Front end rebuild - seeking advice - Diesel Forum - TheDieselStop.com
Forum sponsored by: Discount Tire
post #1 of 3 (permalink) Old 09-01-2018, 01:08 PM Thread Starter
Boating_fool's Avatar
My Photos: (61)
My 2008 6.4 w/98k has started to develop some play in the right tie rod end. On most other vehicles I own(ed) I have rebuild the entire front end at 100k just to eliminate future issues and hassles with multiple alignments.
all Moog parts are $528 (including new steering stabilizer) through rock auto.
I am only questioning if I should replace the ball joints. It is a 4wd and sees mostly highway use. Replacing the ball joints requires pulling the axles and adds another $125 or so in new seals.
How many miles or years can one expect from factory ball joints? Should I just go ahead and replace them with the steering?
OJ
Vincent
Greencastle PA (Unfortunately)
2008 F250 CC SWB King Ranch 4x4 6.4
Air Lift 5000 Ultimate w/wireless air, Bilstein 4600 HDs, Hellwig BigWig Sway bars, Pullrite Super Rails, Hensley BD3.
2018 Mercedes E400 4Matic Coupe
2015 Mercedes GLK250 BlueTec
2002 Ford Focus SVT
Boating_fool is offline
post #2 of 3 (permalink) Old 11-05-2018, 02:46 PM
I am at 225,000 on a 2006 4x4 and need to replace them.
2006 F250 Lariat Supercrew, ESOF 4x4, 18" tires, FX 4, HD Alt., block heater, Integrated Trailer Brake Controller, Upfitters, power rear window, cab lights - delivered 10/25/05
Ford Remote Start; High idle mod; Timbren load levelers, Scangauge II, Blue Spring upgrade, Quick Start 200 amp large frame alternator, 2 batteries January 2010; GPCM replace October 2011; 2 EGR valves; EGR Cooler replaced 12/30/11; Performance Machine & Mfg. coolant filter added 1/2/12; Rotella T6 5W40 oil; turned rotors, replaced brake pads for 1st time 1/7/12 101K miles; GPCM, both subharnesses and all 8 glowplugs replaced 1/5/13 at 118,000 miles; 2 Ford batteries replaced under battery warranty twice, the latest 9/18/2015; FICM power supply board replaced with Dorman board 11/20/13. Coolant flushed and replaced with Prestone ELC 9/27/14. STC fitting 10/19/14; Dummy Plugs 11/8/14; Turbo rebuilt 11/29/14; cold side CAC tube and boots replaced with metal tube 1/24/15; replaced hot side boots 1/30/16.
Ford06 is offline
post #3 of 3 (permalink) Old 11-05-2018, 06:22 PM
klhansen's Avatar
My Photos: (180)
I've replaced ball joints on the driver's side at about 200k miles, IIRC. I'm at ~220 right now and the right side is still original. Wait, I take that back. The new D60 axle went in at maybe 50-60k miles, so that would make it 140-150k on the driver's side and maybe 150k now on the passenger's side ball joints.
If you're going that far in, I would probably replace both side ball joints. It's recommended that the spindle bearing inside the hub assembly be regreased every 60k or so anyway.
), AIS,
regulated return,
klhansen is offline
  Diesel Forum - TheDieselStop.com > Other Topics > Wheels, Tires, Brakes, and Suspension
