Calipers - New or Rebuilt? - Diesel Forum - TheDieselStop.com
Sponsored by Discount Tire
 1Likes
  • 1 Post By Stroking it
post #1 of 11 (permalink) Old 01-10-2019, 05:13 PM Thread Starter
Looking to possibly replace my calipers, along with pads and rotors, on my next brake job. Mine are the OE equipment that came on the truck when it was manufactured.
Will contact my dealer to see if new OE ones are available or possibly go with Motorcraft calipers if OE is not available.
For those who have replaced theirs with Motorcraft calipers, what has been you experience with them?
Thanks in advance!
2002 2WD XLT CrewCab, 3.73 Limited Slip, Assembled 08-09-01 in Ford's Cuautitian, Mexico plant. BTS Transmission with 6.0L Cooler, Mobil 1 Synthetic transmission fluid, KC reverse backup lights with separate on/off dash switch, Undercover Bed Lid, Bilstein shocks, Gentex K-21 auto dimming/temp/compass mirror, Michelin LTX/MS2 tires, Factory Aluminum Wheels, Door Seal Mod, Ford Severe Duty AIS w/Zoodad, Royal Purple 75W-140, Fleetrite ELC Coolant, Billet Aluminium Thermostat Housing, Ford Factory Bed Liner, Sylvania Silverstar Ultras. Tekonsha P3 Brake Controller, Dieselsite Max AC Assist. DP-Tuner Infinity with 60hp tow and 80hp city/highway tunes. Garrett EBPV Delete Pedestal and High Flow Outlet. International Up-Pipes.
TooCoolTwo is offline
post #2 of 11 (permalink) Old 01-10-2019, 05:28 PM
I replaced my rear calipers with Motorcraft loaded calipers. New pistons, pads, bolts, hardware. I also replaced the brake line hose to the rear calipers. The front calipers I replaced the pads, hardware and the brake line hoses.
The rear calipers were hanging up. That is why I replaced the entire calipers. I replaced the front calipers with loaded (pads & hardware assembled) the previous brake job.
I will only use NEW Motorcraft. I ordered from Rockauto.
2002 F350 7.3 psd supercab dually 2wd, AIS, Moog joints, Bilstein, Michelin Defender LTX, Dieselsite coolant filter, red ELC, prepump spin-on fuel filter, 252,000 miles, hutch/harpoon mod, marinco mod, scan gauge ll, Zoodad, Dieselsite boots, pedestal delete, CNC Fab w/ crossover oil lines, 6.0 trans cooler, replaced oil pan, Walker BTM, Denso starter
1974 CJ6 ... off the frame needs work
2013 Expedition... wife's car
Panhead ... 53 motor, 51 tanks, B grind cam, S&S carb, points, drum brakes ... It doesn't just sit in the garage
panhead george is online now
post #3 of 11 (permalink) Old 01-10-2019, 06:36 PM
ArcticDriver's Avatar
Isn’t OE the same thing as Motorcraft?
SOLD:
ArcticDriver is online now
post #4 of 11 (permalink) Old 01-11-2019, 06:30 PM Thread Starter
Not sure if OE is Motorcraft or not. I "think" OE are all newly manufactured new calipers and all Motorcraft calipers are remanufactured to Ford's specifications, but I might be wrong.
post #5 of 11 (permalink) Old 01-11-2019, 07:45 PM
Originally Posted by ArcticDriver View Post
Isnít OE the same thing as Motorcraft?
I believe OE is Motorcraft.
Why would you want to buy a rebuilt caliper? I would prefer new pistons in the caliper with the new pads to ensure they do not fail before the life of the pads.
post #6 of 11 (permalink) Old 01-11-2019, 08:45 PM
Motorcraft is OE. There are some other manufacturers that make OE parts also.
2001 F350 XLT 4X4 crew cab, dual rear wheels, long bed, black, 7.3l turbo diesel, automatic transmission, 4.10, shift on the fly, running boards, sliding rear window, 38 gal fuel tank, Odyssey extreme 65-PC1750T batteries, Michelin LTX-MS2 rear tires, Sumitomo Encounter front tires, Shell Rotella Ultra elc, 11,500 gvwr, 20,000 gcwr, 7500 gvw, completely stock, 114,000 miles when purchased, now has 240,000 miles, repairs so far: two starters, batteries, cps, brakes, tires, alternator, ball joints, locking hub, wheel hub, AC compressor, serpentine belt, power steering pump, driver's side window, ignition switch, o-ring, Spectra premium radiator, water pump, fan clutch, fan blades, thermostat, thermostat housing, tensioner. Stolen twice so far, but recovered both times with major damage.
DonWarkentin is online now
post #7 of 11 (permalink) Old 01-11-2019, 11:01 PM
After a period of time new calipers aren't available because Ford stops making them. I believe they only have to make parts for a M/Y for 5 years or something like that. After all the new parts are gone than all you can get is a reman part. That is why there is a core on some parts. It keeps older trucks on the road and brakes are nothing that should keep a great running truck off the road. Nothing wrong with a reman part. However I go to Napa for things like that. Not Autozone.
Stroking it is offline
post #8 of 11 (permalink) Old 01-12-2019, 01:34 AM
I buy them from Rock Auto. You can get either new or reman from them. Either new or reman work fine.
post #9 of 11 (permalink) Old 01-12-2019, 09:56 AM
I have bought stuff from Rock auto BUT make sure that the part you order is exactly the part you want. I got some parts only to find that they weren't correct and i had to pay to return them. It was my mistake so I only have me to blame nut make sure it's the correct part. I did however get good quality parts from them. Descent shipping time though.
panhead george likes this.
post #10 of 11 (permalink) Old 01-12-2019, 09:58 AM
chuckster57's Avatar
Why are you replacing them.
Train Horns:
PM please not visitor message
chuckster57 is offline
post #11 of 11 (permalink) Old 01-13-2019, 08:32 PM Thread Starter
Safety. My truck was manufactured in 08-2001, make it eighteen years old with the original factory calipers. Preventive maintenance for safety reasons. Wife and I do some mountain driving in the summer. Time for new rotors and also.
  Diesel Forum - TheDieselStop.com > Other Topics > Wheels, Tires, Brakes, and Suspension
