where to order cryo slotted rotors - Diesel Forum - TheDieselStop.com
Forum sponsored by: Discount Tire
post #1 of 3 (permalink) Old 07-11-2019, 07:53 AM Thread Starter
2000 F250 4wd. Want to replace whole brake system.
Who to order from ?
2000 f250 crew cab,100,000 miles, 3:73 gear
1997 F250 7.3, 4:10 gear
The 97 feels like it pulls better then the 2000
lbvb is offline
post #2 of 3 (permalink) Old 07-19-2019, 12:04 AM
woodnthings8's Avatar
Check out Riffraff Diesel. I ordered all new rotors and EBC pads to rejuvenate mine. They work great now.
Sent from my SM-G965U using Tapatalk
Ken
2002 F-350 CCLB 4X4, HD4R100 , Riffraff FRx, Riffraff CAC Boots & PRI's, Bellowed Up-Pipes, 4" Diamond Eye exhaust, Powerslot rotors,
, DP Tuner-F6, Autoenginuity, EEC-V Breakout Box, KCM S.S. HPX Line, S&B Filters intake, Quad Autometer gauge pod, Inovations canopy, Banks Big Head wastegate actuator, 6.0L Trans Cooler,
Zoo-dad, Dieselsite Coolant Filter, Cobra 29LTD/NW CB, DVD and always looking to do more....
woodnthings8 is offline
post #3 of 3 (permalink) Old 07-19-2019, 12:34 PM
https://www.summitracing.com/search/...250-super-duty
Summit racing has cryo slotted rotors.
DonWarkentin is offline
  Diesel Forum - TheDieselStop.com > Other Topics > Wheels, Tires, Brakes, and Suspension
