Need new tires--advice please - Diesel Forum - TheDieselStop.com
Forum sponsored by: Discount Tire
post #1 of 9 (permalink) Old 05-14-2019, 10:20 AM Thread Starter
2001 F250 2x4. Tire size is 265x75R16. Apparently this size tire is hard to find these days, so the choice is rather limited.
It is a truck that regularly runs over grass. I have AT tires on it now--Toyo on the back and Firestone on the front. I'm considering going with mud grips in the back because whenever the grass is slippery, the tires just spin, then dig holes but won't get any traction.
I've been looking around for mud grips that are good for mostly paved driving but good for grass. There are many, most from manufacturers I've never heard of. My local Gateway Tire would have to order anything but this tire--Americus RUGGED M/T--and their price, including installation, balancing, etc. is $200 per tire. I'd be buying two tires for the rear and moving the rear tires to the front. Toyos would be in the neighborhood of $300+ per tire installed.
Online tires would be much cheaper, but I'd have to pay to get them installed and balanced.
So three questions--
1) Anyone have any thoughts on the Americus RUGGED M/T?
2) What M/T would you recommend for mixed driving?
3) If one buys online, will tire stores mount and balance them for you at what price?
vineyridge is online now
post #2 of 9 (permalink) Old 05-14-2019, 12:54 PM
https://simpletire.com/americus-lt26...-amd2457-tires
https://simpletire.com/toyo-lt265-75r16-360320-tires
https://simpletire.com/goodyear-lt26...12034142-tires
1. I don't know anything about the Americus Rugged M/T $134.99.
2. Toyo Open Country M/T $270.89 Goodyear Wrangler DuraTrac $151.93
3. Free shipping (2-4 days). I take them to my local tire store, where they charge $15 for installation, mounting, and spin balancing.
Last edited by DonWarkentin; 05-16-2019 at 12:13 PM. Reason: Change to correct tire size and load range.
DonWarkentin is offline
post #3 of 9 (permalink) Old 05-14-2019, 03:33 PM
bugman's Avatar
My Photos: (12)
Even with a mud type tire you are still going to just spin on wet grass.
You need to put a bunch of weight in the bed to get the tires to bite. 500-1000 lbs should do it. Then even your AT tires should work.
bugman is online now
post #4 of 9 (permalink) Old 05-14-2019, 04:48 PM Thread Starter
If even mud grips will spin on wet grass, would it make sense to buy ATs and some sort of traction aid? I'm over 70, female, and need my truck bed often. Shifting 500 or a 1000 pounds of dead weight when I need the full bed would be nearly impossible for me.
post #5 of 9 (permalink) Old 05-14-2019, 05:41 PM
bugman's Avatar
My Photos: (12)
That's a little bit of a predicament.
Depending on where you live hardware stores and places like Home Depot and Lowe's sell traction sand that is in a 80 lb or so tube. Even just a couple of them above the axle should help a lot. And you could have them place them into the bed. They don't take up much room since they are around 5" round and a couple of feet long.
The only other thing that you might look into would be a electronic locking rear differential and someone to install it. But there you are looking at close to $1500+.
Do you know if you have a limited slip rear end? If you have a puzzled look on your face right now you can check the sticker on the door jamb and checking this link to see if you do or not. If you do the rear end may need to be either rebuilt or serviced to get it working properly again.
https://www.drivetrain.com/parts-cat...ord-is-it-posi
Other than that you might want to talk to your local tire dealer to see what they recommend for your type of situation. Other than that there are a few other ways to help with traction such as airing down the tires and then airing them back up when you get to the road.
Hopefully someone that has had your type of problem will chime in here to help.
post #6 of 9 (permalink) Old 05-15-2019, 07:14 AM Thread Starter
The door sticker has C 1 under axle. According to the site you linked that is a 3.73 limited slip differential.
I'll have my mechanic check it out.
Thank you.
post #7 of 9 (permalink) Old 05-15-2019, 03:42 PM
https://www.ebay.com/itm/Plastic-Sta...-/173878045189
Get some bread trays, cut off the sides, and use them to get enough traction to get going.
post #8 of 9 (permalink) Old 05-15-2019, 04:49 PM
ArcticDriver's Avatar
The tire size you have 235/65/16 Load Range “E” should be an easy tire size to find. Most of us here have the same size on our trucks.
I would recommend you shop at Discount Tire.
What town do you live in?
NOS Black CPS. ScanGauge-II. Bilstein 5100. Stancor GPR. Walker BTM. Noco Mod. Michelin Defender LTX 285/75/16.
SOLD:
ArcticDriver is offline
post #9 of 9 (permalink) Old 05-16-2019, 12:10 PM
You can also buy online from Discount Tire if you don't have a local store. www.discounttiredirect.com/
https://www.discounttiredirect.com/b...ry-m-t/p/39825
Toyo Tire Open Country M/T $271
http://www.discounttiredirect.com/bu...ngler-duratrac
Goodyear Wrangler Duratrac $201.99
  Diesel Forum - TheDieselStop.com > Other Topics > Wheels, Tires, Brakes, and Suspension
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
Similar Threads
snow tires need some advice 7.3 powerstoke kid 1999-2007 Upgrades and Aftermarket - General 5 11-14-2008 02:06 PM
Need advice for tires for my Moto Metal 951 wheels 20X10 Ricardo 1999-2007 Upgrades and Aftermarket - General 2 11-01-2005 09:22 PM
Duallys eating front tires ShepVA 1999-2007 General Questions 11 09-16-2005 09:25 AM
Need advice on lift and tires HDone 1999-2007 Upgrades and Aftermarket - General 0 08-29-2005 03:05 PM
Advice Please - On Again - Off Again - tall switch out tires on Excursion goldframe Power Stroke Excursions 1 10-15-2002 12:27 PM
