Brakes are grabbing, pulsating - Page 2 - Diesel Forum - TheDieselStop.com
Forum sponsored by: Discount Tire
 1Likes
post #16 of 17 (permalink) Old 03-10-2019, 09:06 PM Thread Starter
Removed fuses 6 & 9 from the fuse panel under the hood. Both for the ABS system. Did trigger an ABS light but the problem remains. Back to the drawing board.
Capt Skup is offline
post #17 of 17 (permalink) Old 03-11-2019, 01:20 AM
ArcticDriver's Avatar
If you are trying to replace the fluid then the Mobil-1 works best. I tried Valvoline Synthetic ATF in the red jug and it made noise so flushed & re-filled with M1 and no more pump noise.
You can raise the front wheels on jackstands and remove the return line at the reservoir. There is a DIY available with a photo.
Clip that hose to a container and the old fluid will be pushed out by force as you SLOWLY turn the wheels left and right. Slowly or it creates air bubbles. Ofcourse, keeping an eye on the reservoir and filling with fresh ATF to keep it from running dry.
NOS Black CPS. ScanGauge-II. Bilstein 5100. Stancor GPR. Walker BTM. Noco Mod. Michelin Defender LTX 285/75/16.
SOLD:
ArcticDriver is offline
  Diesel Forum - TheDieselStop.com > Other Topics > Wheels, Tires, Brakes, and Suspension
Similar Threads
Interchangeable Axle Tag ID differences Relentless007 Other Technical Questions 1 12-09-2016 11:50 PM
Help with hard brakes hoobaleenyo Wheels, Tires, Brakes, and Suspension 4 09-24-2016 04:23 PM
warped rotors again... arrrrg!!! stumpinator Wheels, Tires, Brakes, and Suspension 21 11-09-2014 07:28 AM
2006 chevy 2500 rear brakes question lari2001 Other Technical Questions 6 08-21-2007 04:01 PM
Brakes - sink to the floor - no stop! redbrand 1999-2007 Gas Engines 4 12-03-2003 09:12 AM
