Need Rear Rotors- Powerslots worth it, or autopart store good? - Diesel Forum - TheDieselStop.com
Forum sponsored by: Discount Tire
post #1 of 8 (permalink) Old 02-06-2016, 06:28 AM Thread Starter
My Photos: (5)
My rear rotors are finally shot after 15 years. I have powerslots in the front, but is that really necessary for the rear? I haven't priced them yet, but I am sure they are not cheap. I thought about just using an advance auto coupon code and picking them up from the local store. Also, what is the removal procedure like on the rears? Thanks.
2002 F-250, PSD 6-speed, CC, short bed, 4X4, Toreador Red w/ Silver accent, A.R.E mx cap, Weld Super Single II and 33s in the summer, x-springs, F-350 blocks and badges, AIC, proflaps, ITP intank mod, AirDog with 3 micron filter, isspro guages and TTM, scangauge, husky liners, alarm, xm stereo,stull 5399-p grille, centramatics, ccv mod, AIS Air Filter, Southbend CON O, Detroit Truetrac LSD, coolant filter, 203 stat with billet housing, blackcloud intake heater plug/boost fitting, reese titan hitch, fabcraft PTO cover/temp sender port, prodigy brake controller, ITP Boost Annihalator, oilguard bypass filter, Mag-Hytec rear dif, bilsteins, hellwig rear stabilizer bar, ATS housing, non-ebpv pedistal and exhaust flange, magnaflow 3.5dp exhaust, ITP reg return, turbomaster wastegate controller, and ceramic coated bellowed up pipes, PHP 50t and 80p, currently 127,000 miles.
clydesdale is offline
post #2 of 8 (permalink) Old 02-06-2016, 05:46 PM Thread Starter
My Photos: (5)
oops. I did not know there was a separate forum for brakes. Mods - Feel free to move this. Thanks.
post #3 of 8 (permalink) Old 02-06-2016, 11:15 PM
klhansen's Avatar
My Photos: (180)
When I did rear brakes, I just went with loaded calipers and rotors from the dealer. Aftermarket rotors are not needed, IMO. But I'd at least buy the highest quality line rotors if you go to your local parts store.
), AIS,
regulated return,
klhansen is offline
post #4 of 8 (permalink) Old 02-07-2016, 09:51 AM
I went with suggestions from this site.
Even though dually front rotors are expensive, no matter where you buy them.
I bought mine through Ford and loaded calipers.
2002 F350 7.3 psd supercab dually 2wd, AIS, Moog joints, Bilstein, Michelin Defender LTX, Dieselsite coolant filter, red ELC, prepump spin-on fuel filter, 254,500 miles, hutch/harpoon mod, marinco mod, scan gauge ll, Zoodad, Dieselsite boots, pedestal delete, CNC Fab w/ crossover oil lines, 6.0 trans cooler, replaced oil pan, Walker BTM, Denso starter
1974 CJ6 ... off the frame needs work
2013 Expedition... wife's car
Panhead ... 53 motor, 51 tanks, B grind cam, S&S carb, points, drum brakes ... It doesn't just sit in the garage
panhead george is offline
post #5 of 8 (permalink) Old 02-07-2016, 11:14 AM
Steve83's Avatar
Anything that reduces the surface area in-contact between the pads & rotors 1) reduces the braking force given the same pedal force; OR 2) increases the pedal force necessary to achieve the same braking force; AND 3) increases brake temperature given the same braking force; AND 4) increases pad & rotor wear given the same braking force.
That's essentially the same as what Wilwood says about its own (and any other brand's) drilled/slotted rotors.
For the best braking, lowest temperatures, and longest life, you want the biggest, flattest pads & rotors you can fit in there. The more pistons a caliper has (per side), the flatter the pads will remain.
Cryo-nodular-ceramic-cobalt-whatever rotors are gimmicks. If you want the best, buy the brand Ford controls. They're not much (if any) more expensive than local parts-store junk.
Steve83 is offline
post #6 of 8 (permalink) Old 02-07-2016, 05:17 PM Thread Starter
My Photos: (5)
So, what it sounds like is that I should try to get the best possible price on original motorcraft?
post #7 of 8 (permalink) Old 02-07-2016, 09:13 PM
klhansen's Avatar
My Photos: (180)
If you're not in a giant rush, get them thru AutoNation Ford White Bear Lake. I just got parts to do front brakes (hoses, pads, caliper kits, slide pins, etc) thru them after trying to match up my front hoses locally without success. You can either just go to their site www.parts.autonationwhitebearlake.com or post in their forum if you have questions. Mike was very helpful in getting met the correct parts.
), AIS,
regulated return,
klhansen is offline
post #8 of 8 (permalink) Old 02-07-2016, 11:27 PM
Steve83's Avatar
...original motorcraft?
Yes, check the price of MC parts before buying any others.
No, MC parts are not necessarily "original". Ford doesn't make parts; it makes vehicles. It orders parts from mfrs. who agree to & actually DO meet all Ford specifications; sometimes, they use Ford designs - other times, Ford buys "off-the-shelf" parts that suit its vehicles. There can be MANY suppliers (OEMs) of any one part to the assembly line (OE parts). But the suppliers of parts in MC boxes & bags are NOT always the same mfrs. who supply the assembly line, and the supplier can change over the years (for both OE & MC parts). But no matter who's making MC parts or the country of origin, Ford will only allow them to go into MC boxes if they still meet Ford's latest specs for that part. The same supplier might also make OE pads & rotors for Honda & Caterpillar; and for NAPA & the zone. And each one has its own specs for that mfr. to follow. So just because a rotor comes from the same mfr. as a MC rotor, that doesn't mean it meets Ford specs unless it has the Ford logo on the part.
It's a subtle distinction, but worth being aware of.
Steve83 is offline
  Diesel Forum - TheDieselStop.com > Other Topics > Wheels, Tires, Brakes, and Suspension
