Tire Pressure Q - Diesel Forum - TheDieselStop.com
Forum sponsored by: Discount Tire
post #1 of 6 (permalink) Old 06-09-2019, 05:43 PM Thread Starter
jss35lksa's Avatar
Tire Pressure Q
Can anyone help me find a Tire Load Limit/Inflation Guide for my Continental 225/70R19.5 HSR tires?
I've Googled, Binged my finger raw and can't find anything
John
2018 F-450 King Ranch. White Gold. Factory Installed 27K Ford (Reese) 5th wheel hitch.
Fulltime RV'er Pulling a 2019 DRV Mobile Suites.
jss35lksa is offline
post #2 of 6 (permalink) Old 06-09-2019, 06:04 PM
klhansen's Avatar
My Photos: (180)
Click here --> Load & Inflation Table Application Guide and it should load up a PDF for you. This happens to be from Toyo, but the brand doesn't matter, just the size.
[on edit] just noticed that doesn't have 19.5 inch wheel sizes listed. Have you tried a commercial tire supplier?
OK, second try: Here's a link from Michelin: https://www.michelintruck.com/michelintruck_en_us/assets/.../load-and-inflation.pdf
), AIS,
regulated return,
klhansen is offline
post #3 of 6 (permalink) Old 06-09-2019, 09:03 PM Thread Starter
jss35lksa's Avatar
yea. it doesn't have the LR-G tires that the F-450 has. Thanks anyway
John
post #4 of 6 (permalink) Old 06-09-2019, 10:36 PM Thread Starter
jss35lksa's Avatar
In case anyone else is interested (I finally found this)
https://commercial.bridgestone.com/c...08-08-2018.pdf
It also covers the LR-G and higher rated tires.
John
post #5 of 6 (permalink) Old 06-09-2019, 11:18 PM
klhansen's Avatar
My Photos: (180)
The second link I found had your size and load range - First 19.5 entry in the middle of page 2.
), AIS,
regulated return,
klhansen is offline
post #6 of 6 (permalink) Old 06-10-2019, 12:38 PM
The Bridgestone and the Michelin charts are nearly identical, with three exceptions:
1. Michelin chart shows the weight rating for the entire axle, while Bridgestone chart shows the weight rating for the individual tire.
2. Michelin chart shows the weight rating for duals down to 65psi, while Bridgestone chart shows it down to 70psi.
3. Michelin chart shows the weight rating for singles down to 65psi, while Bridgestone chart shows it down to 80psi.
DonWarkentin is offline
  Diesel Forum - TheDieselStop.com > Other Topics > Wheels, Tires, Brakes, and Suspension
