Glow plug sensor - Diesel Forum - TheDieselStop.com
post #1 of 5 (permalink) Old 08-11-2018, 02:03 PM Thread Starter
Glow plug sensor
My 7.3 would not start today. I have a hand held Actron diagnostic device.
It showed the codes for the glow plugs and glow plug sensor have failed.
Would this cause the motor not to start?
Any one out there have any advice?
Thank You!
iluv2drive is offline
post #2 of 5 (permalink) Old 08-11-2018, 02:12 PM
RT
RT's Avatar
It might keep it from starting in cold weather. Should have minimal issues in August.
RT is online now
post #3 of 5 (permalink) Old 08-13-2018, 02:50 PM Thread Starter
thanks
post #4 of 5 (permalink) Old 08-13-2018, 06:21 PM
klhansen's Avatar
My Photos: (180)
Could be an ICP sensor problem. Disconnect the sensor (located on the driver's side head behind the alternator) and try starting again. If the sensor has oil in the electrical connector, it's toast and needs to be replaced. If it's giving the PCM a biased signal that's still within normal range it could cause a no-start due to low HP oil pressure.
Like RT said, a glow plug issue shouldn't cause a no-start in August, even in Alaska.
), AIS,
regulated return,
klhansen is offline
post #5 of 5 (permalink) Old 08-13-2018, 08:11 PM
ArcticDriver's Avatar
Just a reminder for those living at high elevation that BARO also affects the need for a proper functioning GP system.
NOS Black CPS. ScanGauge-II. Bilstein 5100. Stancor GPR. Walker BTM. Noco Mod. Michelin Defender LTX 285/75/16.
SOLD:
ArcticDriver is offline
  Diesel Forum - TheDieselStop.com > Ford Diesels > Power Stroke Excursions
