What type of grease? - Diesel Forum - TheDieselStop.com
Forum sponsored by: Discount Tire
 1Likes
  • 1 Post By ArcticDriver
post #1 of 7 (permalink) Old 07-29-2019, 04:21 PM Thread Starter
Big Horn's Avatar
On my new front hubs there is an o-ring inboard of the hub oil seal, what type grease should I put on it?
I was planning on putting marine bearing grease on the inside of the knuckle before sliding the axle and seal in- would this be alright for the o ring
2002 F350 7.3L / 4R100 - 4WD CC DRW 8 Box, AIH Delete, Gauges- Pyro, Trans Temp, Boost, Fuel Pressure, TS-6 tuner, Zoodad Mod, Mishimoto 31 row Trans cooler, Mobil 1 ATF, Trans return line ATF filter, Hutch/Harpoon Mod, Air Lift Load Lifter 5000 rear air springs, Rancho 9000 shocks, Timbrens on the front.
Big Horn is offline
post #2 of 7 (permalink) Old 07-30-2019, 11:05 AM
Steve83's Avatar
High-temperature (disk brake) wheel bearing grease ONLY. NOT marine (which is not rated for disk temperatures).
Steve83 is offline
post #3 of 7 (permalink) Old 07-31-2019, 11:07 AM Thread Starter
Big Horn's Avatar
I just realized I didn’t describe these parts correctly🙄 the large oil seal that is pressed onto the axle shaft gets installed into the knuckle first with the setting tool. I wanted to lube the knuckle first before install. Then once the axle with seal is set properly—the new bearing hub has an o-ring on the outer diameter where it is installed into the knuckle and fastened with the four studs/nuts on backside of the knuckle. A lot of the videos on installing hubs and replacing the needle bearing that rides on the axles recommends using high quality marine bearing grease as it is not affected by water. Would I still use high temp bearing grease for installing the axle/oil seal and on the hub/o-ring before bolting up?
If I recall correctly the o-ring on the hub is to make a seal for the vacuum in using the ESOF to engage the 4wd lock hubs while in Auto.
I apologize for my OP not describing it correctly- thanks!
Big Horn is offline
post #4 of 7 (permalink) Old 07-31-2019, 07:09 PM
Steve83's Avatar
ESOF is only the pushbutton transfer case.
Originally Posted by 2002 F-Super Duty 250-550/Excursion Workshop Manual SECTION 204-01B: Front Suspension — 4x4 Wheel Hub REMOVAL AND INSTALLATION Procedure revision date: 02/10/2004
NOTE: Apply a coat of Ford High Temperature 4x4 Front Axle and Wheel Bearing Grease E8TZ-19590-A meeting Ford specification ESA-M1C198-A to the O-ring area of the wheel hub and bearing before installing the hub and bearing.
Marine grease IS affected by water - just not as badly as common grease. Never use marine grease on any brake wheel.
Steve83 is offline
post #5 of 7 (permalink) Old 07-31-2019, 08:20 PM Thread Starter
Big Horn's Avatar
Thank you Steve83
I start going back together with it tomorrow- I did get the Spicer solid u-joints installed. Smoooooth! I’m not so sure the greasable u-joints that we’re in there didn’t have significant wear—I didn’t realize how stiff they were until I got the new Spicers in.
Big Horn is offline
post #6 of 7 (permalink) Old 07-31-2019, 08:56 PM
ArcticDriver's Avatar
+1 for non-greasable u-joints.
panhead george likes this.
NOS Black CPS. ScanGauge-II. Bilstein 5100. Stancor GPR. Walker BTM. Noco Mod. Michelin Defender LTX 285/75/16.
SOLD:
ArcticDriver is offline
post #7 of 7 (permalink) Old 08-01-2019, 11:35 AM
Steve83's Avatar
(phone app link)
Steve83 is offline
  Diesel Forum - TheDieselStop.com > Other Topics > Wheels, Tires, Brakes, and Suspension
