Smoked my brakes today - Diesel Forum - TheDieselStop.com
Forum sponsored by: Discount Tire
post #1 of 5 (permalink) Old 09-01-2011, 11:05 PM Thread Starter
millwrightdude's Avatar
I was towing our camper today and had to slam on the brakes to avoid an accident and smoke the brakes. I could see the smoke coming from the brakes when I got out of the truck. I have about 15k on the new pads and rotors. I would like to replace the pads with something better than the Motorcraft replacement pads I installed.Is there a pad that will help this from happening again.
2002 XLT 350 crew cab Long box white
am/fm/cass/cd 4x4 auto
carpet delete 265/75/16 3.73
limited slip 9900lb package
X springs ranchhand bumpers
B&W Gooseneck & Companion hitch
Firestone airbags & compressor
Rancho shocks 289K and all stock
(Thinking about selling to buy a 6.7)
2015 F250 Regular Cab 4x4 6.2 Gas
B&W Gooseneck
Ranchhand bumpers
Firestone airbags and Airlift wireless compressor kit
37K miles
millwrightdude is offline
post #2 of 5 (permalink) Old 09-02-2011, 03:33 PM
I have power slot rotors and hawk pads on mine, and like them. Living at 8,000 ft, I do a lot of up and down hill driving. Pull a loaded 16 ft cargo trailer some of the time.
02 F250 7.3l AFE intake, 4" turbo back, Bilstein Shocks, BTS trans, bellowed up pipes, DC Power 250 amp alt, X-Monitor Digital Gauge Pack(tran/egt/boost), DP-Tuner( 60 tow,60/80 econ altitude), power slot rotors / hawk pads, front SSBC V8 piston calipers
AE ScanTool
michaelmcm5 is offline
post #3 of 5 (permalink) Old 09-06-2011, 07:33 AM
FMTRVT's Avatar
My Photos: (16)
The first thing I would say is to check the trailer brakes and make sure you can manually lock them. While there is a safety overload factor, truck brakes on any manufacturers product are not sized for trailers.
One of the situation with after market pads, any aftermarket pads, is that they don't go through as long of a post bake process as OE products due, so the thermal history of the pads is important is getting the pads out of the green state. Even though 15k was put on the truck, even with that if you haven't exceeded say 700F prior the pads are still "green" above that temperature.
And it's possible to generate smoke and odor from any pads. Part of our past work was to get OE pads (which have the longest bake and high temperature cycles) to burn and time how long they would continue to burn. Man we hated that process.
Jack
YouTube Videos Google - TooManyToys
Step Lights;Painted Flanges; Bypass Oil Filter; Heated Mirror Switch; Reverse Lights; 7.3L Fuel Reg Shim; 6 Disc Radio Speed Volume Mod; Coolant Filter, etc.
FMTRVT is offline
post #4 of 5 (permalink) Old 09-06-2011, 04:24 PM Thread Starter
I changed the pads out for some motorcraft one's and took .002 off each rotor. Put it all back together and they work great. I wonder if the trailer brakes can be adjusted?
B&W Gooseneck
Ranchhand bumpers
37K miles
post #5 of 5 (permalink) Old 09-09-2011, 05:18 AM
I also love my Hawk LTS pads.
2002 Excursion Limited 7.3L PSD, Auto, 4x4, 35x12.50-17 Mickey Thompson ATZ, Blue Gold, AFE Stage II with ProGuard7, MBRP 4" stainless, DP tuner (hi idle, stock, 40, 60, 80, 120), Adrenaline HPOP, Coolant Filter, Amsoil bypass filter, Ford rear sway bar, 6 1/2" spring arch.
2000 BMW 540i, 6 speed, sport package, daily driver.
jnyost is offline
  Diesel Forum - TheDieselStop.com > Other Topics > Wheels, Tires, Brakes, and Suspension
