF-47, Hydroboost, AIC, Max A/C Assist, 95.5 radiator and degas bottle 318,000 miles
'96 F350 4x4 PowerStroke, auto, 4.10 gears, crew cab, XLT, DRW conversion, AIC, 502,000 miles
'02 F350 4x4 PowerStroke, 6-speed, 3.73 gears, crew cab, XLT, DRW, AIC, 223,000 miles
Diesel_Aggie is offline
post #15 of 15 (permalink) Old 05-15-2017, 04:07 PM
i got about 17 in Hg coming straight from the pump does that sound like i need a new pump?
Natefinn is offline
  Diesel Forum - TheDieselStop.com > Other Topics > Wheels, Tires, Brakes, and Suspension
