Front Rotor Removal? - Diesel Forum - TheDieselStop.com
Forum sponsored by: Discount Tire
post #1 of 3 (permalink) Old 08-22-2011, 07:15 PM Thread Starter
I am trying to remove the front rotors for an upgrade. Ive already removed the 8 nuts holding the hub extension (and rotor) but nothing budges. Short of using a bigger hammer, are there any tricks? (I prefer using finesse over force) Any suggestion will be appreciated. Thanks, JayB
2000,F350,4X4,DRW,SC,Lariat, Harvestgold/black,(DAC3), AIC, 6sp, 4:10LS, captains chairs, B/W turnover ball, Class V hitch, AIS, Baldwin bypass & coolant filters, Magnefine p/s filter, Oberg trans filter, Racor 645R30, Racor 4500CCV, J&J grille, Husky liners & mudflaps, Line-X, Mag-Hytec, D-P Tuner 40t/60t/80e chip, Westach 3" EGT/Boost gage, ITP HX Line, Evans coolant, 203* therm, TTM, Banks Big Head, Banks exhaust & downpipe, High Flow Outlet (non EBV), WW, LuK, Gearvendors Overdrive, BD Short Shifter, Cyclops, Rancho 9000s, Rancho Steering Stabilizer, Firestone Air-Lift, X-springs, C-Betr, regulated fuel return, Air Dog, "Hutch" mod, Brown Bread & Vcomp sound damping, Kenwood & JBL speakers, (2)Odyssey 1700T Batteries, 100% Amsoil, NRA Life Member
JayB is offline
post #2 of 3 (permalink) Old 08-22-2011, 07:50 PM
RT
RT's Avatar
There's no magic - you can try penetrating oil at the interface of the hub and rotor, but usually its brute strength that wins the battle. I put a 2x4 on the back side and "tap" it with a hand sledge, rotate and repeat. Eventually it will budge. Try turning the wheels all the way one direction or the other to give yourself better access to the area you're aiming at. Bob has a write-up for brake upgrades, but you'll notice he conveniently left off the step where the rotor comes off:
Welcome to guzzle's Powerslot/Hawk pads brake Maintenance Web Page
RT is offline
post #3 of 3 (permalink) Old 09-09-2011, 05:25 AM
A 3lb mini sledge works best. You need a little bit of "shock" to break the hold it has on the hub.
2002 Excursion Limited 7.3L PSD, Auto, 4x4, 35x12.50-17 Mickey Thompson ATZ, Blue Gold, AFE Stage II with ProGuard7, MBRP 4" stainless, DP tuner (hi idle, stock, 40, 60, 80, 120), Adrenaline HPOP, Coolant Filter, Amsoil bypass filter, Ford rear sway bar, 6 1/2" spring arch.
2000 BMW 540i, 6 speed, sport package, daily driver.
jnyost is offline
  Diesel Forum - TheDieselStop.com > Other Topics > Wheels, Tires, Brakes, and Suspension
