TPM Light - Diesel Forum - TheDieselStop.com
Forum sponsored by: Discount Tire
post #1 of 5 (permalink) Old 09-04-2018, 09:57 AM Thread Starter
TPM Light
Low pressure light started coming on. Any ideas on how to tell which one it is? Pressure is fine in all 4. Just started 2 days ago.
2011 350
130K miles.
12 F350 Lariat. Stock. So far
"You have reached Mr Medic. Please leave a message after the beep. If you would like to hear this recording in a language other than English, take your ass to a country speaks it"
mrmedic is offline
post #2 of 5 (permalink) Old 09-04-2018, 10:24 AM
Steve83's Avatar
Check the owner's manual for the re-learn procedure. When you get to a wheel that doesn't re-learn, its battery is probably dead. Rotate the tires to get that one into the last learning position, and try again. If it fails at the same location, it's a system problem. If it fails at the same wheel, buy a new sensor, and have a tire shop install it, and re-learn the system.
Steve83 is offline
post #3 of 5 (permalink) Old 09-04-2018, 11:03 AM Thread Starter
If it is a battery, is it replaceable? Or a new TPM?
mrmedic is offline
post #4 of 5 (permalink) Old 09-04-2018, 11:33 AM
ford_doctor's Avatar
If there is a fault with a sensor and the signal is missing the BCM will set a code for it that will identify the offending sensor. Of course this is dependent on the tires and TPMS sensors were trained with them in the current position. I frequently see this issue when cold werather first creeps in after someone has rotated their tires and set the pressures and not retrain the TPMS sensors.
A quick way to determine if you have a bad sensor is to enter the training mode and any sensor that fails to set... well you know.
2016 Ford Fusion ENERGI Titanium Plug-in Hybrid
Diesel Technician Society
Diesel Mentor Directory
ford_doctor is online now
post #5 of 5 (permalink) Old 09-06-2018, 11:20 AM
Steve83's Avatar
Yes, one of those. You won't know if the battery is replaceable until you attempt to buy that sensor, or battery for that specific model of sensor.
But generally: OE TPMS sensor batteries are NOT replaceable.
Steve83 is offline
  Diesel Forum - TheDieselStop.com > Other Topics > Wheels, Tires, Brakes, and Suspension
