SSBC or PowerSlot rotors/brakes? - Diesel Forum - TheDieselStop.com
Forum sponsored by: Discount Tire
post #1 of 4 (permalink) Old 08-26-2018, 09:43 PM Thread Starter
BroncoGlenn's Avatar
I'm looking at needed to do my brakes in the coming months. I'll need new rotors so I'm looking at either going with the SSBC or the PowerSlot rotors and pad sets. The SSBC package I'm looking at this one: https://www.xtremediesel.com/ssbc-short-stop-4-wheel-kit-a236106x?variant_id=109104 .
The other option, and at a higher cost, are the PowerSlot (now StopTech) rotors and Hawk pads. I know that many--with positive reports--have used these in the past, but over the years I'm wondering if other alternatives are just as good.
Application is 2002 F350 SRW, mostly daily driving, occasional towing with non-braked < 3k# trailer or a few times a years a braked travel trailer.
Glenn
2002 F-350/XLT/PSD/SRW/CC/LB/4x4OR/Auto 233k miles
Ford AIS, Edge Insight CTS2 (no tunes), ceramic coated International bellowed up-pipes, RiffRaff billet wheel, EBPV delete pedestal/outlet, RiffRaff boot set, Turbo Master mechanical waste gate actuator, 6.0 trans cooler
BroncoGlenn is offline
post #2 of 4 (permalink) Old 08-27-2018, 05:17 AM
I've had a couple different brands between my trucks. The biggest difference I have found between the slotted ones are if they are cryo'ed or not. The cryogenic treated ones do not seem to warp.
2000 Excursion 7.3L Diesel 4x4, BTS Tranny, AFE intake,Stage1 Single Shot Injectors , GTP38R turbo, EBV delete, 6 position TS chip, Adrenaline HPOP
kcastle is offline
post #3 of 4 (permalink) Old 08-29-2018, 07:16 PM Thread Starter
Thanks for the heads up on that. As I recall what was perceived as warping with pulsations in the pedal was, in most cases, material transfer/buildup on the rotors themselves from the pads. But either way, if the cryo'ed ones lessen that experience that's good to know.
Glenn
post #4 of 4 (permalink) Old 08-29-2018, 08:31 PM
yan7gin's Avatar
Some peoples had issue with drill and slotted rotors devloping micro crack from the drilled hole. Ive been happy so far with my powerstope z36 kit...
F350 2002 7.3
auto, 37/13.5/20 open country, Bushwaker cut-out flare, Bilstein 5100, Maxtow gauges (EGT, Trans temp, Boost), 4 inch diamond eye turbo back axel drop with BTM muffler, S&B intake, RR AIH plug, billet FPR with gold spring, CNCfab Sgt 1 HPOP, CNCfab HPOP line with cross over, CNCfab 4 line fuel kit, ARP heads stud, RDP plenum reinforcing insert, complete CAC intercooler boot kit, full engine seal and gasket kit, 360* turbo rebuilt, WWII, EGPV delete, dark blue CPS, Hydra chip with SDK tunes, Polished compressor manifold, HD coolant, 203* thermostat, Transgo HD kit, Energy suspension bushing kit, front and rear diff fully rebuilt with 4:88 gear ratio, Z36 powerstop heavy hauling brake kit, headlight relay mod, Fumoto drain valve AND STICKER
F350 2008 6.4 (sold)
TT 26' Springdale 2014
7x17 enclose trailer (shop) 2012
yan7gin is offline
  Diesel Forum - TheDieselStop.com > Other Topics > Wheels, Tires, Brakes, and Suspension
