One piece hub/rotor question - Diesel Forum - TheDieselStop.com
Forum sponsored by: Discount Tire
post #1 of 6 (permalink) Old 05-09-2019, 11:31 AM Thread Starter
Are there certain year models of 250's and Excursions that used the one piece hub/rotor vs the removable rotor? The one piece deal sure makes for a lot of extra cost and labor when you only need new rotors.
Howard Avery is offline
post #2 of 6 (permalink) Old 05-09-2019, 10:21 PM
klhansen's Avatar
My Photos: (180)
The 2WD units used one-piece hub and rotors. The wheel bearings on them are separate and serviceable, unlike the unit bearing hubs use on 4WD trucks.
), AIS,
regulated return,
klhansen is offline
post #3 of 6 (permalink) Old 05-10-2019, 04:34 AM Thread Starter
Thanks. So on my 2wd when removing the hub/rotor I can either repack or replace the bearings? Also, do you recommend turning (if possible) or replacing the rotors? I'm starting to have a vibration during heavy breaking.
post #4 of 6 (permalink) Old 05-10-2019, 07:55 AM
klhansen's Avatar
My Photos: (180)
If you have a hard spot in the rotors, turning them is a very short term fix. Ford recommends replacement instead of turning.
FMTRVT (Jack, our resident brake guru) has an excellent discussion on the "warped rotor" myth.
), AIS,
regulated return,
klhansen is offline
post #5 of 6 (permalink) Old 05-10-2019, 02:34 PM
bugman's Avatar
My Photos: (12)
Very few shops will turn a rotor anymore.
It is just cheaper to replace them.
bugman is offline
post #6 of 6 (permalink) Old 05-13-2019, 05:46 AM Thread Starter
Thanks for the info fellas.
  Diesel Forum - TheDieselStop.com > Other Topics > Wheels, Tires, Brakes, and Suspension
Similar Threads
One Piece Rotor (Ford F-350 4x4 Dually Manual) turkxmax Wheels, Tires, Brakes, and Suspension 4 11-18-2011 04:27 PM
Cab trim piece fell off teesh 1999-2007 General Questions 3 09-14-2009 01:16 AM
One piece driveline conversion for 2 piecers? RPMOffroad 1999-2007 Upgrades and Aftermarket - General 2 09-23-2008 10:05 AM
Which clutch piece is the core? az350x Power Strokes 1994-1997 General 1 11-06-2006 02:09 AM
Is the rear hub and rotor one piece or two on a Dually? LWesthaver 1999-2007 General Questions 2 05-17-2006 10:28 PM
