I HATE my brakes!!!!!! - Page 3 - Diesel Forum - TheDieselStop.com
Forum sponsored by: Discount Tire
post #31 of 40 (permalink) Old 06-19-2013, 11:04 PM
Machiner1's Avatar
you should probably swap to the late 99 rotor on the left side as well so you can get rid of the washers. They certainly aren't helping with the stiffness / rigidity of the caliper
Early 99 F350 7.3 250k
SRW single cab 4x4 Auto Trans
4" turbo back w/ 5" muffler
Isspro trans pyro, boost, Fuel Press. and HPOP Gauges
AeroForce Scan Gauge
Stage 1 single shots from Full Force
Riffraff FRX & HPX
Terminator 500 HPOP
EBPValve delete W/ Blank Pedistal
Kickers all around w/ 10" sub
4" Cold air intake
35" MTs with 1.5" wheel spacers
DP f5 Tuner w/ F8 switch
On board air w/ Air horn
AST Ultra remote start
WMO !!!!
Machiner1 is offline
post #32 of 40 (permalink) Old 06-20-2013, 06:35 AM Thread Starter
I think you're right. I'll make sure to do that. Thank you.
Steve
Early 99 7.3 F250 Extended cab 4x4 6-speed 200,000 miles DIY intake, MBRP 4" single exit, Isspro EGT and boost, DP Tuner 80 econo flash, South Bend clutch Carbotech Bobcat front brake pads, Door seal and Snowman mods...
Steve91T is offline
post #33 of 40 (permalink) Old 06-28-2013, 11:39 AM Thread Starter
I finally got the time to replace all the brakes. The late 99 left front rotor did the trick....fits perfectly without washers.
So my brake pads are actually fine, still have about 50% pad left, so I just reused the pads. I've got all new rotors, calipers and brackets, all for free. I just had to pay for 2 bottles of brake fluid.
From this...
To this...
I love the feel of new brakes. Turns out non of my caliper slide pins were frozen. So the pulling must have been the left rear caliper not working well. Once the left front really got stuck, that's when I realized I had some problems. I'm really glad I was able to replace all 4 calipers and brackets, so hopefully I won't have this problem for a few years. We'll see!
Thanks guys,
Steve
Steve91T is offline
post #34 of 40 (permalink) Old 06-28-2013, 03:39 PM
FMTRVT's Avatar
My Photos: (16)
You know I have to ask this .......
Did you check the installed runout with a dial indicator?
Jack
YouTube Videos Google - TooManyToys
Step Lights;Painted Flanges; Bypass Oil Filter; Heated Mirror Switch; Reverse Lights; 7.3L Fuel Reg Shim; 6 Disc Radio Speed Volume Mod; Coolant Filter, etc.
FMTRVT is offline
post #35 of 40 (permalink) Old 06-28-2013, 05:49 PM Thread Starter
Ha nope! I knew it was coming. I didn't do it because I don't have a dial indicator and I honestly don't even know how. I think this is something that I'm going to do next time when I have more time.
Steve91T is offline
post #36 of 40 (permalink) Old 06-28-2013, 05:55 PM
chuckster57's Avatar
Dial indicator with a magnetic base is very reasonable at Harbor Freight. I have had mine for over 20 yrs now. I use it to "degree" cams too.
Sent from AutoGuide.com App
Train Horns:
PM please not visitor message
chuckster57 is offline
post #37 of 40 (permalink) Old 06-28-2013, 09:57 PM
FMTRVT's Avatar
My Photos: (16)
Yep, I was waitin'.
After preaching about doing this for years I guess I should spend some time and write up a pictorial for how to index rotors.
Jack
FMTRVT is offline
post #38 of 40 (permalink) Old 07-03-2013, 12:17 AM
Bill1013's Avatar
With all that trouble with the left caliper, I would surely change the left hose to it, they can deteriorate inside and not let the brake fluid return, acts like a check valve.
99.5 F350 XLT Lariat 4X4 4R100 4.10 DW CC LB Centurion conversion, 183K miles Garret Turbo, Radio SD &Tape, SP Performance 40-60-80 chip, 100 Gal.Transfer Flow W/Trimax Control Aux. fuel tank. ScanGaugeII, Boost, EGT, Trans. Temp. Oil Temp. Build date 03/99
92 F350 2WD 7.3 IDIT E4OD CC LB dually Banks turbo US Gear O/U, 79K on the engine. 129K body.
Have AutoEnginuity W/Ford enhanced. Lima OH area.
My mind works lightening fast. One Flash and it's gone forever.
Bill1013 is offline
post #39 of 40 (permalink) Old 07-03-2013, 01:52 AM
HYDROBOOST?
Hi all! I wanted to check and see if this truck has a Hydroboost. It is common in the brake world, that if the pressure is too low, the brakes will overheat. You may also have a booster/master holding pressure in. ALL of the caliper problems you mentioned are related to excessive heat. IF it does not have HYDROBOOST, we can convert it to Hydroboost. Check on that. I also modify the proportioning valve to raise the pressure to the rear brakes.
POWERBRAKEBOB is offline
post #40 of 40 (permalink) Old 07-03-2013, 06:37 AM
FMTRVT's Avatar
My Photos: (16)
Second post of really bad info .....
Too low of pressure huh? That's a new one.
How are you modifying the prop valve on these vehicles????!!! For over a decade they have used dynamic proportioning within the ABS software. Hopefully your business has good liability insurance if you are installing a mechanical prop in series with the ABS enabled system.
Jack
FMTRVT is offline
  Diesel Forum - TheDieselStop.com > Other Topics > Wheels, Tires, Brakes, and Suspension
