New front brake calipers dragging - Diesel Forum - TheDieselStop.com
Forum sponsored by: Discount Tire
post #1 of 12 (permalink) Old 07-05-2019, 12:52 PM Thread Starter
clem's Avatar
My issue is front calipers dragging after applying brakes. The new calipers have new pads and good rotors. This happens with both sides. I’ve changed all three rubber lines. Steel lines look good. No leaks anywhere. With the wheel off and cracking the bleeder it seems there’s still too much drag on the rotor. This happens with both sides. It seems to me that the wheel should spin Freely.
97 F-250 PSD 4wd 5spd 4.10 SCLB, D60, Tymar intake, 3"dp, EBPV gut, Boost/Pyro gauges, SBC Con-O, Stancor 586-902 GPR, Royal Purple gear and tranny oils,225k
96 F-350 PSD 4 door dually auto 2wd all stock,112k
'87 Tbird TC Auto
'87 Tbird TC 5sp
clem is offline
post #2 of 12 (permalink) Old 07-05-2019, 02:39 PM
If you did not replace the rotors they have a rust ridge that forms on both inner and outer sides of the rotor. The new pads will hit this ridge and drag until the pads or the ridge wears down. It can also cause a shutter when braking.
DENNY
DENNY is online now
post #3 of 12 (permalink) Old 07-05-2019, 05:50 PM Thread Starter
clem's Avatar
Denny,
Thank you for the heads up on the rust ridge. I will check that out first thing in the morning.
'87 Tbird TC Auto
'87 Tbird TC 5sp
clem is offline
post #4 of 12 (permalink) Old 07-07-2019, 05:48 AM Thread Starter
clem's Avatar
I cleaned the rotors. They weren’t to bad. The truck has never been on a salty road. Still the same problem. With the wheels off and pushing the brake pedal a few times the hub and rotor are very hard to turn by hand. A slight pry on the caliper lets them spin free.
'87 Tbird TC Auto
'87 Tbird TC 5sp
clem is offline
post #5 of 12 (permalink) Old 07-07-2019, 09:59 AM
ArcticDriver's Avatar
You have probably already lubed your caliper slide pins but I will just mention it again. Also inspecting them for any corrosion high spots.
SOLD:
ArcticDriver is offline
post #6 of 12 (permalink) Old 07-10-2019, 04:25 AM Thread Starter
clem's Avatar
Thanks Arcticdriver,
The calipers and brackets are new. I did lube them with white lithium. I also installed a new master cylinder. Bled the lines again. It seems they don’t want to fully release.
'87 Tbird TC Auto
'87 Tbird TC 5sp
clem is offline
post #7 of 12 (permalink) Old 07-10-2019, 02:06 PM
klhansen's Avatar
My Photos: (180)
Slide pins should be lubed with silicone grease, not petroleum based. Petroleum based lube will swell the boots and cause the pins to hang up. It's also possible that your front brake hoses (if original) have collapsed inside and are acting like check valves. If you didn't change out the hoses, do that (and get that lithium grease out of the slide pins.)
), AIS,
regulated return,
klhansen is offline
post #8 of 12 (permalink) Old 07-11-2019, 07:04 AM
https://agscompany.com/product/sil-g...ant-tube-4-oz/
I use Syl-Glide.
NAPA sells the same under their label.
Its Silicone based.
SOLD:
post #9 of 12 (permalink) Old 07-11-2019, 12:56 PM
klhansen's Avatar
My Photos: (180)
On re-reading your original post, I see you already changed the lines. Did you mess with the master cylinder at all? If the brake pedal doesn't come all the way up, the piston inside might be covering the relief holes and not allowing fluid back into the reservoir.
You might try shooting a PM to FMTRVT, and ask him to look a this thread. Jack is the resident brake expert and could could probably shed some more light on your issue.
), AIS,
regulated return,
klhansen is offline
post #10 of 12 (permalink) Old 07-11-2019, 10:02 PM Thread Starter
clem's Avatar
Brakes are freed up.
I just kept working the caliper pistons in and out until the dragging went away.
I did install new hoses with the new calipers. White lithium on all contact points. I didn’t put any grease on the pins at all.
'87 Tbird TC Auto
'87 Tbird TC 5sp
clem is offline
post #11 of 12 (permalink) Old 07-11-2019, 10:16 PM Thread Starter
clem's Avatar
I did install a new master cylinder but only after the new calipers and hoses.
'87 Tbird TC Auto
'87 Tbird TC 5sp
clem is offline
post #12 of 12 (permalink) Old 07-11-2019, 10:24 PM Thread Starter
clem's Avatar
Thanks klhansen
That’s all good info
Thanks everyone
'87 Tbird TC Auto
'87 Tbird TC 5sp
clem is offline
  Diesel Forum - TheDieselStop.com > Other Topics > Wheels, Tires, Brakes, and Suspension
