Will they fit?? - Diesel Forum - TheDieselStop.com
Forum sponsored by: Discount Tire
post #1 of 4 (permalink) Old 01-24-2012, 11:32 AM Thread Starter
summitman6.7's Avatar
Will they fit??
Can I fit a 325/60/20 on my 2011 F350 with out a leaving or a lift kit?? I have Bushwacker flairs all the way around.
2011 F350 Crew/Long XLT 6.7, Tux Black, 3.31 gears w/ 20" KMC Rock Star's wraped in 325/60/20" Goodyear Dura Trac's.
summitman6.7 is offline
post #2 of 4 (permalink) Old 01-25-2012, 06:01 PM
Jassman's Avatar
yes you can....orig. I had the 2" front level kit...and the same 325 60 R20 BFG tires.. rubbed slightly making a full tilt left turn..rubbed on the inner frame..no problem..turning right and in reverse both ways no problem. When I needed new tires..went with the same brand but upgraded to the new Rancho 9000 adjustable shocks.. no level kit, truck rides so much better with better control, sits level....but still the same amount of rubbing.. I just crank it all the way until I feel it and then back off...
ok I figured out how to make it work..click the last pick 3 times and you can see a super big shot of the tire and bushwacker...
Name:	photo 3 (2).JPG
Name:	photo 2 (2).JPG
2015 F350 LWB CC 3.55 Platinum on order
2012 F150 FX4 w appearance package
2011 F350 LWB CC 3.55's GPS Lariat. my truck
2010 F150 FX4 5.4 3.73's
2008 F350 LWB CC 6.4 dually. 3.73's
2007 F350 LWB CC 6.0 Dually, 4:10, ID SCT tunes Xtreme race, Xtreme street, and tow w/agressive brake, MBRP Turbo back cool duals AFE Mega 2 ..
Jassman is offline
post #3 of 4 (permalink) Old 01-30-2012, 02:35 PM Thread Starter
Thanks, Got the tires on this weekend. They look MUCH better than the 275/65/2's did with the bushwacker flairs. No leaving or lift. I had to trim the wheel well liner a bit, but not much. I am gonna look into the shocks you talked about to see if I can get a little hieght with them.
post #4 of 4 (permalink) Old 02-01-2012, 12:30 AM
Looks great Jassman, I like the blue a lot better than the black stripes. When it comes time to replace my oem goodyears I'm following your lead with those 325 bfg's. aka: Z06 over on the OSO site.
06 F350 Amarillo, 4x4, 6.0L, CC/SB, SRW, factory 20's, Line-X, ATC Platinum tonneau, MBRP downpipe to custom dual straight pipes, ISSPRO EV2 gauges, scangauge II, coolant filter, Fleetrite ELC, upgraded STC fitting & turbo oil supply & drain, EGR cooler delete, Innovative Diesel SCT X3 tow & economy tunes, custom 3M ScotchCal paint protection film.
Amarillo is offline
  Diesel Forum - TheDieselStop.com > Other Topics > Wheels, Tires, Brakes, and Suspension
