hydroboost install - now PS pump whines. - Diesel Forum - TheDieselStop.com
Forum sponsored by: Discount Tire
 1Likes
  • 1 Post By DonWarkentin
post #1 of 7 (permalink) Old 10-22-2019, 11:45 AM Thread Starter
Dieselfoil's Avatar
I recently installed hydroboost on my 1996 F250 Powerstroke. Upon firing it up, the power steering pump whines now. It gets slightly louder if I step on the brake or turn the steering wheel. It never made a peep before the install.
Has anyone experienced this before?
Also, I noticed that the orifice on the new hose going from the hydroboost to the PS pump is slightly smaller than the original hose. I'm wondering if there is less fluid flow now, causing the whining?
I changed the fluid (ATF type F) and didn't really help.
Brakes work well. I didn't connect the pressure sensor yet. Need a "T" as there was not port for the sensor on the new master cylinder.
Thanks in advance.
Name:	Two tone test.jpg
'96 F250 4x4 Crew Cab SB
Chipped
Stage 1 Injectors
4" straight pipe
8" lift on 38.5" tires
Rear disc brake conversion
Still in progress...
Dieselfoil is offline
post #2 of 7 (permalink) Old 10-22-2019, 12:26 PM
ford_doctor's Avatar
Totally normal unless this is going on for days. It takes time to completely remove the air from the system. There is a vacuum adapter that can be put on the fluid reservoir that when vacuum is applied is supposed to hasten this process. My experience is that pressing the brake a couple of times and turning the steering wheel lock to lock once then shutting the engine off 10 minutes and repeating several times is a good start. Also you can step up the fluid to synthetic ATF like Mercon LV.
Nice truck!
2019 Ford Fusion ENERGI Titanium Plug-in Hybrid
Diesel Technician Society
Diesel Mentor Directory
ford_doctor is offline
post #3 of 7 (permalink) Old 10-22-2019, 12:58 PM Thread Starter
Dieselfoil's Avatar
Yeah, It's been whining for about 6 days now. Maybe I'll try the synthetic ATF. I did all of the air bleeding steps, but no luck yet. It's just annoying. I'd like to understand exactly what is causing it, as there wasn't a whine until I added the hydroboost. I understand a pump will whine when low on fluid, so I thought maybe the hydroboost or the new lines might be restricting the flow, and acting like a low fluid situation.
Chipped
Stage 1 Injectors
4" straight pipe
post #4 of 7 (permalink) Old 10-24-2019, 05:46 AM
Wait... this was not a repair/replacement of the hydroboost but an upgrade install?
post #5 of 7 (permalink) Old 10-24-2019, 02:50 PM
Please give us a little more detail of what you did. Did you replace the hydroboost, or add a second hydroboost, or upgrade the hydroboost?
ford_doctor likes this.
DonWarkentin is offline
post #6 of 7 (permalink) Old 10-25-2019, 10:49 AM Thread Starter
Dieselfoil's Avatar
I replaced/upgraded the standard vacuum assist to a new hydroboost and new master cylinder.
Chipped
Stage 1 Injectors
4" straight pipe
post #7 of 7 (permalink) Old 10-28-2019, 11:05 AM Thread Starter
Dieselfoil's Avatar
Correct. Upgrade installation.
Chipped
Stage 1 Injectors
4" straight pipe
  Diesel Forum - TheDieselStop.com > Other Topics > Wheels, Tires, Brakes, and Suspension
