where to order cryo slotted rotors - Diesel Forum - TheDieselStop.com
Forum sponsored by: Discount Tire
post #1 of 2 (permalink) Old 07-07-2019, 06:27 PM Thread Starter
2000 F250 crew cab 180,000 miles
Being 20 years old I want to change master cylinder to hose to calipers and rotors.
Looking at cyro slotted,dont know if I need them. Did put cyro on 2000 excursion and made big improvement.
Any suggestions where to order ?
2000 f250 crew cab,100,000 miles, 3:73 gear
1997 F250 7.3, 4:10 gear
The 97 feels like it pulls better then the 2000
lbvb is offline
post #2 of 2 (permalink) Old 07-07-2019, 09:32 PM
Rock Auto
https://www.rockauto.com/en/catalog/...hub,rotor,1896
DonWarkentin is offline
  Diesel Forum - TheDieselStop.com > Other Topics > Wheels, Tires, Brakes, and Suspension
