Diesel Forum - TheDieselStop.com
Diesel Forum - TheDieselStop.com (https://www.thedieselstop.com/forums/)
-   Wheels, Tires, Brakes, and Suspension (https://www.thedieselstop.com/forums/f122/)
-   -   Front end rebuild - seeking advice (https://www.thedieselstop.com/forums/f122/front-end-rebuild-seeking-advice-651635/)
Boating_fool 09-01-2018 01:08 PM
23 Attachment(s)
My 2008 6.4 w/98k has started to develop some play in the right tie rod end. On most other vehicles I own(ed) I have rebuild the entire front end at 100k just to eliminate future issues and hassles with multiple alignments.
all Moog parts are $528 (including new steering stabilizer) through rock auto.
I am only questioning if I should replace the ball joints. It is a 4wd and sees mostly highway use. Replacing the ball joints requires pulling the axles and adds another $125 or so in new seals.
How many miles or years can one expect from factory ball joints? Should I just go ahead and replace them with the steering?
OJ
Ford06 11-05-2018 02:46 PM
I am at 225,000 on a 2006 4x4 and need to replace them.
klhansen 11-05-2018 06:22 PM
I've replaced ball joints on the driver's side at about 200k miles, IIRC. I'm at ~220 right now and the right side is still original. Wait, I take that back. The new D60 axle went in at maybe 50-60k miles, so that would make it 140-150k on the driver's side and maybe 150k now on the passenger's side ball joints.
If you're going that far in, I would probably replace both side ball joints. It's recommended that the spindle bearing inside the hub assembly be regreased every 60k or so anyway.
Powered by vBulletin® Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
