heavy duty light truck tires - Page 3 - Diesel Forum - TheDieselStop.com
Forum sponsored by: Discount Tire
post #31 of 39 (permalink) Old 04-13-2007, 09:28 AM
Flywheel's Avatar
Re: heavy duty light truck tires
Actually the Sterling Plant has been brought back to Ford about a year ago. No longer Visteon
....so the axle rating is back down to 6084lbs? [img]/ubbthreads/images/graemlins/shrug.gif[/img]
Trail Boss Replacement Bumpers, Tool Box, Headache Rack, Full Length Running Boards, BFG AT/KO 285/75x16E, 2003 Cup Holder, Marinco Heater Plug, Weather Tech Rain Vents / Hood Guard, B&W GN Hitch, X-Springs, Rear 4" F350 Blocks, Hellwig front and rear sway bars, Airlift / Wireless, Duraflaps
Isspro A-Pillar Gauges, Isspro TTM, Ford AIS, Magnaflow 3.5" DP - 4" Exhaust, Garrett GTP38R Turbo, Turbo-Master, High Flow Outlet, Non EBV Pedestal, IH Up-Pipes, DS 203 degree Stat, OA, BTS Tranny, 6.0L Tranny cooler, DP-Tuner F6, FRX, Cass Stage 1s, T500 HPOP, DieselSite HPX
99 F-250 CC SB 4x4 7.3 White
Ranch Truck, Ranch Hand brush Guard, Original Cup Thrower, DP-TUner F6, 4" Turbo Back Magnaflow, AIS Intake, 6.0 Tranny Cooler, Ford 4R100HD, CM Flatbed
Autoenginuity
Flywheel is offline
post #32 of 39 (permalink) Old 04-13-2007, 09:35 AM
Flywheel's Avatar
David - yep - your math is right - but remember, the Axle Weight Ratings EXCEED the GVWR - so it somes down to distribution as well as overall weight...You are actually at about 2200lbs overweight...IF you go by the numbers.
Like thes two other posters asre saying, you can do it (like home depot....we can help...).
BUT -
You are overweight
The bumper pull trailer you have is dang heavy
Now add a pretty substantial load to the back of you SRW truck
it is a freakin' heavy load and not adviseable for a family trip.
If you were going 20 miles up the road - no problemo - but loading up with kid and stuff on vacation is just plain wrong.
You need a dually. heck - get a dually rear axle, sway bar and front wheel adapters and fender flares - you'll be good to go.
Autoenginuity
Flywheel is offline
post #33 of 39 (permalink) Old 04-13-2007, 12:09 PM
Smokey should know better (he is the stat man) but if you go to the Visteon website, (they make your axle) you will find the axle is rated at 9700 pounds.
We're talking about a 2001 model. Back then, Ford owned and ran the Sterling MI axle plant. And Ford specs for 2001 SuperDuty pickups say the 10.5" rear axle in an F-250 was rated at 6,084 pounds @ground.
Sometime during the 2003 model year, Visteon bought the plant from Ford. You can use Visteon specs after the 2003 model year, but not for a 2001.
This is a real question not a retort.
Have you seen anything that would indicate there was a change in the design, (large or small) or for that matter any parts changes
01 250 PSD SC 6sp camper pkg -5.6k to 25k pot- AIS- Reese Titan - SC max tuner- Rhino lined-
73 Pinzgauer
78 toylet (chevota) cruiser 12 years of mods
05 disco (wifes car)
Overload is offline
post #34 of 39 (permalink) Old 04-13-2007, 10:17 PM Thread Starter
ok i figured you all spent this much time and effort....so i went to the scales today.......gross combines truck and trailer all loaded and wet was 19,920 the trailer only was 12,140 the trailer toungh weight was 1,360 and the suprise kicker was i put just the rear of the truck on the scale and it only weighs 3,140...ok here we go the rear half is 3140 plus the toungh weight is 1360 1360+3140=4,500 so if i add the 1200 i want to add it will be 5,700.....now ive seen it for myself ...is this ok...or am i still not seeing the big picture.....david
2001 f250 4x4 cc sb , 6 in lift, cheyenne wheels, 3.73 gears, 4 in exhaust with muff delete ,piller gagues, dp 6 pos chip, zoodad ,john wood transmission
sandfun is offline
post #35 of 39 (permalink) Old 04-13-2007, 10:22 PM
what was your front axle weight and rear axle weight while hooked up. and what was your trailer axle weigths while hooked up.
sgrem is offline
post #36 of 39 (permalink) Old 04-13-2007, 10:45 PM Thread Starter
man i didnt think i had to weigh half the truck wile hooked up.....heck i thought about doing that and thought everyone would want it all seperated like i did it so they could do the math themselves....but now that iv'e raved on and on....why do you ask that question ?????
sandfun is offline
post #37 of 39 (permalink) Old 04-13-2007, 10:56 PM
those are the actual weights that matter. weight transfers to the axles are measured when hooked up. then there is no math to do. either you have the capacity or not. very cut and dry. hook up with all your gear and go back to scale. put each truck axle on its own scale WHILE HOOKED UP and the trailer axles together on the scale WHILE HOOKED UP with everything you expect to ahve with you. even the family.
sgrem is offline
post #38 of 39 (permalink) Old 04-13-2007, 11:14 PM
also do you have a hitch that will hold that cause the limits of your factory one is exceeded. also your drawbar and ball. some of the huge ones are limited to 12k max and 1200 tongue weight. the cheap o ones that most people have are limited to about 6k and 600 tongue weight.
sgrem is offline
post #39 of 39 (permalink) Old 04-14-2007, 11:27 AM
Go to your local truck stop that has scales, you can get weights for each axle, it costs something like 5 or 6 bucks.
1997 Ford F350 SRW 7.3L PSD
1985 Ford Ranger 2.3L 5 speed
1966 Mustang 200 I6, auto, 4 wheel disk, power brake retrofit, Corvette master.
Former vehicles, 1994 E350 7.3L IDI, 1985 International 1654 rollback, 6.9L IDI, (2) 1994 Ford E350 7.3L IDI, 1985 Ford F350 DRW 6.9L IDI, 1985 Ford F350 wrecker 6.9L IDI.
*dual ASE Master Certified, Automotive, Medium & Heavy trucks*
Owner / operator, Patriot Automotive, N Ridgeville OH
Mr_Roboto is offline
  Diesel Forum - TheDieselStop.com > Other Topics > Wheels, Tires, Brakes, and Suspension
