Tire suggestions for F350 - Diesel Forum - TheDieselStop.com
Forum sponsored by: Discount Tire
 1Likes
post #1 of 27 (permalink) Old 09-21-2019, 08:22 PM Thread Starter
Just got a new 2012 King Ranch, needs rear shocks and new tires, otherwise in really good condition, new brakes all around, new brake booster, new front end parts. Pretty much set for the long haul.
Our plans are for road trips towing a travel trailer, so it will be our tow pig, and spare vehicle when needed. Funny thing too, bought it and my daily driver F150 needed some work before it's warranty expires in 120 miles, so worked out great, been driving the Ftreefiddy for a couple days now.
So what would be a decent tire for this, we don't off road, but will drive in snow, and it will be mostly highway when we do.
DD 2018 F150 Platinum 3.5 EB
Tow Baby, 2012 F350 King Ranch SRW SB. Rolling Thunder III
Sold due to neglect
U.S.N. Paradise BB91904 '99 F350 CC LWB DRW
Mods, SuperHyper Improbability drive stage II.
Hypermax 5" turbo back system, triple pillar guages, Heater core shutoff. AEM Brute Force intake. 3.73 gearing. DP PCM with 80HP Installed!
ACD2 is online now
post #2 of 27 (permalink) Old 09-21-2019, 09:32 PM
Whatever brand you get a narrow tire will do better in snow than a wide one.
DENNY
DENNY is online now
post #3 of 27 (permalink) Old 09-22-2019, 11:38 PM
ArcticDriver's Avatar
DENNY
Denny,
The old rule out West was always narrow, high-profile for snow since most roads were not maintained and the narrow tire cut through to road surface where it could get traction. This was true for heavy lugged, studded and/or chained.
Now that roads are maintained more quickly and see more traffic, many argue a standard width tire with good siping and or studs creates a wider surface area (more grip) on plowed or snow-packed or icy roads.
My personal favorite for dedicated snow these days is the General Altimax Arctic w/studs but they are only available in popular widths. Its getting hard to even find narrow & high-profile anymore.
NOS Black CPS. ScanGauge-II. Bilstein 5100. Stancor GPR. Walker BTM. Noco Mod. Michelin Defender LTX 285/75/16.
SOLD:
ArcticDriver is offline
post #4 of 27 (permalink) Old 09-23-2019, 10:31 PM
cagedtoy's Avatar
MICHELIN®️
LTX®️ A/T2
60,000 mile warranty. Best tire on snow and ice that will wear excellent.
New Rig as of 11-2012 99.5 Super Cab Long bed only 77,000 Build date 3-03-99 so it has 99.5 7.3 with early 99 running gear. Edge CTS with Att.
Sold 99.5 F350 Dually Crew Cab 215,000 Ts Tunner, Edge with Att. 4" MBPR Turbo Back no Cat Wicked Wheel rolling on 235 75 16. Sold
Trailer Queen: 84 Toy 4Runner One Ton's Rolling on H1's with 42 Iroks Full Hydro Marlin Crawler 4:7-1 gears with Duall cases. 4.3 Vortech turbo 350 Auto
cagedtoy is offline
post #5 of 27 (permalink) Old 09-24-2019, 12:37 AM
Arctic
My wife has a BMW 535 ix with the wide tires and it does great but, I do put studded tires on in the winter. I have another buddy that runs standard size Bridgestone blizzacks year round. and does well on snow and ice. I am just thinking the OP got a DRW and if that is the case if he is empty he will not have the weight needed for traction. Now if he has and uses 4x4 as need he won't have much of a problem. BUT!! The larger the tire the less downforce PSI. I have a few friends that have big aggressive tires that can't get up a icy hill because they have too much area on the road and they can't get the traction needed. If you are going to run a stock/wide tire without studs on ice you need to suck it up and get a soft tread sniped tire like the Blizzacks. I did have Michelin tires and they where great but not as good as studs.
ACD2
Is it DRW, do you have 4X4?
DENNY
DENNY is online now
post #6 of 27 (permalink) Old 09-24-2019, 09:10 AM
DENNY,
Sorry.
I missed that about the Dually. You’re right, the flotation would be dangerous with greater width.
SOLD:
post #7 of 27 (permalink) Old 09-24-2019, 09:32 AM
Michelin Defender......
I have used the Michelin LTX . The Defender replaced the LTX and has much better tread life.
2002 F350 7.3 psd supercab dually 2wd, AIS, Moog joints, Bilstein, Michelin Defender LTX, Dieselsite coolant filter, red ELC, prepump spin-on fuel filter, 260,000 miles, hutch/harpoon mod, marinco mod, scan gauge ll, Zoodad, Dieselsite boots, pedestal delete, CNC Fab w/ crossover oil lines, 6.0 trans cooler, replaced oil pan, Walker BTM, Denso starter, bellowed up pipes, rebuilt oil cooler, billet dip stick adapter, HD glow plug relay
1974 CJ6 ... off the frame needs work
2013 Expedition... wife's car
Panhead ... 53 motor, 51 tanks, B grind cam, S&S carb, points, drum brakes ... It doesn't just sit in the garage
panhead george is offline
post #8 of 27 (permalink) Old 09-25-2019, 10:46 AM Thread Starter
It is a SRW 4x4. I need to update my profile, my last big truck is still in there. If it were Dually I would just get BFG Commercial TA for it. The King Ranch has 20" wheels which narrows the choices down too much. The Firestone tires it has on now are highly rated, but no longer available, or I would just get a new set of those. Looks like the BFG KO2 will be the ones, getting a lot of good feedback on them, but they are pricey @ $300 each.
I may look into 18" aftermarket wheels and tires as a package, and put the KR wheels aside. It would give me a greater choice in tires and may even cost less.
Sold due to neglect
ACD2 is online now
post #9 of 27 (permalink) Old 09-25-2019, 01:01 PM
If you want something less expensive than the BFG K02 at $300 each, then here are a few suggestions for a winter tire in your size keeping the 20" wheels.
General Grabber Arctic LT @ $206 each
Firestone Winterforce LT @ $220
Cooper Discoverer M+S @ $229
Bridgestone Blizzak LT @ $265
Delta Trailcutter M&S @ $291
https://simpletire.com/catalog?year=...log&category=3
DonWarkentin is offline
post #10 of 27 (permalink) Old 09-25-2019, 01:10 PM
klhansen's Avatar
My Photos: (180)
I've been running the Cooper Discoverer AT3 for quite a few years, and have had good service from them. I run them year-round without studs.
), AIS,
regulated return,
klhansen is offline
post #11 of 27 (permalink) Old 09-25-2019, 04:20 PM Thread Starter
I am not looking for a Winter tire though, I want one for all seasons. Having two sets of tires is mighty expensive and takes up more room than I have. Already have two sets for my F150. Of course, a tire that handles snow well is good, but also needs to be able to handle hot pavement without wearing out in 20 miles like a good snow tire will.
Sold due to neglect
ACD2 is online now
post #12 of 27 (permalink) Old 09-25-2019, 05:58 PM
klhansen's Avatar
My Photos: (180)
I think the AT3's would serve you well. I get good wear from them. I could check how long my last set was on the truck if you'd like.
ACD2 likes this.
), AIS,
regulated return,
klhansen is offline
post #13 of 27 (permalink) Old 09-25-2019, 09:15 PM Thread Starter
Local place has them for $273. Discount Tire. $1503 out the door. I used to sell and install Coopers back in the 90's, they were always happy customer tires back then. Have Coopers on the wife's Focus too.
Sold due to neglect
ACD2 is online now
post #14 of 27 (permalink) Old 09-26-2019, 03:26 PM
klhansen's Avatar
My Photos: (180)
I replaced my last set of AT3's at 42k miles, just a touch under 4 years. When I rolled into the shop to get the current set down in Spokane on a road trip, they were about a zillionth of an inch from the wear bar on the RF tire. I could have run them a bit longer, but had just installed a new camper which put the truck at GVW, and we were a long way from home. I had made arrangements to get them installed in Spokane along our route. Mine are 265/75R16 size so are a bit less expensive than for the larger wheels (not sure why they charge more for a bigger hole in the middle). I paid ~$625, and they had a $70 rebate on a set of 4.
), AIS,
regulated return,
klhansen is offline
post #15 of 27 (permalink) Old 09-27-2019, 12:47 PM
https://simpletire.com/michelin-lt275-65r20-87707-tires
The Michelin Defender is good for all seasons, and it is rated M/S for mud and snow. It has a 50,000 mile warranty, and it costs less than $300 per tire. I have used the Michelin LTX M/S2, which is the progenitor of the Defender, on my truck for many years, with excellent results.
  Diesel Forum - TheDieselStop.com > Other Topics > Wheels, Tires, Brakes, and Suspension
