Battery cable - positive side - terminal broke - Page 3 - Diesel Forum - TheDieselStop.com
 6Likes
post #31 of 56 (permalink) Old 12-26-2017, 10:52 PM
Steve83's Avatar
Originally Posted by kcastle View Post
Those are cheap batteries, and the stack of ring terminals on that positive clamp is a poor connection. Look at how the current has to flow between the big red cable at the far Left, and that positive battery post:
-cable
-crimped ring
-bolt OR tiny ring to the other big ring
-clamp
-post
Every one of those joints is subject to corrosion because it's exposed to the atmosphere (which can include Oxygen, rain, engine fluids, battery acid...). Even the crimped joints can wick acid in. For each joint, there's SOME voltage drop; if the joint is dirty or loose, there's more drop. If the cables were soldered directly to the clamp,
there'd be only 1 joint to worry about:
-clamp
-post
And those rings don't look very clean right now, so they're probably already dropping the battery voltage.
Originally Posted by chuckster57 View Post
There is a tool that you can use a small sledge hammer with.
A soldered joint is easier, cheaper, stronger, and a VASTLY-superior electrical connection. It can also be UN-joined without damage to the cable or terminal, so either can be reused. It just takes a minute or 2 more to solder than to whack. The tool for soldering (a common propane torch) is cheaper, too.
https://www.supermotors.net/registry/2742/69178-4
Originally Posted by dillon134 View Post
Anybody know what the guage is of the OEM positive battery cable?
Use a drill index to find the diameter of the stripped cable, and compare it to the chart ~1/3 down this page:
https://en.wikipedia.org/wiki/American_wire_gauge
...these POS.
The one you linked isn't OE for these trucks. It looks like a much-newer design, and probably for a car or small SUV.
Originally Posted by 79jasper View Post
I won't say to do it or not to do it, but some just buy welding cable.
Welding cable bears that designation merely because it's made of finer strands, so it's easier to bend by hand - that makes it more-suitable for a welder to manipulate the electrode. And the insulation is more cut- & abrasion-resistant, to tolerate being walked or rolled on. Otherwise, it's just high-quality wire.
Steve83 is offline
post #32 of 56 (permalink) Old 12-27-2017, 12:41 PM
79jasper's Avatar
Oh, I know why it's thinner strand. Lol
How do you feel about crimped then soldered? Heard of people doing that also.
Sent from my SM-G892A using Tapatalk
79jasper is offline
post #33 of 56 (permalink) Old 12-27-2017, 02:14 PM
Originally Posted by ArcticDriver View Post
KCastle,
You appear to be missing one green felt ;-)
So are the cables original and only the terminals new? Or did he build the entire length new?
The cables between the two batteries, and the battery to the engine ground are all new. The cable is 2/0 AWG welding cable.
2000 Excursion 7.3L Diesel 4x4, BTS Tranny, AFE intake,Stage1 Single Shot Injectors , GTP38R turbo, EBV delete, 6 position TS chip, Adrenaline HPOP
kcastle is offline
post #34 of 56 (permalink) Old 12-27-2017, 02:16 PM
That looks like a great setup. I'd like to just replace the terminal ends and reuse the current cable but assume I'd have to purchase a hydraulic assisted crimper to ensure a good connection.
The crimper I used is a manual crimper. TEMCo Lug Crimper Tool TH0012 - 8 AWG - 0000 AWG(4/0) DIELESS Indent
kcastle is offline
post #35 of 56 (permalink) Old 12-27-2017, 02:25 PM
-cable
-crimped ring
-clamp
-post
It would seem I have a really crappy batteries and battery setup. It just happens to start every time for some reason.
All the connectors and wire were fluxed, swaged on, and soldered. Then they were covered in adhesive heat shrink. The entire terminal is covered in superlube anti-corrosion gel. I do agree that I forgot to clean end ends this past fall. There may be a small amount of loss with the ring terminals stacked, but everything is very serviceable.
kcastle is offline
post #36 of 56 (permalink) Old 12-30-2017, 01:30 PM
Steve83's Avatar
I feel it's counterproductive, and a waste of a good solder terminal plus an inch of each wire.
What possible benefit can there be to crimping a good solder joint? The solder is mechanically stronger than the crimp (by a WIDE margin). And crimping doesn't improve the electrical connection over solder. All it does is prevent the joint from being separated; the terminal can never be emptied & reused, and the wire can't be removed without cutting some off.
So what can you even hope to gain from it?
I've heard people argue that "if it gets hot, the crimp will keep the wire from dropping out". Maybe. But there will still be liquid solder running out, shorting other things & maybe even setting them on fire.
And if any of my soldered terminals ever gets hot enough to melt the solder, I WANT the wire to fall out. Maybe it'll break the circuit before the terminal catches fire, or the battery explodes. If there's THAT much current flowing, and THAT much resistance at that terminal, keeping them together is NOT helpful.
The reason is that they haven't had enough time to corrode to the point of you noticing the problem. But they will...
Why? It's strictly cosmetic - it has no function (IN THIS APPLICATION). The solder seals liquids out of the wire strands, and the ring terminal is still exposed. So the heat-shrink doesn't seal or insulate anything.
The only places that matter are where the rings touch other metal. But if they weren't shiny-clean before you applied the gel, you aren't protecting anything.
...everything is very serviceable.
Solder is, too. But it doesn't age like a stack of rings does. And it has less resistance. And it costs less. And it takes less time to make, or repair.
Steve83 is offline
post #37 of 56 (permalink) Old 12-30-2017, 03:37 PM
79jasper's Avatar
Just curious. Lol
If it was properly crimped, you wouldn't get any solder into the joint anyways.
I've heard all sides of crimped vs soldered vs both.
79jasper is offline
post #38 of 56 (permalink) Old 12-30-2017, 04:04 PM
I feel that crimped is much better but I still haven't finished reading this post so I may change my mind in an hour or so ;-)
dillon134 is offline
post #39 of 56 (permalink) Old 12-30-2017, 05:35 PM
Steve83's Avatar
Assuming you could get a perfect crimp (which I doubt), you'd still have needlessly ruined a solderable terminal & an inch of wire(s). If you were planning on soldering all along, you gain nothing by crimping first.
But if you're assuming a perfect crimp, why waste the solder? The added strength? Only if you plan to lift the battery by the cables, frequently.
Steve83 is offline
post #40 of 56 (permalink) Old 12-31-2017, 03:53 AM
ArcticDriver's Avatar
Originally Posted by JB4LCM View Post
I was replacing both batteries in my 04 excursion (6.0) this afternoon> The positive terminal on the passenger side was badly corroded and when I tried to lift it off the battery the positive cable coming from the driver side that is crimped into the terminal just snapped off.
Hold your fire boys. Cease fire.
My question is which method, crimp or solder, would have benefitted the OP more?
It sounds like even if the crimp was performed correctly when new that the corrosion resulted in the cable strands disintegrating and this resulted in the crimp no longer having a tight grip.
Would the same have occured with a solder? Would a wire strand encapsulated in solder be safe from corrosion?
OK...you can start shooting again.
NOS Black CPS. ScanGauge-II. Bilstein 5100. Stancor GPR. Walker BTM. Noco Mod. Michelin Defender LTX 285/75/16.
SOLD:
ArcticDriver is offline
post #41 of 56 (permalink) Old 12-31-2017, 10:49 AM
chuckster57's Avatar
The problem isn't that one method is superior to the other, but rather the need to continue a "I'm right, your wrong" discussion. I have crimped NUMEROUS battery cables over the years and have had the battery fail long before the connection corroded. This includes autos and RV's. Unless someone can post FACTS from an INDEPENDANT source, I say they are both good to go....Lets leave it there.
79jasper and stumpman like this.
Train Horns:
PM please not visitor message
chuckster57 is offline
post #42 of 56 (permalink) Old 12-31-2017, 11:32 AM
79jasper's Avatar
Searching the interwebs, it seems soldering is not recommended for battery cables.
Most times, the strands break at the edge of the solder. (Now this could be a case of operator error)
So I would say, if you don't have the right setup to solder them, then just crimp it.
79jasper is offline
post #43 of 56 (permalink) Old 12-31-2017, 12:24 PM
Steve83's Avatar
I didn't realize we were shooting. I was just trying to thoroughly answer what he axed me.
Corrosion can only affect a surface exposed to something corrosive. Solder adheres to Copper, effectively becoming a new surface. Crimping merely mashes the surfaces together, but all those surfaces are still exposed to air, water, battery acid, and everything else in the atmosphere around them. Water & acid will wick into a crimp; they can't wick into solder.
Yes, solder reduces the flexible length of cable. But if the cable is pre-bent before soldering to the shape it needs to be (as that photo album shows), that doesn't add any stress to the soldered cable, and it doesn't break.
The only setup needed is a common propane torch.
79jasper and ArcticDriver like this.
Steve83 is offline
post #44 of 56 (permalink) Old 12-31-2017, 02:50 PM
I built/repaired several battery cables with new ends. I use solder on the and use HD heat shrink, I do not have a crimper so solder is easy choice for me. One set of cables have 15 years on them with no problems. Just one more thing to stir the pot is how corrosive is the flux and what effect will it have on the copper wire not covered with solder?
DENNY
DENNY is offline
post #45 of 56 (permalink) Old 12-31-2017, 03:33 PM
Steve83's Avatar
That would depend on the flux. If you're talking about rosin-core electrical solder, it's NOT corrosive to Copper - that's why it's used. But if you're talking about MISusing acid-core plumbing or structural solder on Copper wire - sure, it's corrosive.
DENNY and ArcticDriver like this.
Steve83 is offline
  Diesel Forum - TheDieselStop.com > Ford Diesels > Power Stroke Excursions
