Front sway bar links.????? - Page 2 - Diesel Forum - TheDieselStop.com
Forum sponsored by: Discount Tire
post #16 of 36 (permalink) Old 06-08-2007, 01:38 PM
Re: Front sway bar links.?????
and btw the energy suspension bushings come in red or black,
theyre made of polyurethane and will provide a MUCH NICER
ride (and firmer turning / less lean) than the crappy RUBBER
bushings that come from the factory !
04 f350 CC LB SRW 4x4 (fx4 w/out the stickers & badges)
cb1000 is offline
post #17 of 36 (permalink) Old 06-08-2007, 05:33 PM
Anything I should be aware of before I tear into it? I am mainly concerned about the frame maounts because of the rattle I hear when I hit bumps.
are you SURE its your sway bar bushings and not the ball joints
that youre hearing ?
the problem <hard part> is removing the stupid FORD OE
bushings in the drop link / lolly pops...they have a
metal collar around the rubber insert...and it is a
TOTAL pain to press the OE bushing OUT if the rubber
part is torn out.
youll need a press to get the metal collar out & there isnt
much to press against.
a press makes the job easier even on the bushings that are
still intact...and its next to impossible to remove the
metal collar w/OUT a press.
the Energy Suspension bushings can be pressed in by hand
or w/ a vise or clamp...the bushings are avail. from
jegs.com & summitracing.com for about 34 bucks.
remember to lube the bushings that go 'round the bar...or
theyll squeek like hell !
[/ QUOTE ]ur right i didnt have a press on two of them i had to litterally burn them out with a cutting torch. big ball of metal dripped out. others the air chisel worked.
samdust is offline
post #18 of 36 (permalink) Old 06-08-2007, 05:48 PM
soak 'em a little in 3 in one oil or pb blaster....
the THREE that werent torn (on drop links) i knocked
out w/ a hammer (put the drop links in a vice)
the one that had torn (and left the metal collar behind
had to be pressed out.
cb1000 is offline
post #19 of 36 (permalink) Old 06-09-2007, 10:52 AM
NCHornet's Avatar
I read many, many posts where folks had a devil of a time getting the old bushings out. Not worth saving $40 to me. I called Powerstrokeshop and got two of them for around $45 each, install was easy as removing 4 bolts. However the noise is back on the drivers side after just a couple months!!!
NCH
2000 Ford F350 4X4 Auto,Crew Cab Lariat, Western Hauler Package, Long bed,
Isspro EV Guages on A-Pillar, Coolant change from Green to Gold to Red,
SCT XCalibrator2 with DP's 60 tow,80 econo,120 Race
Fumoto Valve, Marinco Mod, Homemade CCV MOD,Fuel Neck Mod, KMC Wheels at all 4's
Monroe Reflex Shoxs, SS/Kevlar Brake Lines,
FTVB from Greg Evans,Ford AIS Intake
Coolant filter,Walker BTM, Attwood Gooseneck ball flush mount,6.0 cooler, 2002 headlights & corners
Zoodad Mod,Cyro'd Powerslots and Hawks LTS Pads. 2005 front grill
Turbo Lifesaver, Infinity Refrence x4, powered by Infinity Reference amp, sounds awesome!!
Towing a 2005 HORNET 30BHSS 8500 LBS,
Stopping it with a Prodigy P3 Controller
Friends Don't Let Friends Drive Trucks With Generic Tunes!!
NCHornet is offline
post #20 of 36 (permalink) Old 06-09-2007, 11:27 AM
yup cause all you did was replace the junk w/ junk...the problem
is ford uses crappy factory RUBBER bushings...theyre inferior any
way you slice it...they flex MORE, tear, wear, hard to replace
and they COST MORE...than the polyurethane ENERGY SUSPENSION (brand)
bushings.
you say its not worth saving 45+ bucks...but now youve gotta do
the JOB AGAIN...how much is your time worth ?
cb1000 is offline
post #21 of 36 (permalink) Old 06-11-2007, 10:01 AM
NCHornet's Avatar
I must have gotten a bad part from Ford, it happens. I am restoring a 77 CJ5 and Energy Suspension had to send me three tranny mounts before I got one where the threaded insert wasn't mounted so crooked the trans wouldn't bolt up, so don't preach how good there products are to me!!! Besides if the factory ones last another 7 years the way the first ones did, that's okay with me.
See Ya
NCH
NCHornet is offline
post #22 of 36 (permalink) Old 06-11-2007, 10:47 AM
Those of us having to REPLACE the factory drop link bushings
arent doing it because we WANT TO...or that they have lasted
7 years...
next time you go down the road and see a superduty...look under
it...i think youll find more than one w/ a busted drop link
bushing...
the bushings rate right up there w/ the ball joints...PENNY
WISE, POUND FOOLISH !
cb1000 is offline
post #23 of 36 (permalink) Old 06-11-2007, 01:45 PM
bushings.
[/ QUOTE ]factory bushings arnt rubber dude they are metal they are wrapped in rubber stuff to hold in grease thats it. thats why they are so hard to get out. ill agree i havent had any problems with energy sus. bushing ill buy again if my clunking comes back
samdust is offline
post #24 of 36 (permalink) Old 06-11-2007, 01:55 PM
which bushings are you talking about ? the sway bar bushings
are NOT grease wrapped in rubber...if you tore one youd know this !
cb1000 is offline
post #25 of 36 (permalink) Old 07-26-2007, 11:02 AM
This is a question for anyone that installed the ES poly swaybar set. Did you use the large flat washer in your install? And if so, where did you place it?
Thanks.
Rusty
1997 F250 CC, SB 4x4, 220,000 miles, 7.3 PSD, E4OD, 3.73 gears, Kingpin Dana 60, 10.5 rear, True-trac, Sky 3" RSK, D-code spring in front, B-codes in back, F250 blocks
rusty1161 is offline
post #26 of 36 (permalink) Old 07-26-2007, 01:53 PM
so wait whos talking about what? ok so theres the sway bar, that mounts to the axle, and has RUBBER bushings on it. then there is the end links that mount from the sway bar to the frame. all RUBBER bushings. can someone take pics if what they are talkin about?
dougdoug is offline
post #27 of 36 (permalink) Old 01-18-2008, 02:06 PM
Well I ordered the bushings from Energy Suspension and installed them. I had to have the old bushing pressed out of the links. Guy did for me at work. No problem installing the new ones. Now we have to see how long they last.
niteman9 is offline
post #28 of 36 (permalink) Old 01-18-2008, 08:19 PM
Thanks.
Rusty
Yes. I put them on the bolt head side of the bushings. This is the side furthest from the sway bar and closest to the engine.
Joe
2002 F350, Crew Cab, 4WD, ISSOPRO Gauges,
3.73, Auto, 2wd low range mod, No door dinger,
Interior lights off switch, Zoodad Mod,
Extra Trans Cooler, Before coolers trans fltr,
Coolant fltr, Crimestopper remote start/alarm
Oil Guard Bypass, Air horns
MOUNTAINMAN444 is offline
post #29 of 36 (permalink) Old 04-19-2008, 09:10 AM
I'm in the process of replacing the sway bar bushings on my truck. Are you guys re-using or replacing the bolts. I can't get the 2 bolts that attach the end link to the frame to break free from the bushing. Any tips or hints?
2004 Superduty Supercab SB FX4 4x4 PSD 6.0 Torqshift
nautiquexl is offline
post #30 of 36 (permalink) Old 04-19-2008, 09:22 AM
Hit them with a hammer. You should see a washer like metal shield on one or two of them. And they are just washers, should not be holding up back.
2000 F-250 Ex-Cab Shorty - 4x4 - 7.3l - Auto - CAT ELC - 203* - Dieselsite Coolant Filter - AIH Delete - ITP HPX - Bilsteins - Walker BTM - Ford Severe AIS - CCV Canister - SCMT 1700 - Harpooned Tank w/ ITP Pre-Pump Kit - 321k
Check out my
tjsulli790 is offline
  Diesel Forum - TheDieselStop.com > Other Topics > Wheels, Tires, Brakes, and Suspension
