Diesel Forum - TheDieselStop.com
Diesel Forum - TheDieselStop.com (https://www.thedieselstop.com/forums/)
-   Wheels, Tires, Brakes, and Suspension (https://www.thedieselstop.com/forums/f122/)
-   -   Tire Pressure Q (https://www.thedieselstop.com/forums/f122/tire-pressure-q-655750/)
jss35lksa 06-09-2019 05:43 PM
Tire Pressure Q
Can anyone help me find a Tire Load Limit/Inflation Guide for my Continental 225/70R19.5 HSR tires?
I've Googled, Binged my finger raw and can't find anything
klhansen 06-09-2019 06:04 PM
Click here --> Load & Inflation Table Application Guide and it should load up a PDF for you. This happens to be from Toyo, but the brand doesn't matter, just the size.
[on edit] just noticed that doesn't have 19.5 inch wheel sizes listed. Have you tried a commercial tire supplier?
OK, second try: Here's a link from Michelin: https://www.michelintruck.com/michelintruck_en_us/assets/.../load-and-inflation.pdf
jss35lksa 06-09-2019 09:03 PM
yea. it doesn't have the LR-G tires that the F-450 has. Thanks anyway
jss35lksa 06-09-2019 10:36 PM
In case anyone else is interested (I finally found this)
https://commercial.bridgestone.com/c...08-08-2018.pdf
It also covers the LR-G and higher rated tires.
klhansen 06-09-2019 11:18 PM
The second link I found had your size and load range - First 19.5 entry in the middle of page 2.
DonWarkentin 06-10-2019 12:38 PM
The Bridgestone and the Michelin charts are nearly identical, with three exceptions:
1. Michelin chart shows the weight rating for the entire axle, while Bridgestone chart shows the weight rating for the individual tire.
2. Michelin chart shows the weight rating for duals down to 65psi, while Bridgestone chart shows it down to 70psi.
3. Michelin chart shows the weight rating for singles down to 65psi, while Bridgestone chart shows it down to 80psi.
Powered by vBulletin® Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
