Battery cable - positive side - terminal broke - Diesel Forum - TheDieselStop.com
 6Likes
post #1 of 56 (permalink) Old 03-31-2016, 11:49 PM Thread Starter
I was replacing both batteries in my 04 excursion (6.0) this afternoon> The positive terminal on the passenger side was badly corroded and when I tried to lift it off the battery the positive cable coming from the driver side that is crimped into the terminal just snapped off. I have been racking my brain trying to figure out a fix, but the back end of the terminal connector is also a crimped connection to another positive lead and no wiggle room to work on this.
Anyone else have this happen? is it just break down and buy the whole assembly - or is there an easier fix?
2000 F350 4x4 Crew, 3.5" lift, Rancho 9000 and 35"BFG.
2004 X 4x4, leather, 4" lift, MX6 and 35" Grapplers.
JB4LCM is offline
post #2 of 56 (permalink) Old 04-01-2016, 01:34 AM
Steve83's Avatar
This photo album shows how to repair it correctly under $15:
This is another option:
Steve83 is offline
post #3 of 56 (permalink) Old 04-01-2016, 01:05 PM
I recently redid my battery cables with new terminals using NOCO TZKIT3 Lead-Free Military Grade Zinc Battery Terminal Kit.
The kit was $9. I have about another $40 in new terminal lugs and 00-AWG welding cable between the batteries now. Best part is, you don't have to take the terminals off the battery when servicing things.
2000 Excursion 7.3L Diesel 4x4, BTS Tranny, AFE intake,Stage1 Single Shot Injectors , GTP38R turbo, EBV delete, 6 position TS chip, Adrenaline HPOP
kcastle is offline
post #4 of 56 (permalink) Old 04-01-2016, 04:33 PM
bugman's Avatar
My Photos: (12)
If you need it now and can't wait a week for shipping to occur just go down to your local NAPA parts store and pick up a cable assembly.
Done.
bugman is offline
post #5 of 56 (permalink) Old 04-01-2016, 06:25 PM Thread Starter
Called a good diesel guy in town (worked for Ford for 20+ years) and he said WHY pay the $300 for the ford harness when you can go to the battery guy in town and he'll rebuild your cables in an hour.
I did. And DONE - all for $46.
JB4LCM is offline
post #6 of 56 (permalink) Old 04-01-2016, 09:14 PM
ArcticDriver's Avatar
I wish my town had a "battery guy" that worked that cheap.
Heck, I am not even sure my town has a guy who will do that work.
NOS Black CPS. ScanGauge-II. Bilstein 5100. Stancor GPR. Walker BTM. Noco Mod. Michelin Defender LTX 285/75/16.
SOLD:
ArcticDriver is offline
post #7 of 56 (permalink) Old 04-02-2016, 12:37 AM
Steve83's Avatar
...WHY pay the $300 for the ford harness when you can...
...click the Amazon link I posted?
...And DONE - all for $46.
The cables are pretty, but that battery terminal is garbage, and there's nothing to protect all that bare copper.
Then become him.
Steve83 is offline
post #8 of 56 (permalink) Old 12-02-2017, 01:35 PM
I realize this is an old post but I'm dealing with corroded terminals on my 2005 Excursion and have been planning to upgrade my alternator so it makes sense to upsize the battery cables as well.
Can you post a photo of your batteries with your current cable setup that you described in the post from last year?
dillon134 is offline
post #9 of 56 (permalink) Old 12-02-2017, 03:31 PM
klhansen's Avatar
My Photos: (180)
There's no need to upsize the battery cables for a higher amp alternator, just the cable between the junction at the battery cables and the alternator. The battery cables are already sized for starting current, which is WAY more than any alternator you put on will put out. Unless the battery cables are corroded or otherwise deteriorated, there's no need to change them out.
), AIS,
regulated return,
klhansen is offline
post #10 of 56 (permalink) Old 12-02-2017, 03:50 PM
Thanks for the reply. Yep, my cable terminal on the drivers side battery is falling apart. I'm having a tough time finding a replacement terminal end for it so I figured this would be the time to just upgrade the entire cable assembly.
Based on your comment, I don't need to.
post #11 of 56 (permalink) Old 12-25-2017, 03:20 PM
kcastle is offline
post #12 of 56 (permalink) Old 12-25-2017, 03:41 PM
KCastle,
You appear to be missing one green felt ;-)
So are the cables original and only the terminals new? Or did he build the entire length new?
SOLD:
post #13 of 56 (permalink) Old 12-25-2017, 03:51 PM
That looks like a great setup. I'd like to just replace the terminal ends and reuse the current cable but assume I'd have to purchase a hydraulic assisted crimper to ensure a good connection.
post #14 of 56 (permalink) Old 12-25-2017, 05:26 PM
chuckster57's Avatar
I see nothing wrong with the “bare copper” ends. Just replaced six 6V batteries in a motorhome 5 years old. A touch of spray and a minute of 150 grit paper and they look like they will go another 5 years at least.
Only reason the batteries were replaced was the owner never checked the water and boiled them dry.
Train Horns:
PM please not visitor message
chuckster57 is offline
post #15 of 56 (permalink) Old 12-25-2017, 05:28 PM
I made my own cables last year. There is a tool that you can use a small sledge hammer with. I use it a lot at work when we add a second battery in an RV.
Train Horns:
  Diesel Forum - TheDieselStop.com > Ford Diesels > Power Stroke Excursions
