Suspension lift and tire?? - Diesel Forum - TheDieselStop.com
Forum sponsored by: Discount Tire
post #1 of 3 (permalink) Old 01-04-2012, 01:11 PM Thread Starter
ken1221's Avatar
I'm looking at doing a 4" suspension lift and I currently have extra leaf springs in the rear for towing..I was wondering a few things would I have to remove the leaf springs in the rear for it to be level with a 4" suspension lift? and what're the biggest tires & wheels I can run with a 4" lift?? Thanks!
2002
F250 4x4 EC LB, DP Tuner F5, ISSPRO EV2 Gauges EGT, Boost, Trans Temp AIH Delete with riffraff boost fitting adapter, AFE Stage II Intake,
Magnaflow 4" Turbo Back Exhaust w/ Muffler Delete w/ 5" exhaust tip, Wicked Wheel, Turbomaster Wastegate Controller, Tuff Country Rear Leaf Spring Lift, Foil Delete, Moog Ball Joints, Timken Axel Bearing, Gatorback belt, 3" Bushwacker Fender Flares, SS Chrome Grille Insert.
ken1221 is offline
post #2 of 3 (permalink) Old 01-19-2012, 07:44 AM
tdJOHN3's Avatar
This kit would work for what you're looking for. 4" Suspension Lift Kit [EZ-Ride] - 2000-2004 Ford F250 / F350 Super Duty 4wd - 24955 | $904.95
The biggest tires you could go with are 35".
tdJOHN3 is offline
post #3 of 3 (permalink) Old 01-26-2012, 08:02 PM
irishpride's Avatar
I'd suggest with a 4 inch lift you keep the tires around 35x12.5x what ever size rims you have. I run 37x13.5x17 with a 6 inch lift with no problems.
irishpride is offline
  Diesel Forum - TheDieselStop.com > Other Topics > Wheels, Tires, Brakes, and Suspension
