Converting from leaf springs to Coils. I did it! - Page 2 - Diesel Forum - TheDieselStop.com
Forum sponsored by: Discount Tire
 3Likes
post #16 of 25 (permalink) Old 12-09-2016, 12:18 PM
Does anyone know if the rear axles from the 2005 and 2011 are substantially different? The 2011s come with an e-locker and they cost about as much as buying a locker for the earlier axle.
tsmall07 is offline
post #17 of 25 (permalink) Old 01-15-2017, 06:59 PM
The 2005 has the VSS in the differential, the 2011 has the VSS in the trans IIRC .
Valley Rock is offline
post #18 of 25 (permalink) Old 01-16-2017, 07:00 AM
I've been reading a lot since I posted and it looks like the issue is that it has a speed sensor at each wheel for the stability control. Not really possible to deal work that without a ton of work. Now I'm wondering if there's much of any difference between the 06-07 and the 08-10 axles.
tsmall07 is offline
post #19 of 25 (permalink) Old 01-17-2017, 04:03 PM
Hypothetically speaking you should be able to use one of the wheel speed sensors in place of the older style VSS that set on top of the diff . It may require some recalibration, or it may work just fine, but it accomplishes the same thing, the rear spring perches are the same from 99 thru 2011, that I know because I am putting a 2011 rear and front in my 2K SD .
The rear switched to a flange instead of a yoke at some point, not sure what year, but the 2011 has a flanged pinion .
tsmall07 likes this.
post #20 of 25 (permalink) Old 01-17-2017, 11:53 PM
Assuming it's the same kind of signal, I suppose that could work. Let me know how it goes for you.
tsmall07 is offline
post #21 of 25 (permalink) Old 10-09-2017, 01:57 PM
Any pictures?
scottm likes this.
robertkkoh is offline
post #22 of 25 (permalink) Old 12-27-2018, 09:27 AM
imrdnck's Avatar
Do you have to reinforce the frame?
imrdnck is offline
post #23 of 25 (permalink) Old 07-07-2019, 06:15 PM
caryt can I get more info on the conversion as I am interested thx
SCAT49 is offline
post #24 of 25 (permalink) Old 07-08-2019, 12:39 PM
Big Horn's Avatar
Originally Posted by hawssie View Post
The ride was actually a little stiffer maybe because my doner axle/springs were from a f350 and my truck is a f250. But it rides much better and is so much quieter then the old leaf springs that clunk when turning and its much more sporty ride.
Can someone expand on this- “old leaf springs that clunk”. I noticed on my 4wd F350, wheels turned hard, backing up, I would get that “clunk” - is this a normal characteristic of the front leaf springs? I was unsure of the noise. Thanks!
2002 F350 7.3L / 4R100 - 4WD CC DRW 8’ Box, AIH Delete, Gauges- Pyro, Trans Temp, Boost, Fuel Pressure, TS-6 tuner, Zoodad Mod, Mishimoto 31 row Trans cooler, Mobil 1 ATF, Trans return line ATF filter, Hutch/Harpoon Mod, Air Lift Load Lifter 5000 rear air springs, Rancho 9000 shocks, Timbrens on the front.
Big Horn is offline
post #25 of 25 (permalink) Old 07-09-2019, 06:31 PM
Sounds like mine. But I don't know enough about it to know whether or not that is a normal characteristic.
DonWarkentin is offline
  Diesel Forum - TheDieselStop.com > Other Topics > Wheels, Tires, Brakes, and Suspension
