Lube points, driveshaft & suspension - Diesel Forum - TheDieselStop.com
Forum sponsored by: Discount Tire
post #1 of 4 (permalink) Old 07-17-2019, 01:33 PM Thread Starter
So I am planning to lube my 2000 F250 Powerstroke and I see the 4 zerks on the Steering Linkage but I do not see any on the driveshaft, Am I missing anyplace I ought to be greasing?
I note that the maintenance schedule says to check the suspension and driveshaft every 15,000 miles (as well as the exhaust system and heat shields). Dumb questions I know but what are your checking for and how do you do that?
ATLPanther is offline
post #2 of 4 (permalink) Old 07-17-2019, 02:40 PM
ArcticDriver's Avatar
It depends on what parts have been replaced as it was common for Ford to use “Lifetime” greased u-joints, etc.. Part of the reasoning is that owners would neglect to grease and parts would wear prematurely or they would over-grease and it would attract abrasive materials and even blow out rubber boots. The grease they used in these applications is a superior quality and there should be no need to drill and install zerks although that might be beneficial in severe duty environments.
4x4 front axles will quite possibly have zerks at upper & lower ball joints.
One other place that may require grease is the Driveshaft Center Support Bearing (aka carrier bearing).
Also research greasing the spline of the rear driveshaft. This requires a special type of grease recommended by Ford. This service is also a good opportunity to replace driveshaft u-joints IF they feel worn or notchy while disassembled.
SOLD:
ArcticDriver is offline
post #3 of 4 (permalink) Old 07-18-2019, 07:12 AM
An additional lube point are the brake caliper slide pins and these need a silicone based grease such as Syl-Glide.
SOLD:
post #4 of 4 (permalink) Old 07-18-2019, 10:24 AM
Steve83's Avatar
Originally Posted by ATLPanther View Post
...I see the 4 zerks on the Steering Linkage but I do not see any on the driveshaft, Am I missing anyplace I ought to be greasing?
Ford has been eliminating grease points & fittings since the early 80s because the contamination added by adding grease usually causes more wear than would occur in a sealed or greaseless part. So there should be nearly no grease fittings on a 2000 truck. That there are any suggests to me that those are replacement parts.
(phone app link)
(phone app link)
...check the suspension and driveshaft every 15,000 miles (as well as the exhaust system and heat shields). Dumb questions I know but what are your checking for and how do you do that?
For everything, always start with a basic visual inspection. Even someone who knows & cares nothing about vehicle maintenance can still tell when metal is torn, cracking, rusting, wearing, or mangled; so just look around. If you start doing it when the vehicle is new, you can certainly spot changes, even if you don't know what you're looking at. Yours isn't, but if you're not sure, just post good pics and someone can tell you if it's normal or not.
These captions describe some things to look for:
(phone app link)
(phone app link)
(phone app link)
For more, buy the Haynes for your truck, and read it cover-to-cover at least once:
(phone app link)
Steve83 is offline
  Diesel Forum - TheDieselStop.com > Other Topics > Wheels, Tires, Brakes, and Suspension
