Firestone air bags for early '99 F250 - Diesel Forum - TheDieselStop.com
Forum sponsored by: Discount Tire
post #1 of 7 (permalink) Old 04-23-2017, 02:47 PM Thread Starter
just added dump insert on truck like to get some ideas on air bags for rear. thanks
stumpman is offline
post #2 of 7 (permalink) Old 04-23-2017, 04:59 PM
chuckster57's Avatar
Firestone or Airlift would be a toss up, either one are high quality. What specific questions do you have?
chuckster57 is offline
post #3 of 7 (permalink) Old 04-23-2017, 05:36 PM Thread Starter
part #s for firestone ride rite also wonder if truck sways when loaded and pulling trailer ride somewhere about inboard or outboard explain please thanks
stumpman is offline
post #4 of 7 (permalink) Old 04-23-2017, 07:25 PM
klhansen's Avatar
My Photos: (180)
Firestone air bags mount outboard of the frame rails. As far as the other items, not sure what you mean.
), AIS,
regulated return,
klhansen is offline
post #5 of 7 (permalink) Old 04-23-2017, 09:44 PM
My airlift are mounted outboard. I get no sway with 2000 lbs of kingpin weight. Pulling a bumper pull trailer, bags don't really affect trailer sway. Proper loading of trailer is more important.
Train Horns:
PM please not visitor message
post #6 of 7 (permalink) Old 04-23-2017, 11:57 PM
Some of the airbags mount inboard of the frame. They will provide lift but closer to the center of the truck. I can't report on the inboard bags because, I have always gone with the outboard bags. They it should provide best anti-sway from bed load. Wag from the trailer is as chuckster57 says, proper loading of trailer is key. I have done that wrong more than once!!!!
DENNY
DENNY is offline
post #7 of 7 (permalink) Old 04-24-2017, 02:04 PM Thread Starter
thanks to all decided to go with firestone 2484
stumpman is offline
  Diesel Forum - TheDieselStop.com > Other Topics > Wheels, Tires, Brakes, and Suspension
