Diesel Forum - TheDieselStop.com
Diesel Forum - TheDieselStop.com (https://www.thedieselstop.com/forums/)
-   Wheels, Tires, Brakes, and Suspension (https://www.thedieselstop.com/forums/f122/)
-   -   TPM Light (https://www.thedieselstop.com/forums/f122/tpm-light-651673/)
mrmedic 09-04-2018 09:57 AM
TPM Light
Low pressure light started coming on. Any ideas on how to tell which one it is? Pressure is fine in all 4. Just started 2 days ago.
2011 350
130K miles.
Steve83 09-04-2018 10:24 AM
Check the owner's manual for the re-learn procedure. When you get to a wheel that doesn't re-learn, its battery is probably dead. Rotate the tires to get that one into the last learning position, and try again. If it fails at the same location, it's a system problem. If it fails at the same wheel, buy a new sensor, and have a tire shop install it, and re-learn the system.
mrmedic 09-04-2018 11:03 AM
If it is a battery, is it replaceable? Or a new TPM?
ford_doctor 09-04-2018 11:33 AM
If there is a fault with a sensor and the signal is missing the BCM will set a code for it that will identify the offending sensor. Of course this is dependent on the tires and TPMS sensors were trained with them in the current position. I frequently see this issue when cold werather first creeps in after someone has rotated their tires and set the pressures and not retrain the TPMS sensors.
A quick way to determine if you have a bad sensor is to enter the training mode and any sensor that fails to set... well you know.
Steve83 09-06-2018 11:20 AM
Yes, one of those. You won't know if the battery is replaceable until you attempt to buy that sensor, or battery for that specific model of sensor.
But generally: OE TPMS sensor batteries are NOT replaceable.
Powered by vBulletin® Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
