Calipers and Brake System - Page 2 - Diesel Forum - TheDieselStop.com
Forum sponsored by: Discount Tire
post #16 of 30 (permalink) Old 07-19-2019, 04:02 PM Thread Starter
Big Horn's Avatar
Thank you!!! Got the axles out. Not a lot of room to work with a pry bar......started first with a porta power spreader, between knuckle and u-joint—side to side. Moved it out far enough to get a prybar between axle tube and old seal (see picture) and then popped them out.
The needle bearing polished surfaces on axles look good as well as those that go into the differential. The u-joints have no play in them and have grease zirks so I’m going to leave them alone.
Anyone know if greasable u-joints were installed by Ford or has someone likely already replaced them?
Also I’m going to make a seal installer instead of buying one— when using seal installer to seat the axle and seal all the way into the knuckle is there a positive stop you can feel where you know it’s in far enough for the groove and split ring Thanks!
2002 F350 7.3L / 4R100 - 4WD CC DRW 8 Box, AIH Delete, Gauges- Pyro, Trans Temp, Boost, Fuel Pressure, TS-6 tuner, Zoodad Mod, Mishimoto 31 row Trans cooler, Mobil 1 ATF, Trans return line ATF filter, Hutch/Harpoon Mod, Air Lift Load Lifter 5000 rear air springs, Rancho 9000 shocks, Timbrens on the front.
Big Horn is offline
post #17 of 30 (permalink) Old 07-21-2019, 09:15 AM
ArcticDriver's Avatar
Big Horn,
I think Ford u-joints lacked zerks for that era.
SOLD:
ArcticDriver is offline
post #18 of 30 (permalink) Old 07-21-2019, 10:38 AM
Steve83's Avatar
Beginning around 1990...
(phone app link)
Steve83 is online now
post #19 of 30 (permalink) Old 07-21-2019, 12:46 PM Thread Starter
Big Horn's Avatar
(phone app link)
Definitely something to consider—no more than I will use my 4WD new sealed u-joints would probably last me the rest of my (trucks) life. Besides, now I know how to take the front hubs apart- Lol
Thanks Steve83
Big Horn is offline
post #20 of 30 (permalink) Old 07-21-2019, 12:50 PM Thread Starter
Big Horn's Avatar
Also-After reading a little more, I opted to buy the seating tool—as the directions say the tool is made to seat axle and hub seal to the correct depth.
Big Horn is offline
post #21 of 30 (permalink) Old 07-21-2019, 12:52 PM Thread Starter
Big Horn's Avatar
Originally Posted by ArcticDriver View Post
Big Horn,
Big Horn is offline
post #22 of 30 (permalink) Old 07-21-2019, 02:13 PM
Steve83's Avatar
Originally Posted by Big Horn View Post
...no more than I will use my 4WD new sealed u-joints would probably last me the rest of my (trucks) life.
Even if you plan to use & abuse them non-stop, sealed U-joints will last longer with less maintenance than greasables. And they're physically stronger.
post #23 of 30 (permalink) Old 07-22-2019, 05:42 AM Thread Starter
Big Horn's Avatar
I have a question about my Dana 60 oil seals. I didn’t have any oil in the axle tubes until I pulled the axle out of the carrier (low side on stands)
How long (Miles) do these seals normally last before needing replacement?
Big Horn is offline
post #24 of 30 (permalink) Old 07-22-2019, 05:48 AM Thread Starter
Big Horn's Avatar
I realize that probably depends on 4WD usage.
Big Horn is offline
post #25 of 30 (permalink) Old 07-23-2019, 05:42 PM Thread Starter
Big Horn's Avatar
Waiting on parts Sucks! Cleaned and wire brushed this morning, a coat of fosfo, and then black paint tomorrow.
Big Horn is offline
post #26 of 30 (permalink) Old 07-23-2019, 05:55 PM
klhansen's Avatar
My Photos: (180)
At least 200K miles( YMMV ). I replaced my D50 axle that had problems with a new 04 D60 takeout. I've had the axle shafts out of that one at least once, and the axle seals (just outboard of the differential) are still fine. I leave my hubs locked all winter, as well.
You have to pull the differential to change them, so if they aren't leaking ...... well you know the saying - if it ain't broke, don't fix it.
), AIS,
regulated return,
klhansen is offline
post #27 of 30 (permalink) Old 07-25-2019, 06:35 AM Thread Starter
Big Horn's Avatar
Since I’m waiting on parts I’ve been searching / reading all the old posts about front hubs on TDS. Came across the Dynatrac Free Spin modification. A lot of old posts, but nothing recent. Went on-line to manufacturers web site, Seems like a good mod and don’t see any negative comments on TDS other than initial cost. I’ll see how these $300. hubs hold up this time, but Geeeeeeez - $1900.00 is a lot of money..........But I guess since I would be doing the labor it might be worth it in the long run
Big Horn is offline
post #28 of 30 (permalink) Old 07-25-2019, 06:40 AM Thread Starter
Big Horn's Avatar
That’s $300. X 2 ($600. + parts, hub seal, dust seal, ......... I don’t want to do this very often
Big Horn is offline
post #29 of 30 (permalink) Old 07-25-2019, 02:27 PM Thread Starter
Big Horn's Avatar
Originally Posted by klhansen View Post
Be advised that the standard C-clamp style ball joint/u-joint press won't work on them. The cups are too large to fit in the hole in the press, and putting any rings in will make the clamp too small to fit around the yoke. A hydraulic shop press will be needed.
Heading up town to buy a six pack and lottery ticket! Wire brushed, soaked in liquid wrench, and got the u-joints apart with a hammer and spacer (old lug nut key) 😗
Big Horn is offline
post #30 of 30 (permalink) Old 07-25-2019, 04:03 PM
klhansen's Avatar
My Photos: (180)
Good Job! There's always the BFH approach.
), AIS,
regulated return,
klhansen is offline
  Diesel Forum - TheDieselStop.com > Other Topics > Wheels, Tires, Brakes, and Suspension
